Unsettling Rumours about Kings Cross suburban platforms
SprinterMan
20 Sep 2010
Hertford
I heard a rumour doing the rounds at work a few weeks ago that once the Thameslink Programme is finished, platforms 9, 10 & 11 at Kings Cross are going to be demolished and replaced with shops. Does anyone know if there is any truth in this?
If true, then it seems remarkably short sighted. These platforms will still be perfect to handle an 8 car 700 or 6 car 717 during times of disruption, and an 8 car 387 or 365 for scheduled services. The main platforms at KGX are going to get busier with the introduction of more VTEC services and the arrival of First East Coast, so in times of disruption on the Moorgate branch it will leave them fewer places to turn trains back.
Adam :)
me123
9 Jul 2007
I certainly haven't head about this, but it would seem unlikely and very short sighted. In addition to the above, the three platforms at KGX would provide room for potential further growth on services on the Great Northern routes. I don't know if there's plans to run the 800s and 801s in five car formation, but the platforms would seem ideal for them if that was the case. And, of course, the 180s used by HT and GC, and indeed the 802s that will replace them, can also make use of the shorter platforms.
Besides, Platform 9 3/4 must be of some literary significance and probably drives quite a lot of non-travellers into the station (and, consequently, its shops which leads to £££). To have a 9 3/4, you surely must need to have a 9 and a 10.
Failed Unit
26 Jan 2009
Central Belt
I had heard about redevelopment so not overly surprised.
Remember that platforms 10 / 11 are not really fit for purpose so making the 1 decent platform would be an improvement.
I think if they did Kings cross would cope. Some of the dwells are over 1 hour, will this be acceptable on the 2018 timetable or will the services of less than 2 hours be turned in about 30 mins.
As for disruption it will be a bad day to lose Thameslink and Moorgate at the same time. I Moorgate service will not need the platform for long. If wouldnt be ideal but I am sure kx could cope with 9 platforms. (Not saying I think it should however.) perfect work for me is as I understood merge 10 and 11 to a larger platform with more space.
Simon11
7 Nov 2010
:lol: Got to be a first in terms of a reason of wishing to save the platforms!
The OP seems to be suggesting that all three platforms will be lost, whereas others are suggesting that one platform will be lost in order to lengthen the other.
I suppose it's worth noting that 11 has already been filled in and dug out once before !
The Ham
6 Jul 2012
In which case put shops outside of the gate line along with a fake platform 10, that then gives the shops lots of access to tourists and allows said tourists access to where they want to be. Problem solved and you create a draw making the shops even more attractive.
If this does happen would it be the biggest loss of terminal platform capacity since Bond Street?
Edit: Yes, I did mean Broad Street. (Keep reading, you'll see what I mean...)
SpacePhoenix
18 Mar 2014
Is there enough height in that area of the station for a mezzanine floor for them to do something similar to what was done at Waterloo?
Peter Mugridge
8 Apr 2010
Epsom
I think you mean Broad Street? Though I wonder about Holborn Viaduct given that the service level at Broad Street wasn't particularly high towards the end - Holborn Viaduct, while physically smaller, certainly had a greater throughput.
Of course, Holborn Viaduct's capacity wasn't really lost - simply diverted into the Thameslink core.
Clip
28 Jun 2010
No room there for one unless the extended the roof upwards
Cherry_Picker
18 Apr 2011
There is always always always a lengthy queue of people waiting by the platform 9¾ sign to have their picture taken. I'd guess it's probably half an hour or more on a normal day, I dread to think what it's like during the school holidays. The platform is definitely a significant draw of business into the station and I'm sure they are considering what can be done with it ahead of any redevelopment.
GNER 91128
13 Jan 2011
Peterborough
Wouldn't it make sense to take out two of the platforms so one can be extended and become full length and able to take IC trains as others suggested? It's a shame only one would be able to be kept but obviously extending means taking out a lot of track and point work and there's not exactly a lot of room until you reach the tunnel mouth. Although things could be made easy if they started using the tunnel bores over on the platform 0 side, I guess anyway.
I would have thought you'd only need to remove 11 to extend 10. 9 you probably wouldn't be able to extend, but then I don't see why you would need to decommission it either.
There'll be more than enough 'short trains' to occupy P9-11 in the medium term, notably the HT 5 cars just confirmed ordered, and the GC all 180 fleet by next year some time, etc etc. What about the First group Edinburgh open access service, anyone know what length trains they are aiming for? Then there's all the ECML 5 car IEP possibilities to new destinations, such as Middlesbrough?
Hopefully the GC all 180 fleet will be delayed by a couple of years.
lineclear
29 Mar 2016
I wouldn't pay too much attention to the railway rumour mill. The existing platform 10 will be abolished and the existing platform 11 will be renamed platform 10. Platform 9 will be extended.
Failed Unit
26 Jan 2009
Central Belt
Won't resignalling whenever it happens result in platform 0 getting renumbered to 1 and then all existing platforms up 1. Ie 1 becomes 2 etc. Saying that if I recall said resignalling is a few years off yet.
Wolfie
17 Aug 2010
Sent from my Nexus 4 using Tapatalk
Do you mean Broad Street by any chance?
Oops...sorry for reopening something done to death..
lineclear
29 Mar 2016
Apparently not!
The remodelling (which is very extensive) is part of the resignalling/ETCS scheme. It's still at GRIP 3 though, so things could change.
IanD
18 Sep 2011
Newport Pagnell
About 3 people waiting the last time I went past. They've moved the half trolley once, I'm sure they can move it again.
Why? There's no sign of any delay to them getting the GW 180s AFAICT, they have them all on lease from next month, but four of the five will be subleased back until the first IEPs enter service during 2017.
GrimsbyPacer
13 Oct 2014
Grimsby
If platforms 9, 10 & 11 are demolished to make way for shops...
Can't they rename platforms 0-8 as 1-9 so as to keep the tourism boost from Harry Potter fans?
Clip
28 Jun 2010
Got the midday last wednesday and the whole queing system thing was rammed and spilling onto the concourse for some length.They must make a fortune from that shop too .
The longer they sub-lease them, the better AFAIC.
muddythefish
13 May 2014
Operational flexibility or the chance for NR to make money through more retail outlets? Goodbye platforms 9-11.
