There's a flag switch - see the yellow/black flag in the offside window of the train shown. When it's raised, the motor weak field is enabled. It's designed like this so as to make it visible from outside the train, allowing managers to check with a glance whether any trains have weak field enabled in the tunnel sections.
That's interesting! Done some digging but couldn't find much, I'm assuming weak field isn't permitted in certain sections?
I drove 170s from their introduction on Central in 2000 until CT was split up. I don't think that at any time during that period anyone involved with them actually understood the things. Certainly my traction training was full of "Hang on, the book says that shouldn't happen!"Make sure you get a good instructor because these DMUs are very different beasts to EMUs. I went from the same traction card as you to Cl170s and I still don't fully understand them. I think my instructor imagined that I had previous diesel experience and assumed that there were things I already knew about their design, systems and operation.
If you ever get the chance, you might like to try playing with a Sprinter and seeing the effect of using the various power notches to reach 10mph. You'll find that your assertion that there's no point using full power doesn't quite correlate with what actually happens.No point in using full power from a standing start in a dmu with mechanical transmission. The extra power is wasted at heat.
That's not an instruction I've ever seen.That's why they instruct Sprinter drivers etc not to start select full power until approx 10-15 mph is reached.
No point in using full power from a standing start in a dmu with mechanical transmission. The extra power is wasted at heat. That's why they instruct Sprinter drivers etc not to start select full power until approx 10-15 mph is reached.
Diesel electrics such as class Voyagers seem to be different and full power can be used earlier ?
Is the class 22x the best modern diesel unit to drive ? My vote for the best EMU to drive would be one without a gangway in the middle. A 390 or 395![]()
OK here's one about the dead man's device. How hard is it to keep it engaged for ages on end?
I imagine that if I had a pedal I had to keep depressed with my feet (while sitting down) with sufficient pressure to prevent it springing back up, I would only manage a few minutes at best before my leg muscles tired. Is it that your muscles develop to enable you to keep it depressed for a few hours, or is it easier than I imagine?
The Perkins 158 units have a known throttle control problem with most when selecting notch 1, 2 or 3 don't even move, you do not get any proper acceleration until you select notch 5, the Cummings engine 158's are fine as are the 150's, 153's and 156's. Unfortunately the Perkins engine 158's have a mechanical throttle control that is exceptionally difficult to set up correctly where the Cummings engines sprinters have an electronic throttle control. Even so when driving a 158 I will select notch 2 to start to fill the gearbox up with oil then to 4 and see if it moves and at about 3 mph up to 5, 15mph up to 6 and 25 mph up to 7 depending on gradient. I have found that by doing this way in a 158 you get the best torque, power and acceleration up to 55 mph when the fluid coupling takes over.
It is an instruction where I work and if you select notch 7 from start you will get your ear bent by a Traction Inspector. Notching up to 7 too soon is bad practice.
455 DSD are quite light & make a click, 444/450/456/158/159/442 just sound the viggy alarm as soon as the pressure on the microswitch is released, don't do anything within about 3-5 seconds, the emergency brake applies & you get a nice red flashing light on the TPWS panel & an embarrassing chat with the signaller!
Really? Nothing I've driven has had the DSD/Vigilance tied into the TPWS Brake demand light. On the units I've driven if you drop the DSD or fail to reset the Vigilance the brake will release as soon as the train stops. Interesting to learn that.
Training where I work is to select a low notch to fill the gearbox then to go straight to 7, with the train pretty much starting to move in 7.It is an instruction where I work and if you select notch 7 from start you will get your ear bent by a Traction Inspector. Notching up to 7 too soon is bad practice.
Until quite recently, Time Division Multiplexing was the standard method of controlling a propelling locomotive from a DVT or DBSO in the UK. This sends electronic pulses to the locomotive, in the case of the mark 3s via the lighting circuits.How is the rear engine controlled from the non powered front DVT / DSBO etc?
A driver of a long freight train may not be aware of any wheel flats in the consist once on the move. As carriageline has said, it’s much more likely that they would be identified from the lineside. Traditionally, a signaller in his ‘box would probably be the first to become aware of something, but with so few traditional signalboxes left now that’s no longer generally the case.When some freights pass near our house they have terrible sounding bogies, either like a rattley trolley or there's flat spots on wheels. How does a driver ascertain whether they are serious enough to stop a train and how would he know if there was a derail?
http://www.scot-rail.co.uk/page/WheelChex
WheelChex is a brand name for a Wheel Impact Load Detector (WILD) system used by Network Rail.
This line-side equipment measures the impact upon the railhead of each wheel of a passing train (eg, if it has a wheel flat), and provides details of all trains with wheel loads outside acceptable limits.
When an alarm message is generated by WheelChex, Network Rail Operations Control will identify the train involved and notify the signaller at the centre through which the train will shortly pass.
This will enable the train to be stopped at a suitable location for the driver to examine the wheel-sets concerned.
The train can then be taken out of service, or speed restricted to minimse the possibility of derailments or damage to track caused by wheel defects or overloaded vehicles.
Derailments, it's not been known for the driver not to realise for some time, mainly a loss of power or loss of air if a hose got ruptured! In some cases, the signaller probably sees all the track circuits stay occupied and points go out of correspondence where it starts chopping the cables!
Is there a minimum level of fault finding a Driver has to carry out before the train is declared a failure?
Laying dets and letting them off at 7.30am on a Sunday morning next to an expensive apartment block.
I would suspect I was about as popular as pork at a bar mitzvah!![]()
I can think of several incidents where a freight has derailed for a short distance and rerailed itself, all without any indication to the driver. As you say the only indication of something having gone boo boo is when track circuits and points unexpectedly fail.
One incident that sticks out to me is when a freight train derailed, damaged the track around a set of points near Reading in 2012, the wheels rerailed themselves and the driver continued for about 40 minutes unaware of what had happened. It was only when the signaller asked the driver to examine his train that damage was found to the derailed wheelsets! There's a full report on the incident here: http://www.raib.gov.uk/publications/investigation_reports/reports_2013/report022013.cfm
Easiest method to deal with DSD & Vigilance alarm is to move the power controller every few seconds.
We get about 2' to do our basic cab checks,such as line light,MR,BC,MA Ind.(455),MCB panel,Fault Panel (450/444),TMS (450/444/458), DSI light (455).
Stick your head out of the window & check for BIL or Hazard lights. Then use the GSMR & call Phone A Fiend for technical help if you can't find out what's wrong.
Last time I used it,I'd already diagnosed the problem before,he'd started. A knackered camshaft,being a single unit,I had to go for a walk and get assistance. Laying dets and letting them off at 7.30am on a Sunday morning next to an expensive apartment block.
I would suspect I was about as popular as pork at a bar mizvah!![]()
And plus, I would rather he rang us (signallers) first before ringing the Phone-a-friend line, and we have the means to patch them through anyway. Nothing worse for a train to sit down, and having no idea why! Although it really isn't unheard of for drivers to ring the wrong people first!
Sent from my iPhone using Tapatalk
