TFW Stock Shortages
berneyarms
26 Nov 2013
Dublin
There are no politicians in Westminster currently but there are still civil servants working at the DfT. Parliament has closed, Whitehall hasn't. Grant Shapps is still the Transport Secretary until December 12th.
So I'd expect a decision to be made and TfW informed of the decision, but a public announcement not being allowed to be made until after December 12th.
So we don't know if TfW's Pacers have been given derogations, I read in one magazine that the Mk 2's have derogations in place though
Actually he’s still Transport Secretary until a new government is formed - if it’s a hung parliament that could take longer!
craigybagel
25 Oct 2012
The North Wales MKIIIs were a 175 today. The DVT went down to Canton without the rest of the set on Saturday evening so I'm assuming it's still down there getting worked on.
13 Feb 2011
Cardiff
Sion John
4 Jul 2018
Llanelli
Thanks for the info, hopefully nothing too bad happened...? It's like the TfW launch-wrapped 175s are cursed - 175107 had an engine fire and 175003 derailed...
Yep all ok now tho but i don't know when 003 will be in service but its on the rails tho
sefyllian
14 Jan 2013
The TfW rolling stock situation was debated in the Senedd today, following a Plaid Cymru motion that “… regrets the Welsh Government's failure … to take appropriate action to address the issues highlighted as long ago as 2013 in relation to rolling stock …” (though the motion as passed was amended to remove the criticism).
Some fairly knowledgeable and cogent points, to be fair.
Interesting that TfW have told Hefin David AM: “We expect to have the written approval regarding the derogation before the end of November.”
Read the debate here or watch here.
anamyd
17 Aug 2018
Thanks for informing :) https://www.senedd.tv/Meeting/Clip/c77e4950-bc37-4652-8229-7b850ffb6570?inPoint=03:22:08 for the English version, clipped
20 Nov 2019
Merthyr Tydfil
Are 170s capable of operating coupled to 175s? If so then when they have begun service with TfW that could be a short term solution to overcrowding on the Cardiff- Manchester/ Holyhead routes. Even if they can't they'd still be a much better option for the Welsh Marches route when 175s are unavailable.
Sorry if this was the wrong place to post this. Just a thought I had.
Rhydgaled
25 Nov 2010
Class 170s have worked in multiple with class 153s and class 158s elsewhere, so I'd say that they can't work with 175s (as Sprinters can't). You could in theory run 170+158 on the Manchesters but would the drivers being trained on 170s sign the route? In any case the Cardiff-Holyhead services are only planned to get 2.5 coaches of standard class capacity in this franchise as far as I can make out (mark 4 TSOE+TSO+RSO+FO on some services and 3-car Civity with first class section on others).
I still think they ought to work Welsh Marches services when 175s are unavailable. I'm tired of seeing 150s heading all the way up to Holyhead
Aren't we all tired of 150s standing in for long-distance stock? Not just the marches but other long-distance routes too.
But why would you need the same couplers as a 175? If the reason you want 170s on the marches is because of a shortage of 175s, there wouldn't be a 175 for the 170 to couple to anyway. Just send a 170 out as cover instead of a 150; no need for it to couple to anything. The first choice (booked traction) for the long-distance services has to be a LHCS set, a 175 or a 158. If there are none of those available then the next best thing available is probably going to be a 170 so using a 170 would be preferable to a 150 standing in. Route/traction knowledge will probably dictate that this doesn't happen though.
PHILIPE
14 Nov 2011
Caerphilly
What will work the Maesteg to Cheltenham an Ebbw Vales then. Some of those are currently 175s so they would be freed up.
20 Nov 2019
Merthyr Tydfil
The reason why I was asking about them being able to couple together was because it may be a way to double the amount of carriages on services that are sometimes overcrowded. Although as you say, it's probably unlikely to happen due to traction and route knowledge.
craigybagel
25 Oct 2012
At the moment, only Cardiff crews will be signing 170s so they won't be able to work North of Crewe/West of Chester in place of 175s.
I would have thought there's no hope of them ever being compatible with 175s. Even if the 175s weren't leaving in a few years time the job would probably be more complicated and expensive then it's worth - it's not just the couplers that need changing, but the way the power/brake controllers are set up is completely different. I also suspect the TMS computer system on the 175 would go crazy if asked to talk to the 170. Not going to happen.
anamyd
17 Aug 2018
Fair enough. Would it be too costly to fit them with different couplers like Southern did with the 171s?
170s don't have a modern computerised TMS like 175s (and that TMS is only programmed to recognise 175s and 180s) and 170s also have the extra power and brake steps required to work in multiple with 2nd generation BR DMUs (like @craigybagel says) so even with Scharfenbergs instead of BSIs they wouldn't be able to work with 175s
20 Nov 2019
Merthyr Tydfil
Are the 170s still planned to operate Heart of Wales services eventually? If so then at least that'll free up more 150s/ 153s for the Valley/ City lines.
anamyd
17 Aug 2018
In 2022 supposedly, but there are doubts about them getting cleared for HoW. Even if they did, it would be 2022 so all or most of the Sprinter stock would be gone or be going at that point, although the new stock would also be in the process of introduced
