Typhoon_93
67029 arrived at Aycliffe in preparation for tonight’s delivery.
Will more be coming north on Friday or was that path a precaution in case they werent ready to come north tonight?
Thanks in advance
Presumably 110 mph upgrades if Hynes is alluding to linespeed increases.
In general there are many significant drops in permitted speed between Bishopbriggs and Haymarket. It's 50 up Cowlairs, then up to 60, 70 past Eastfield then up to 85. The maximum of 100 applies from Bishopbriggs to the Falkirk Tunnel, then 95 through the tunnel, back up to 100, 90 over Polmont Jcn and through Polmont, back to 100 for a bit, then down to 90 again. 100 through Linlithgow, 80 MU 90 from Winchburgh Jcn to the tunnel, up to 90 all trains through the tunnel, 80 SP 90, then up to 100 right through Newbridge Jcn, through Edinburgh Park to just before Haymarket West. Down to 80/90 there, then 40 into Haymarket station.
So perhaps some of the 90 sections could be increased to 100, I'm not sure you could increase the limits out of Queen Street that easily.
As it says in #2186 one end is Italian and the other Belgian.Do we know if that is the Italian or Belgian solution, or indeed if they are different in approach (this one being an attempt to flatten the windscreen, the other possibly an attempt to correct the optics or some other trickery?)
I know that there are different solutions, but we don't know which one the pictured one is - that is what I was asking.As it says in #2186 one end is Italian and the other Belgian.
Is there not an issue with increasing about 90mph? I seem to recall discussions about the issues of running at 90mph but that they increase significantly if you wish to run at 100mph.
Those speeds raising to 100 / 110mph aren't likely to save you much time though. Raising the lower speeds higher however would probably be a more worthwhile investment.
In terms of braking and signal spacing I seem to recall the MML had speed limits raised (upto 125mph) because the braking of the Meridians was superior to the traction that had gone before and that they could stop in the same distance as older traction used to do. Perhaps some of this may be possible on the Scotrail network.
If that's the AWS sunflower still slap bang middle right, that's a pity.
I believe the pod you speak of is a cab air conditioning outlet. Traditionally such things were called ball vents but I do not know what the correct name of the modern equivalent is where you press one side and the vent opens.Its not the AWS sunflower - that is located on the dash next to the TPWS panel.
I suspect it is a pod for an in cab facing camera (no camera fitted and our Company Council reps will NEVER EVER even contemplate talks with the company over that issue. In cab CCTV is a red line that ASLEF wont be crossing) that has been fitted to future proof the cab. I may be wrong, but I firmly believe thats what the pod on the right hand side of the screen is for.
Sorry to say that it definitely is the air con vent, same design as on class 395 and class 800 series trainsdefinately not an aircon vent - it has glass or clear plastic on it
In the car parts world I've seen them described as "rocking vane air outlets".I believe the pod you speak of is a cab air conditioning outlet. Traditionally such things were called ball vents but I do not know what the correct name of the modern equivalent is where you press one side and the vent opens.
The same silly paranoia that went on when the GSMR was fitted. The little clear lens was a camera; to spy on you, to get you sacked bla bla bla. ...... it's the light sensor for the display brightness. <sigh>definately not an aircon vent - it has glass or clear plastic on it
I don't get the camera thing anyway. I'm a guard. All of my trains and most stations are fitted with CCTV. It's helped far more of us than it's hurt.
If your referring to the round black thing it's an air ventdefinately not an aircon vent - it has glass or clear plastic on it
