I've seen them pressing the button before the train has stopped when when there is a five plus minute booked stop.I guess it also depends on how long the train is gonna be stood at the station for.
That said people who actually jab at them like they're playing a 1980s video game are the S&T's worst nightmare - where I used to work had an older relay based interlocking and despite continued warnings some members of staff just used to jab the buttons which produced no effect whatsoever in the PSB, then report them as faulty. It doesn't give enough time for the relay to pick, which is why they say 'press and hold for at least x seconds'.
Pressing it multiple times gives no more than one indication for one train on the panel or workstation anyway, unless you're dealing with particularly vintage kit (we have it at Boston) which will just buzz like a demented mosquito repeatedly and irritate the signalman.
I was always taught to hold the button/switch for 2 seconds, 2 minutes before departure, as a matter of fundamtental route-learning principle for required locations. It's a shame this (or any local variant) is perhaps not taught so clearly as a rule elsewhere.
There's not a lot of consistency is there. None of the ones on routes I sign need a key, they're all buttons. They have varying instructions on the length of time you have to press them for, or often no instructions. There is one which you have to press for at least x seconds but not more than you seconds, I can't remember the exact figures off the top of my head! Some will light up to indicate they've operated, some don't. 2 minutes before departure is the general rule for the time to operate them, but at some locations you have to press it before that to allow for level crossings to operate. And the TRTS at Chessington South gives the signal as soon as it is pressed, and it is acceptable to press it as soon as you arrive, even though that's 15 minutes before departure. Some very usefully don't state on them which signal they apply to, or just state the signal number and not direction, which isn't always much help on a bi-directional platform where the signal numbers don't follow a logical sequence.
At one of our locations we have "donkeys dicks" with the TRTS buttons on rubber poles extended up to cab height, accessed by leaning out of the driver's window. Really awkward/stiff to push but a light illuminates to confirm the indication has been sent to the signaller.
Will not do any damage, just won't get you anywhere faster, like button controlled pedestrian signals on roads. If the buzzer keeps going off as at you say it does at Boston, then that's not going to get you on the right side of the signaller!
The 2 seconds hold in advice is more to cater for slower acting electronic systems such as SSI which react to inputs more slowly than relays, which can be virtually instantaneous. SSI does a repeating sequential scan around all its input module address on the particular trackside datalink subsystem, taking about a second or more in total. A 'quick jab' and release on the button could very easily miss the particular input's allocated time slot in the scan, so it will be missed.
Would it be fair to say that TRTS buttons at stations are used more as 'Train Rolling To a Stop' than 'Train Ready To Start ' these days? I often see platform staff jabbing away at them before the doors are even open.
At a couple of places I regularly work, the TRTS isn't a button or t-key switch (usual) but another type of key-switch, for a specialist key only held by platform staff. How common is this?
Aha! You say that, but one of our new SSI interlockings has one of the fastest interlockings I've ever worked, on either workstation or panel! It's very close to being instant! But they don't use trackside modules, but something called object controllers + zone controllere. And they use IP addresses too! Clever kit to be honest.
In that case it's not strictly a SSI, but one of the newer Computer Based Interlockings that has some SSI compatibility. Some of these still do use the SSI trackside modules, but if so they would be constrained by the SSI cycle timings which as suggested above will only scan an indication every second or so. Which wasn't bad in the 1980s when SSI was first introduced, but is looking a bit slow compared to the computers of today!
Do they get pressed for one long press or are there various "bell codes" used?
They only register once, illuminating a light on the panel or VDU equivalent. The ones I have seen stay lit until the signal is cleared so there is no scope to use them for more sophisticated communication.
Agreed - if a TRTS button was pressed in error, then a route had to be set, the signal clear and then the route cancelled in order to extinguish the TRTS indication. There was no other way.
Perhaps it would be a useful feature to have a cancelling button on the platform as well. That would avoid the time delays inherent in unneccessary route setting and cancelling (thus allowing the TRTS to be used normally again easily once the train really was ready) The cancelling device could also be used as an emergency signal replacement as well, if operated after the signal had cleared, say if the platform attendant noticed someone or something caught in doors or trapped between train and platform for instance.
