jfowkes
- Joined
- 20 Jul 2017
- Messages
- 897
Are there any new services or timetable changes coming up that make use of the freed capacity north of Peterborough?
I understand that additional upgrades, particularly to power supply, are needed before the train frequency can be increased.That’s the deferred ECML recast...
All down freights since 3pm have been using the diveunder, but nothing whatsoever in the up direction,Apparently 4E25 Bow to Heck and 4E20 Felixstowe to Masborough used it aswell
There were no limitations in the ORR authorisation letter, of course that doesn’t mean there can’t have been a subsequent fault. Maybe tomorrow…All down freights since 3pm have been using the diveunder, but nothing whatsoever in the up direction,
so presumably the up line has not been approved for use at this point in time?
Slightly stupid question, but how much was booked that could have used it?There were no limitations in the ORR authorisation letter, of course that doesn’t mean there can’t have been a subsequent fault. Maybe tomorrow…
Just these two on a Monday afternoon:Slightly stupid question, but how much was booked that could have used it?
Power supply was one of the reasons given in the press when the recast was shelved, along with Azuma-related issues. Is that not the true story?The recast was due in May, the power supply could accommodate it.
AIUI, GBRf are moving to March specifically for increased use of the dive-under.Just these two on a Monday afternoon:
4L87 - https://www.realtimetrains.co.uk/service/gb-nr:H64627/2021-11-29/detailed
4L08 - https://www.realtimetrains.co.uk/service/gb-nr:H15028/2021-11-29/detailed
(all other 'up' freight services are GBRf intermodals which are booked to call at Peterborough yard)
MARK
The Azuma issues, or the power supply at Grantham/Retford, or both?It was true then, but it’s been sorted.
That's interesting. If the passenger service, 2K10, also used the diveunder a crossing movement would have been avoided
According to Realtimetrains, it departed from platform 2 so to use the diveunder would have involved crossing 3 lines on the ECML instead of 1 line on the GNGE.That's interesting. If the passenger service, 2K10, also used the diveunder a crossing movement would have been avoided
Ah, of course. I forgot the Spalding services use the easternmost line between Peterborough and Werrington Junction, so a crossing movement was unavoidable whether or not the freight used the diveunder.According to Realtimetrains, it departed from platform 2 so to use the diveunder would have involved crossing 3 lines on the ECML instead of 1 line on the GNGE.
Realtime Trains - 2K10 1028 Peterborough to Doncaster
Realtime Trains is an independent source of live realtime running information for the Great British railway network.www.realtimetrains.co.uk
I enjoyed watching 66221 on 4L45 being 'overpassed' by 1E09 and 1A28 on the DF and UF lines just after 1pm today.
A seemingly knowledgeable local chap told me that an OTP went through the dive under in the very early hours of Sunday to make final checks, and then apparently the first real action was a freight sometime on Sunday morning.
Not sure how accurate this claim is, but looking at RTT the only candidate appears to be 6Y70 Biggleswade-Belmont Down Yard:
However, this posts a time for Werrington Jctn as usual, so perhaps not?Realtime Trains - 693L 0900 Biggleswade to Belmont Down Yard
Shame the entry into service has been quite so unceremonious.
Possibly including a day out for sundry politicians, who will be photographed wearing spotless hi-vis and entirely superfluous hard hats?Sources tell me there is to be an official/ceremonial opening, not sure of the date but I suspect it may be next week.
And no doubt trumpeting how much cheaper this upgrade was than the HS2's extension of HS2 to Yorkshire they canned last month. (But not mentioning that it provides a far smaller improvement in capacity)Possibly including a day out for sundry politicians, who will be photographed wearing spotless hi-vis and entirely superfluous hard hats?
Basically, yeah. Its purpose is so freight coming from Anglia way don't block the mainline causing delays.Curious to see if the use of the diveunder will result in improved performance by the passenger trains as just fewer trains in the way?
I was going to say - I thought south of Bawtry all was done on ECML PSU1?It was true then, but it’s been sorted.
The bare minimum to allow enough Azumas to run (AT between Welwyn & Hitchin, Boosterless Classic from Wood Green to Bawtry (exc. Hertford Loop), new feeder at Essendine) has been completed. Most of the bog-standard TSCs/MPTSCs have been upgraded; only the feeders remain ongoing. These are at:I was going to say - I thought south of Bawtry all was done on ECML PSU1?
Yes, 1H03 used it at 14:44 today.Can anyone confirm whether today's (05/12/21) Hull Trains 1H03 1418 Peterborough to Hull used the dive under please?
It would appear so from watching it on traksy as it appeared to use the down Stamford before appearing on the Spalding line. Confirmation that it was the first in passenger train through the dive under would be appreciated.
[05/12/21 14:41:09] CA 1H03 PB0471 PB0475
[05/12/21 14:42:06] CA 1H03 PB0475 PB0485
[05/12/21 14:42:46] CA 1H03 PB0485 PB0499
[05/12/21 14:44:32] CA 1H03 PB0499 PB7007
[05/12/21 14:45:26] CA 1H03 PB7007 PB7009
In addition to the earlier explanation taken from the signalling logs, you can also see it on RTT as with the initial freights a few days ago. The thing to look for, as well as the down Stamford line use, is “no report” at Werrington Junction.Can anyone confirm whether today's (05/12/21) Hull Trains 1H03 1418 Peterborough to Hull used the dive under please?
