- Joined
- 15 Apr 2008
- Messages
- 16,210
Or you could re-time the FGW or SWT and make a connection and make all that a fairly moot point.
Given Exeter to Plymouth via Okehampton is about 60 miles along the old route, assuming that trains run at the same speed as Exeter to Barnstaple (which is about 40 miles) then a journey time of about 90 minutes would seams about right for the reopened route.
The trains from Exeter to Plymouth currently take about 60 minutes, however leave with in 3 minutes of the Waterloo train coming in (making a connection nearly impossible) or about 20 minutes later (although is some cases this can be up to 50 minutes later).
Therefore IF SWT's were to extend their services most people would probably carry on to Plymouth on them rather than change as they would already have a seat, and they would at best only be getting into Plymouth 10 minutes faster
I catch the SWT to Exeter quite a lot and have only missed the onward XC to Newton Abbott maybe once or twice out of a couple dozen trips, it is a cross platform transfer and takes 30 seconds tops.
If you call the case for reopening a route which:That seems a very complicated expensive "solution" to solve the "problem" of tight connections at Exeter (dunno how many passengers an hour make that connection). I'm all for re-opening lines with a good case, but a lot of the justifications being trotted out on here for Okehampton are fairly flimsy.
Given Exeter to Plymouth via Okehampton is about 60 miles along the old route, assuming that trains run at the same speed as Exeter to Barnstaple (which is about 40 miles) then a journey time of about 90 minutes would seams about right for the reopened route.The trains from Exeter to Plymouth currently take about 60 minutes, however leave with in 3 minutes of the Waterloo train coming in (making a connection nearly impossible) or about 20 minutes later (although is some cases this can be up to 50 minutes later).
Therefore IF SWT's were to extend their services most people would probably carry on to Plymouth on them rather than change as they would already have a seat, and they would at best only be getting into Plymouth 10 minutes faster.
Even from Basingstoke getting to Plymouth via Reading would only be about 25 minutes faster. Which isn't a lot of time, and if ticket prices were less then some people would still use it as a preference.
The problem with it being run as a Exeter-Plymouth service is that there are limited paths through Exeter, meaning that as it would result in two paths (one for the Waterloo service and one for the Exeter Plymouth service, both of which would have their end point in Exeter) through Exeter may mean that other services may not be able to be increased (i.e. Exeter to Exmouth may have to stay as 2tph rather than be able to increase to 3tph). Yes there are ways around that (e.g. Exmouth to Plymouth services), but then there would be less through passengers as it is likely that the change times would be better at Exeter (at least for some services) and it would be a smaller catchment.
- Is already subject to a reopening proposal due to congestion at one end
- Has serious aspirations for reopening at the other end for reasons of economic development
- Avoid the two above mentioned projects being left as dead end branchlines, with all the implications for connectivity and future sustainability that implies.
- Would massively increase the resilience of the West Country network as a whole (something clearly wanting, since on no other major corridoor would a blockade of potentially several months be seen as acceptible
weak, then I'd sorely love to see what your idea of a "strong" case would be.
Certainly (as you've admitted in other threads) redoubling schemes don't really cut the mustard.
Would the journey time would be 90 minutes? I have a book by O.S.Nock which gives details of a run from Plymouth North Road to Exeter St Davids in 79 minutes,a heavily loaded train hauled by a Battle of Britain class locomotive.I'd have thought that more modern traction and engineering techniques could knock quite a few minutes off that time-the LSWR route wasn't really that much longer than the GWR,57 miles compared to 52.
Resilience? The Dawlish route has been open over 99% of the time in recent years (going by the figures provided by Goatboy), which probably compares reasonably well with other lines. Where was the demands for a new line from Chester to Holyhead when the North Wales coast line was closed recently? Is that not a "major corridor"? Does it depend on whether there was an alternative line closed by Beeching?
What would be a strong case in my eyes? An electrified route from Exeter to Waterloo, double track throughout? Just a suggestion.
The point here surely is that there is a viable alternative route that was closed, is largely intact, and would be useful in its own right. (And no, Holyhead-Bangor-Afon Wen-Portmadoc-Birmingham-London is not comparable).
Indeed - and it should be done. Since the 750V DC is going to be replaced over time, you may as well make the whole lot 25kV AC whilst you're at it.
Conversely, I think a Dawlish avoiding line could end up worse for those living in Torbay as it would possibly sound the death knell for the line along the coast, which in turn would mean loss of the local stations and services, particularly if the wall gets breached too often. At least with Newton Abbott and Torquay depending on it, they're obliged to keep services along the coast.
... but there is also a (reasonable?) expectation that there will be more frequent, more destructive storms in future, ..
Eh? Sorry, I don't quite follow that. A Dawlish Bypass would speed-up travel between Exeter and Newton Abbot (and Torbay beyond it). Why would that be worse for those living in Torbay?
[/url]
Dead end branch lines? In which case we'd need to worry about the "connectivity and future sustainability" of most lines in Cornwall (as well as the Welsh Valleys etc)
Serious aspirations for reopening at both ends? Good luck to them, but let each end be dealt with on its own merits, rather than this pretence that a slow meandering route through the moors (serving relatively low populations) is a solution to getting a sturdy route through Dawlish. There are proposals for reopening virtually every bit of railway closed in the Beeching era though - this doesn't elevate the Okehampton scheme to the top of that list.
Still betting that in 3-6 months time this will be dead and nothing comes of it.
Perhaps if it had a City the size of Plymouth, as well as its various seaside towns. Also, if there is an alternative to that route, does it have any towns such as Tavistock and Okehampton likely to generate trafficalong its way ? You can pretend to yourself that Dawlish is exactly the same as any other stretch of line in terms of exposure to severe weather, but I can't see many people being taken in
With the exception of Gunnislake all of the branches end on the coast, so there aren't that many travel opportunities beyond the various termini (except perhaps for fishermen). However, it seems patently obvious that a fully integrated through route is likely to generate more usage and establish itself as an important transport node than a series of branch lines
And how is that a stronger case exactly.
- Faster and more frequent services for those that already have them, but how much greater is that need for towns that already have a relatively fast and frequent service than for towns that have no service.
- Increased resilience for a route that already has, and uses a diversionary route, or resilience for a route that currently has none and will be out of action for six weeks at the moment.
Your suggestion fails miserably in comparison to the Okehampton route in all respects, except possibly one. It might be cheaper. That is the entire basis of your argument.
We can always find something cheaper that could be worth doing at some stage, but unless someone has the vision to instigate something that may be more expensive but will provide a vast improvement to travel opportunities we will be left with a network designed for the 1970's that doesn't meet the aspirations of today's travellers
Latest 'news'. The price seems to have gone £700m now - no idea where that has come from. I do not think Dawlish has received as much attention from a British PM in its whole history - it couldn't possibly be anything to do with the number of Con / Lib Dem marginals in the South West could it? Lots of 'floating' voters if you pardon the pun.
What started off as a simple diversionary route has now electrified from Basingstoke to Plymouth and converted the while Southern Region to 25KV overhead electrification!
Maybe bad weather will close the Dundee - Aberdeen line for some periods in the future - the cliffs by Stonehaven may be susceptible to problems.
I've already mentioned the North Wales coast line. Plenty of other coastal lines have no diversionary route.
Towns such as Tavistock and Okehampton? Small towns. With a combined population of around 20,000, there are much bigger places without connections to the national rail network.
You're going to have to try harder than "we can't just open from Plymouth to Okehampton because branchlines can't work". Of course a through route would carry more passengers, it would also cost a lot more money - money that could be invested in other things.
Cost benefit analysis.
If the two schemes cost the same (I have no idea, but for argument's sake...) then you'd have to look at which one benefits the most people. Would an upgraded line through Yeovil Junction benefit more people than a reopened line through Okehampton (pop 5,756)?
You're falling into the trap of coming up with the answer that you want ("reopen something that was closed down fifty years ago") and working backwards to find justifications rather than trying to find something that gives the most benefit for the money available.
http://www.westernmorningnews.co.uk/Cameron-promises-high-profile-HS2-rail-built/story-20614543-detail/story.html
Network Rail has said reinstating the most expensive cross-country Westcountry rail line would cost £700 million a fraction of the £42 billion to be sunk into HS2.
As has been pointed out on many occasions, Tavistock already has a well advanced reopening case and Okehampton are looking to increase their existing services. Whether it be from the towns themselves or the local hinterland, there is a demand for a decent rail service in this area.
The Prime Minister, David Cameron, has today confirmed that the £31.1m promised to improve the resilience of the South Wests rail network will be found.
Ten projects to improve the rail networks resilience against flooding will be funded with the money including for work in Honiton, Cowley Bridge Junction, Crewkerne and several other areas of rail vulnerable to potential flooding.
Yes, but they don't all have Plymouth at the end of them
as you are well aware (and choose to ignore), Dawlish has been breached on a number of occasions, including the very first year in which it was built
This is why there needs to be more of an emphasis on serving new communities in the railway
It's not just a simple case of what assists the most people, it's about how much help can be provided. Say upgrading a line assists 400 people to get where they would have been travelling anyway five minutes earlier. What if building a new line costs the same but helps 200 people. By your methodology, the upgrade should be the greatest benefit. But what if the new line provides those 200 people with better job and educational opportunities and increased business. The opportunities afforded to the 200 are going to be much more valuable in terms of generating economic activity than the five minute journey improvement for the 400. This is why there needs to be more of an emphasis on serving new communities in the railway.
http://www.theplymouthdaily.co.uk/news/local-news/£311-million-rail-resilience-will-be-found
...sounds like "money is no object" but there's no £700m for an Okehampton route. Basically, there will be no Dawlish avoiding route - thread closed?
Plymouth Daily said:Second point, while we are working as fast as we can to restore the Dawlish link, we do need to look at longer term alternatives – and I have discussed this with Network Rail and First Great Western – to see what more can be done.
Western Morning News said:Network Rail has said reinstating the most expensive cross-country Westcountry rail line would cost £700 million – a fraction of the £42 billion to be sunk into HS2.
