bishdunster
There used to be (1960s/early 1970s) both a stuffed dog and an aluminium printing machine at Bournemouth Central.
Yes, I remember those too.Machines that stamped your name, or whatever you typed in, on a thin aluminium strip for use as an ID tag. Like Dymotape on metal.
Trainspotters
Where is one of these? I remember them in an old-time amusement arcade type setup that is long gone in Southampton, never seen one in the wild!Machines that stamped your name, or whatever you typed in, on a thin aluminium strip for use as an ID tag. Like Dymotape on metal.
None of the aforementioned swing bridges are as odd as the old pedestrian swing bridge at Brockenhurst.
Stanlow and Thornton is a bit like this, the station is within a refinery and I believe your average pedestrian might well be stopped and questioned if walking to the station. Mind you bearing in mind service levels right now if you were going to give it ago, you need to time it right. !
The station is actually outside the security fence at Stanlow Gate 4. However to reach it you need to go down Oil Sites Road from the Ince end past some rather forbidding "Private Road" signs. There is an unstaffed card operated barrier on Oil Sites Road between Stanlow and Ellesmere Port to stop its use for through traffic. However cars can in principle approach the barrier from either end - and pedestrians and cyclists can cycle/walk through. The barrier was installed about 10 years ago to deter fuel protestors.
Having said all that, I cannot promise that you won't be challenged if you try walk to the station. I was once (at the Ince end) but as soon as the security man realized I was a legitimate passenger with a fairly heavy bag, he gave me a lift to the station.
But, if you like "collecting" stations just for the fun of it, the best advice is to arrive by an Ellesmere Port bound train and leave by the same train on its way back to Helsby or wherever.
I've made use of one at the Rail Museum in York, but that isn't "still on the network".Where is one of these? I remember them in an old-time amusement arcade type setup that is long gone in Southampton, never seen one in the wild!
Wait, is this an oddity?Just seen a FGW liveried 150 coupled to a GWR 153 working a service to Blackburn, didn’t catch the numbers.
Not terminating, but the Central Line at Stratford is between main line tracks - so is pretty much the Greenford situation in reverse. Funnily enough, that's the same tube line as well...
Plus the 20 minute frequency on Woodford to Hainault.Had forgotten about that, good point. Add to that also the White City 'wrong side' tracks, The Central Line as a whole really is an oddity itself!
45 minute frequency on the St Albans abbey branch, is this unique?
All these old pieces of equipment and oddities have actually done a decent job for many years before being taken out of service. Grayling never has, and regrettably is still in service.Surely the greatest oddity of all is Chris Grayling?
Stratford station is also an oddityHad forgotten about that, good point. Add to that also the White City 'wrong side' tracks, The Central Line as a whole really is an oddity itself!
Transport for Wales seem to like having impossible GBTT public turnaround times. Wrexham Central is another example.Well, there's the 15/15/30 minute pattern in the Barry Island branch. The 'missing' train now goes to Bridgend via Llantwit Major instead.
While researching this I noticed that the turnaround time at Barry Island in the WTT is just 3 mins, that in the public timetable is zero minutes and the WTT departure time is one minute after the public departure time.
It isn't accessible by road vehicle, when trains are not running, even the RRB can't get to the station! There is no taxi access. But there is a station car park, which is very underused as a result! There are warning signs on the road (just before the barriers) warning you not to wait or to take photos! Although, in theory, you can walk to the station, it is quite a trek to/from anywhere, and you will attract attention of security. Although they are pleasant enough if you explain and show them a ticket. But, in reality, plan your arrival and departure by train, unless you have business at the site.
The platform numbers go 1, 2, 12, 11, 10A, 10, 9, 8, 6, 5, 3, 3A,
13, 14, 15, 16, 17
The platform numbers go 1, 2, 12, 11, 10A, 10, 9, 8, 6, 5, 3, 3A, 13, 14, 15, 16, 17
10 and 10A serve different tracks and 3 and 3A serve the same track.
