Speed Limits on Switches?
The Snap
10 Jun 2005
Hi guys,
I am aware that the smaller speed limt sign with an arrow (left or right) represents a speed limit on a diverging section of track from the main one (a switch). Is there a such sign to warn a driver that this speed restriction is coming, incase he is to slow down to obey it? (Like the yellow triangle?)
Thanks,
Jordy
9 Jun 2005
WCML South
I do believe it is a yellow triangle with an arrow - but I may be wrong
Jordy
wumpty
20 Jul 2005
Deepest Darkest Brum
Hi Rich,
The most common way to warn a driver of a route diversion is by signal approach control.
This can be seen in the Maybank BVE4 route. The signal before the junction is fitted with a route indicator (or feather). You can code the signal to stay red by placing a dummy station stop at approx 100-200m before the signal. Then the driver is forced to slow down for the red, which will clear as you run over the dummy station, lighting the feather and the train is going at around 15mph, slow enough to navigate any divergance.
This is the dummy station before the turnout at Radley Junction
27960,
.sta ;10.4250;10.4250;;1;1;ATS,
.Stop 0;0;0,
Set the times as exactly the same, at a time prior to the time the train arrives at the point, or else the signal may take ages to clear.
HTH
The Snap
10 Jun 2005
Cockfosters said:
They're not switches, they're points!!
Everyone else seems to called them switches, I've always refered to them as points though... LOL! :D
The Snap
10 Jun 2005
wumpty said:
Hi Rich,
27960,
.Stop 0;0;0,
HTH
Cheers Steve, I think it's you anyway, LOL! :D
Techniquest
19 Jun 2005
Nowhere Heath
I nearly posted 'turnout' when referring to 'points' recently, so you're not the only one using US terms. Maybe we've all got MSTS on the brain (THAT'S why I have a headache then, lol :lol: ).
Thank you wumpty, by the way, for explaining the signal-controlled junction approach. Don't suppose you know why the signals insist on being double-yellow off Riverside (on the HST service), then single after the next station (Kings Road?), then red before the next one? Surely if it's a HST service, it should be routed as fast as possible, not constantly being slowed after Riverside? Tis well annoying, always knocks my arrival into Hammerwich off by 2 minutes or 3.
