Welcome to communist China... *shudder*Stations could quite easily capture facial recognition at entry points and scan at exit, that way you wouldn't need gate lines at all and people could just leave the station.
Again thats only an issue if scanning from the PDF where it isn't formatted well. Scan from Wallet or directly in the app and you don't need to worry about it being aligned, its in a predictable place on the screen.
My point was a bit off-topic in that it referred to card vs phone generally. It is not always as simple as just paying, the issue is complicated with loyalty schemes etc which require you to pay with (or alongside) an app.That depends entirely on the phone, and how it is held.
That's exactly the same issue with ticket, Oyster cards, ITSO cards and contactlless (Bank Card) transactions. Passengers decide to get whatever form their ticket is in when they get to the gate rather than approaching the gate. Personally, unless both hands are already in use, getting a card wallett out of my pocket and presenting the ticket to a reader. A phone is something different, it will need the login screen to be woken up, a PIN entered, the ticket application opened, and the ticket loaded onto the screen before presentation. Those who think that phone based virtual tickets are faster need to consider how long many others take to pass through and not assume that everybody should be as fast as they are.It's people that go right up to the gateline, stop dead, then get their phone out and find the relevant app/ticket.
Phone in hand, ticket on the screen, brightness up well in advance, I'm through just as quickly as a paper ticket.
Which supermarket app contains adverts for lingerie?My supermarket used to send me paper money-off vouchers by post. At the checkout I would toss the cashier the three or four I wanted to use together with my physical loyalty card, and they would scan them all in about 3 seconds. Now they are all on the supermarket's app, and even if I approach with my phone as ready as possible, with the app open, I must scroll down the list of my vouchers for each one I want to use, and for each one : select -> enlarge for the QR code -> show the cashier for them to scan -> press back arrow to return to the list -> select next voucher -> rinse and repeat for each voucher .... On top of this, the app on the tiny touch screen is a deliberate minefield of side-tracking advertising links, so if I slightly miss the icon for a voucher I end up with a sceen of ladies lingerie bargains for example.
I thought all the gateline scanners are camera based? I've never had a failed scan on either station on my normal commute. I've used a mix of Greater Anglia app, Virgin tickets app, Apple Wallet and direct from the email PDF (once when I couldn't make an app work), never had the brightness issue. There are no red lasers so I assume they are camera based, but its possible other stations are different (I've only done eticket at three National Rail stations).Though fiddling with the brightness is not unusual to be needed. Some apps automatically increase it, but not all do and not on all phones.
That isn't as necessary with camera based scanners.
However, the delays are far outweighed by passengers who feel the need to wait for the ticket gate to close after the last passenger before presenting/inserting their own ticket.
The risk with closely following another passenger is that their ticket may be declined by the gate. If you've already inserted/scanned your ticket, that will open the gate, the passenger in front will pass through, the gate closes, and you're left on the wrong side with a closed gate and no way of reopening it. It's happened to me (with a paper ticket which was swallowed by the gate). Fortunately the gate line attendant accepted my explanation and let me out.What does slow down progress is the passenger who won't tap on until the gate has shut after the passenger in front.
That does not necessitate waiting for the gate to close.The risk with closely following another passenger is that their ticket may be declined by the gate. If you've already inserted/scanned your ticket, that will open the gate, the passenger in front will pass through, the gate closes, and you're left on the wrong side with a closed gate and no way of reopening it. It's happened to me (with a paper ticket which was swallowed by the gate). Fortunately the gate line attendant accepted my explanation and let me out.
I didn't say it did. I was offering a reason why passengers might be cautious in following closely behind others - as I am now.That does not necessitate waiting for the gate to close.
With iPhone there is no noticeable difference between tapping the phone and tapping a bank card, it’s designed for the job and Apple manages the applications running to ensure Apple Pay is prioritised.Yes I have certainly noticed this. I think also the fact there is added latency when using a phone is due to the amount of cruft people have open (and slowing the phone down) as well as the multitude of places in which the NFC antenna is in relative to that on the reader (and the user's ability to place it on the right area) have an effect to get a successful and timely read.
I've always found a purpose designed device (like an NFC card such as a bank card, oyster etc) presented to the TFL yellow pad gets a timely response. It's designed for the job with its own software and hardware architecture.
I do exactly the same.When using contactless I always pause until the gate starts to close before touching, it gives me the confidence that my tap in has been registered. A friend had a maximum fare when he was too hasty rushing through the gate when there was a crowd of passengers.
Well, at station gate lines/ticket inspections I hardly have to break step when presenting a CCST ticket whereas anything reading a QR type code (be it the gate or a manual check) requires people to stop. QEDThey're really not.
Of course, paper tickets never get rejected or take two goes...And even when it works smoothly, it is a slower process than inserting a paper ticket.
Of course they do but their higher average speed has resulted in LU keeping them longer than they might have otherwise. Phones using nfc are about the same as contactless cards, but optical recognition is slowest of all.Of course, paper tickets never get rejected or take two goes...
I’m sure this was meant lightheartedly- unfortunately the “argument” it is using is trotted out every time someone questions the form or direction of that progress. There are many ways in which the move towards alternatives to the traditional cardboard ticket is indeed progress. Speed of exit/entrance through gate lines is definitely not one of them - at the moment at least.Those steam trains were brilliant. Don't know why we have to progress.
Good practice. With Oyster Card I am not reluctant to tapping before the gate is closed because it will show the balance / fare of the journey, which is the indication MY card is being recognised.When using contactless I always pause until the gate starts to close before touching, it gives me the confidence that my tap in has been registered. A friend had a maximum fare when he was too hasty rushing through the gate when there was a crowd of passengers.
This is just bad app design.My point was a bit off-topic in that it referred to card vs phone generally. It is not always as simple as just paying, the issue is complicated with loyalty schemes etc which require you to pay with (or alongside) an app.
