WCRC has shown on numerous occasions that it is a cavalier company and should be permanently banned from running on mainline railways in the UK.
@ All
There is a specific problem with rail traction, in that if a train/tram breaks down, it cannot usually be overtaken and almost invariably causes an obstruction, unlike (in general) a bus/lorry/car, although the latter can occur (as a schoolboy I was on a bus that managed to break down on turning right at a road junction and blocked most of the junction). This is one of the reasons for the closure of most tram systems in the UK in former times, a trend that continues elsewhere in the world, e.g. in the former USSR. As equipment ages, it is more likely to fail (not that this can't affect badly designed new equipment as well) and engines in particular are extremely complicated.
The effect of a train failure on a busy main line can be very disruptive, so it makes sense to restrict access by all steam and first-generation electric/diesel trains to mainline railways. I am not proposing a universal ban, but before exemptions are granted, there should be stringent tests before such equipment is allowed to be used where it could disrupt public services. WCRC has shown on numerous occasions that it is a cavalier company and should be permanently banned from running on mainline railways in the UK.
This is a railway enthusiasts forum. Please cut the condesention and start with the assumption we have actually seen a railway before and understand how it works.@ All
Whilst this is the general rule, that older equipment can be expected to have more wear and tear and thus be more prone to failure, this is a very gross oversimplification. Some engines, even 50-100 years sold are so well maintained that they are more reliable than so-called "modern" equipment.As equipment ages, it is more likely to fail (not that this can't affect badly designed new equipment as well) and engines in particular are extremely complicated.
again, we know what a railway is. Going to go out on limb and presume there are others who understand better than you do.The effect of a train failure on a busy main line can be very disruptive, so it makes sense to restrict access by all steam and first-generation electric/diesel trains to mainline railways. I am not proposing a universal ban, but before exemptions are granted, there should be stringent tests before such equipment is allowed to be used where it could disrupt public services. WCRC has shown on numerous occasions that it is a cavalier company and should be permanently banned from running on mainline railways in the UK.
Seems a bit of a panic merchant response to a hot axle box. As has been said numerous times, it can and does happy to stock regardless of age.
Nobody is disputing that, but it's a huge jump from 'we need to see if this is symptomatic of maintenance issue at WCRC' to 'all stock over 50 years old should be banned immediately'.
A hot box can seize which locks the wheel. The wheel can then break up causing a derailment. So a hot box is serious and needs detecting and stopping ASAP.
Please cut the condesention and start with the assumption we have actually seen a railway...
I get really t’d off with the constant witch hunt against WCRC on these forums especially with comments on things that they have little understanding of.
In regards to the hot box incident, this is not totally predictable – look up Weilbull Distribution on Wiki. Most maintenance outfits, WCRC included, use the predictive method of time/usage for replacement of items just like you change the cambelt on a car after a predicted number of miles. However, other items can and do fail at any point on the Weilbull curve. My wife’s VW 1.4 Polo had a rear wheel bearing collapse at 10k miles whereas my son’s VW 1.4 Golf has done 143k miles and frequently tows a 1500kg trailer and has had no problems.
Modern stock, such as the Pendolino, has condition based monitoring where sophisticated electronic systems are used to monitor the state of bearings etc which identify vibration, acoustic or temperature changes over time and then indicate to maintenance or operations personnel (usually) before a failure occurs so that they can be changed during the next scheduled maintenance. These systems are expensive and suit the fixed formation of EMU/DMU but would be more difficult to manage on heritage stock that is frequently split.
As with the broom example, coach bogies are refurbished and swapped – WCRC has lots of spares from scrapped stock (parcels etc) and all stock has specified inspection dates based on BR practice.
All stock should be banned from running on railways/tramways providing a licensed public transport service if more than 50 years old, due to inherent unreliability. Exemptions could be made for specific lines (e.g. Grosmont-Whitby, the Blackpool tramway) after careful evaluation of the risks. However, such museum pieces should not be making long-distance journeys on main railway lines.
Have you really thought that idea through?
For a start the Statesman stock is Mark2D's I believe,built in the early 70's. And what about class 20's,37's and so on,are they "inherently unreliable"? I seem to recall it was brand new class 70's which recently had a propensity for bursting in to flames?
That seems a touch draconian particularly in light of the fact the HSTs will be that age in 10y time and possibly still in front line service.
The onus should be on those who run such stock to show that it is up to the job.
The railway should also develop ways of keeping other trains running to time when one train fails. Bidirectional signalling with high speed crossovers would help.
And there the idea dies...Would need investment...
Awaits a flaming for saying this and upsetting the purists but you know how you can now buy a Mini and a Fiat 500 that embraces latest technology with regard to brakes and suspension etc, yet still resembles the original but with the demands of modern day consumers met, could a fleet of modern coaches be built to look like older ones? Accessible, modern toilets and with power to run aircon, wifi etc etc and latest crash protection too in case of the worst happening.
Would certainly interest me instead of sitting on musty dralon and finding porno mags underneath (Severn Valley with my mrs).
Would need investment but surely investment is needed to attract younger audiences to generate revenues and make a safer more customer focussed environment.
.....the ORR has deemed them to be in a position to operate on the mainline at present.
Who is going to pay for bi-directional signalling and high speed crossovers to be installed and then pay for the additional maintenance that it all requires ? the train operator who just sends his steam train out on odd days and odd weekends then or will it be back to the taxpayer who is shovelling more money into the railway than ever as against B.R. days of funding of the railways.
Yes, and all the staff too. People 50 years old and over are equally run-down and unreliable. However many annual medical check-ups they have a complete failure (heart attack, stroke, black-out) could occur at any time.
Think Glasgow bin wagon.:cry:
Just because rolling stock is old does not make it bad. I mean look at the IOW they're running stock built in 1938.
It's not for the regulator to prove the operator dangerous. It is for the operator to prove that they are safe. It's a condition of holding an operating approval.It can be the case that a regulatory authority has concerns about a company, their paper trail systems or actual operating practices, but cannot prove them to be dangerous until after a terrible, easily preventable 'accident' occurs.
Would you want to though? Part of the fun is it being "real" and shuddering around when it shouldn't.
It's supposed to be heritage, real history, not some Disney reimagining
I can't see that anyone would want to make a fleet of heritage style vehicles, as you wouldn't be able to make them at all convincing given modern crash worthiness standards. We only really use Mk1 and Mk2 vehicles because they're plentiful in number and relatively simple and easy to maintain. Given that the charter market is gradually shifting towards luxury days out, we may in time see the Mk1 and Mk2 rakes replaced with Mk3, Mk4 or even new builds with very nice interiors.Marklund said:That's fine for a heritage railway. The mainline isn't a train set though.
Who was Guarding? WCRC or the tour operator?Another stop short and release at Bath Spa with a 1Z. Train then moved with all doors open and passengers boarding and alighting to the correct point.
What was the stock and traction? By 'release', I assume it was something with CDL?
Not good :-/
