When coasting a train are you just cutting off the fuel?
Or is it similar to in a car where you have a clutch to disconnect the engine from the wheels.
Thanks
Can trains freewheel whilst "in gear", so to speak? Is it more like coasting a bicycle?
With diesel electric locomotives there is no physical connection as such, between the power source and the wheels. Unlike in a car, lorry or even diesel hydraulic locos such as the Western etc, there is no prop shaft or gearbox to link the diesel engine to the wheels.
Diesel electric locomotives have a diesel engine that is connected to a generator/alternator. This produces electricity that in turn, powers motors on the axles of the locomotive via heavy duty cables. Therefore, there is no 'gear' to speak of. There is a forward or reverse direction, but all that does is to select which way the motors turn; forwards or backwards. Thus, when a loco hauled train is coasting, all that is happening is that the motors are freewheeling and no power is being generated by the generator/alternator to power them. The diesel engine is still running, albeit at idle speed. This set up means that diesel electric locos can have diesel engines that run at lower speeds, rather than high revving engines of the kind found in cars, lorries, diesel hydraulic locomotives. For example, the maximum revs on a class 66 is 904 rpm. Compare that to a diesel powered car, which could rev out to around 5000-6000 rpm.
Diesel hydraulic locomotives and DMUs of the first generation variety, had diesel engines connected to the wheels via gear boxes, prop shafts and clutches. The engines had to rev higher to achieve the same effect that a diesel electric loco does at lower engine speeds.
