signed
1D83 0902 Euston-Holyhead on June 12 seems to be pathed as 80x (2x805 until Crewe), the AWC website seat map has 805 graphics and no Advance are available tickets as well.
Already reserved?What's with the random seats with no number
No, the dark blue ones (such as seat 35 and 32 in the image) are reserved seats, that theme is used for seats that can't be reserved.Already reserved?
First thinking would be that it is made so that only the seats actually on a Voyager are available, to accommodate for a change of stock, but that can also be a bug.What's with the random seats with no number
Already reserved seats are greyed outAlready reserved?
Looking like the 807's are becoming a bit of a white elephant with their rather limited route availability.The June 2024 edition of Modern Railways has a short article about the 805s introduction.
They're expected to enter service in "early June" alongside the timetable change, but they may be introduced on the 1st of June for positioning purposes. The 805s are expected to be introduced on NWC services, not the London-West Midlands services they were originally touted to be introduced first on, presumably due to the axing of the Shrewsbury trains—807s to follow later.
No mention of Liverpool whatsoever.
there are only 10 of them - so they couldn't be used on many routes in any case;Looking like the 807's are becoming a bit of a white elephant with their rather limited route availability.
Heard they won't be able to work North of Crewe for the time being.there are only 10 of them - so they couldn't be used on many routes in any case;
As I understand it, in the long term they'll be used on Blackpool North, Birmingham and Liverpool services - which is more than enough
yes, as has been reported in this thread, due to limitations on the power supply they won't be able to work to Liverpool (not sure about Blackpool) - However the power supply should be upgraded so that will be a temporary limitation, and the 805s are ahead of the 807 in delivery anywayHeard they won't be able to work North of Crewe for the time being.
Is the power supply issue Crewe - Weaver Junction area or from Weaver Jn to Lime Street (or both)?yes, as has been reported in this thread, due to limitations on the power supply they won't be able to work to Liverpool (not sure about Blackpool) - However the power supply should be upgraded so that will be a temporary limitation, and the 805s are ahead of the 807 in delivery anyway
Both.Is the power supply issue Crewe - Weaver Junction area or from Weaver Jn to Lime Street (or both)?
Wasn't the line to Blackpool North electrified fairly recently? How are there already safety concerns?Both.
According to this PWI presentation "NW&C 25kV Future Electrification requirements", there are no concerns south of Crewe, but the whole line between Crewe and Lime Street, and between Crewe and Euxton is classed as Yellow: "There are concerns for the ability of Feeder Stations to continue their current output without interventions". And the line between Euxton and Blackpool is classed red, with "Safety Concerns" at Catteral feeder station.
See chart on p16
The parallel power upgrade programme was not completed on these sections - they are still using 1970s switchgear.Wasn't the line to Blackpool North electrified fairly recently? How are there already safety concerns?
Thanks, very interesting.Both.
See chart on p16
I noticed that the West Midlands Voyager services seem to be mostly single Voyagers at present. I presume this may be related to the Voyagers going off lease.
It maybe from the new timetable with the dropping of Shrewsbury and with completion of the 9 car Pendolino upgrade that there might be possible to run some of the West Midland semi fasts with Pendolinos pending 807 availability.
Also I've seen comments here about the seats being offered by the Avanti seat reservation tool post timetable change.
I'm travelling to Holyhead today ( pre timetable change) and I noticed that the Avanti seat reservation tool would only offer a single Voyager to choose seats in even though the service is a double voyager.
Full 2 set Voyager all the way to Holyhead.Does your train drop a set in Crewe or Chester though?
Not sure if you are aware but there is testing this week of 805 + 807.Just checked on RTT and - for example - Monday to Friday two of the five Euston->Holyhead services stop at Tamworth and Lichfield.
Neither of them are 312m, I make them about 295m (Tamworth) and 270m (Lichfield) maximum from Google Earth, so the official usable length is probably a bit less.
Do you know the head codes or times ?.Not sure if you are aware but there is testing this week of 805 + 807.
Not related to passenger use but EMC testing and tomorrow is the last day of the week of the tests.
Oxley - Wolves - New St - Stafford - Euston - Crewe - New St - Oxley.
Thursday 23rd MayDo you know the head codes or times ?.
Looks like it is
5Q96 into Euston p16 at 10:57 and
5Q97 from Euston p16 at 12:05.
Thanks, I think. Well saves me a trip out.Thursday 23rd May
RTT shows 5Q96/97 Cancelled
The 80x have had loads of test runs North of Crewe, routinely running to Lancaster, a single test run is quite different to running a full service.It ends up at Blackpool and it is pathed as 80X on electric. It is only a "runs as required" but I wonder how this fits with the juice not strong enough North of Crewe argument ?.
807 is out next week on its own, PIS testing Crewe - Euston via the West Mids.Thanks, I think. Well saves me a trip out.
In other news I fished around and found this
This train runs as required
This service runs on an as required basis, and it has not yet been activated in the railway computer systems. This alert will disappear if the train is activated.
If the service should have departed by now, this normally means it is not running. If the train is set to run in the future, then check again closer to the time.
Operated by Avanti West Coast
- UID S52113, identity 5Q94
TSC 22112001- STP schedule
SSuX - 20/05/2024 to 24/05/2024- Empty Coaching Stock
- Great Britain (Network Rail, TPS)
- Pathed as Class 80x on electric
Planned for 125mph max- Runs as required
Departs Euston at 17:05
Arrives Blackpool North at 20:00
Do we know yet if the 805/807s will be in service in July? Planning a trip to North Wales potentially and wouldn’t mond trying out the new trains if they’re in service.
805002 as shown on the linkAnother 805 test possibly?
