Recent DRS new loco tender result for new Class 93 locos
Royston Vasey
14 May 2008
Cambridge
Proper engines, but absolutely asthmatic in electric mode compared with any other new electric loco. They look a rather poor effort compared with Stadler’s EuroDual.
They're designed for double heading, says the article. Not a huge benefit over just buying an electric and a diesel but more flexible I suppose. Shorter freight still exists on the continent so it'll still find a place.
Skymonster
7 Feb 2012
As the Class 93 is now confirmed to be a Stadler design, spefications related Siemens Vectron based locos (including the article in Railway Gazette) are largely irrelevant to the forthcoming UK loco.
Royston Vasey
14 May 2008
Cambridge
Thank you so much for pointing that out. I thought for a minute I was on a forum.
43096
23 Nov 2015
So it's twice the cost (at least) if you're double heading. Shorter freight is very much a niche market, which is why the market for electric locos has gone for increasing power. Bombardier's TRAXX is often described as "medium power" (at 4.2MW continuous rating and 5.6MW one hour rating) and that's the basic minimum for any new electric loco in Europe now.
Harbornite
7 May 2016
Since when were you a forum moderator?
Royston Vasey
14 May 2008
Cambridge
Also, it is confirmed in which reputable news source or press release? Terribly sorry but I haven't seen one.
Photohunter71
17 Jan 2012
In a flat beside Niddrie West junction
Short formed freight, R.O.G, double heading?!!! I haven't seen short freights/enterprise workings since the 1980's early 1990's, and what is the point of that new locomotive that a fleet of 68's and 88's can't handle? I've looked on Railway gazette and nothing has been mentioned about tenders for a new locomotive or even a whiff of an order for new UK locomotives, is the source reliable?
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Short formed freight, R.O.G, double heading?!!! I haven't seen short freights since the 1980's, and what is the point of that new locomotive that a fleet of 68's and 88's can't handle?
ROG want a fleet of "go anywhere" locos - they currently run diesels under wires for a lot of miles. The 93s are also due to have special couplers to haul any UK unit.
krus_aragon
10 Jun 2009
North Wales
Any unit? That seems a lofty claim, given the plethora of incompatible MU systems we've had since privatisation. Even dead-hauling them all would require a versatile set of couplers.
Photohunter71
17 Jan 2012
Good point! And whose idea was it in the first place to have a plethora of coupling systems? One across the board would have been sufficient and common sense.
trash80
18 Aug 2015
Birches Green
I've often wondered this, seems basic common sense but maybe as a manager of mine once told me "DON'T use common sense!!" :P
Photohunter71
17 Jan 2012
Well, we should have stuck to hook and chain with buffers or the buckeye system. We didn't need dellner or any other coupling systems, that should have been made clear in tendering for new rolling stock contracts, talk about making a rod for your own back!
TRAX
2 Dec 2015
France
I hope this is ironic...
TRAX
2 Dec 2015
France
The Yanks use automatic couplers on their MUs, as it’s the only intelligent way of quickly coupling trains in the 21st century.
delticdave
14 Apr 2017
The only Do-Do locomotives I can find were French Steam-Electrics built in the 1890s. There were only three (including the prototype), and as all were scrapped, we can safely call them dodos as well. :)
Look further..... Search for the EMD DD40X diesels, purchased by Union Pacific. Unit No. 6936 is preserved in working order & often works with their steam fleet.
DC
krus_aragon
10 Jun 2009
North Wales
Hm. Its wikipedia page describes it as a D-D, rather than a Do-Do. Is there any material difference between the two?
USRailFan
2 May 2011
Norway
DC
There also were some SD45s built for Brazilian metre-gauge that had the same axle arrangement. Newer metre-gauge locos for Brazil (such as the "Dash 9" seem to have four two-axle bogies in groups of two instead.
ac6000cw
10 May 2014
Cambridge, UK
Americans don't use the 'o' suffix (to indicate individually motored axles, versus mechanically coupled axles with a shared motor) since 'individually motored' has always been the normal arrangement there. So what us Europeans would describe as a Do-Do they call a D-D.
There were also the earlier EMD DD35 and DD35X Do-Do locos (built for UP/SP in the US), but none of those survive - so they're definitely in the 'Dodo' category...
Photohunter71
17 Jan 2012
I go by the "If a system works and it aint broke, why try to fix it?" mantra. And you do not need a multitude of incompatible systems for drawgear, as I stated a few posts earler, common sense would be to have one uniform drawgear type across the board thus eliminating the need for special coupler vehicles between locomotive and multiple unit/hst, hence why some class 43's were retrofitted with buffer and chain-hook coupling. But I state again, the requirements should have settled on one specific drawgear type and incorporated that into tendering for new rolling stock. Anyway, this is off topic, so I'll get back on topic. Was there any mention of what diesel engine package was to be used in this proposed class 93?
TRAX
2 Dec 2015
France
What I don’t understand is how can you think manual coupling is better than automatic coupling where mechanical, electrical and pneumatic connections are made automatically and quickly just by pushing one train against another, without requiring any manual and time-consuming intervention before and after the process ?
Rob F
17 Dec 2015
Notts
I don't think anyone thinks that. What they do think is that is a bad idea to have a multiplicity of different incompatible couplers.
TRAX
2 Dec 2015
France
Well that’s not what I read but okay, on that I agree.
