HilversumNS
- Joined
- 30 Apr 2015
- Messages
- 232
Deleted
If they lay rails, trains can run. Simple as.
Christ on a bike the way some of you are talking you would think the area between Bedford and Stevenage was like the Alps - it is fairly undulating country with a few unremarkable hills. :roll:
I think you need to look at a map. From leaving Luton through to Harpenden the railway runs along the bottom of the valley and the height increases quite significantly in the mile either side as the attached link to an OS map shows.
And most people on here seem to want a Luton - Stevenage link.
If you were talking Hitchin - Bedford, I'd agree with you, not least because there was previously a line there that had worked around the gradients on the land.
http://www.streetmap.co.uk/idld.srf...searchp=s.srf&dn=767&ax=514488&ay=218877&lm=0
Actually, looking at the map, if an MK-Luton-Stevenage link is desired then it might be sensible to link the Bletchley-Bedford line to the MML where they get close to each other south of Bedford (near Millbrook the lines are only about 1km apart) and avoid Bedford altogether i.e. have the main MML interchange at Luton, which is a much larger urban area than Bedford anyway and also has the airport traffic potential.
There is some wibble written by the clueless on this thread about prices. Whilst clearly qualified quantity surveyours your understanding of working within the railway boundary is limited to say the least.
It is NOT the same operating environment as a building site. I cant be bothered to rehash all of the arguments because you simply don't care.
"(and miss Bedford)" - do you mean "(and miss MK)"?
I certainly agree that Bedford-Northampton is a good idea, because it combines the advantages of being a useful and straightforward workaround for the problem of both MK and Bedford being awkwardly off to one side of the EW route rather than directly on it, and of extra connectivity in its own right for journeys where EWR of itself provides little improvement. Not only for passenger journeys; it plus Bedford-Cambridge would give a route from Felixstowe to DIRFT that avoids the WCML altogether.
Like I have said a few times, you need to convince Northampton council then as we have sold off the vast majority of the Brackmills branch as Northampton council wanted the land for development. Re-opening Northampton to Bedford is pretty much a dead duck. There is also next to no East Anglia traffic to DIRFT anyway, it's all London Gateway/Purfleet/Tilbury traffic.
Assuming that includes my comments on platform extensions, then you are quite right that I don't care. The situation - that we could have on one side of the fence a few guys with a digger and a possession building a square lump, while a few yards away on the other side some other guys could be building a whole bunch of houses for less money - is so patently ridiculous that the arguments can be rejected unheard because they lead to an unreasonable result. It is those arguments which are the true "wibble", and the true "clueless" are those who do not recognise them as such.
When the bridge collapsed a couple of years ago some freight run through Dullingham and turned at Cambridge so would perhaps do again, not ideal but better than nowt
There is nothing further to update on Central Section route options since March. The work to identify a preferred route is complex and will take some time, but we expect to have a preferred corridor identified by the end of the year. There may be an interim update on progress in late June following a meeting of the Central Section working group, but I cannot pre-empt what this update might cover. When there is ‘news’ I will post this on the website and send an email to subscribers.
The newspaper article is accurate. When support and funding for the Western Section was announced by Government in July 2012, the target date for completion was given as December 2017. Network Rail were tasked with delivering the work in the five-year spending period April 2014 to March 2019. They published their delivery plan on 31st March 2014 and committed to deliver East West Rail Western Section by March 2019. This is not a two-year delay, but rather Network Rail gave a commitment to deliver 15 months later than the original target date.
There are no other delays that are not documented on the website. The current situation is that we await confirmation of the final scope for the scheme, which will include enhancements proposed by the Department for Transport (including electrification) over and above the original scheme promoted by the East West Rail Consortium. This should be confirmed by September 2015, if not earlier.
The plan is for EWR services to start in March 2019, and the line between Oxford and Bletchley will be electrified at the same time as the re-construction and upgrading of the line. We therefore can expect a diesel service to operate to Bedford before the Bedford Bletchley section is electrified, which may not happen until 2021 – the date has yet to be confirmed.
I hope that helps.
Kind regards
Caryl
Caryl Jones
Communications Manager - East West Rail Consortium
"Assuming that includes my comments on platform extensions, then you are quite right that I don't care. The situation - that we could have on one side of the fence a few guys with a digger and a possession building a square lump, while a few yards away on the other side some other guys could be building a whole bunch of houses for less money - is so patently ridiculous that the arguments can be rejected unheard because they lead to an unreasonable result. It is those arguments which are the true "wibble", and the true "clueless" are those who do not recognise them as such.
I can't believe any sane individual is still touting the reinstatement of Northampton - Bedford, particularly as part of EWR.
I wouldn't say I want a Luton-Stevenage link - I want an East-West route, but realistically unless it can be sold as a "high speed airport link" or similar, politicians are just not going to be interested. I would see the ideal route as Bedford to St Neots, entering Cambridge from the north, more-or-less as mr_jrt has suggested on here (although it would mean freight having to reverse to reach Felixstowe). But I just can't see such a route being supported, given the likely cost and lack of airport connections....and most people on here seem to want a Luton - Stevenage link.
So its now or never really.
Opening up the Northampton-Bedford line does have its advantages.
Bedford is connected to the north west directly without changes.
It opens up diversion routes in both directions (if you include the Marston Vale)
You could easily get a circular service (Bedford, Northampton, MKC, Bedford)
MKC is no longer a terminus, as it stands its logistical location on the line is pretty bad and requires its own special service.
The A428 is designed as a village access road, its not designed as a dual carriageway, which if you look at the numbers of cars using it, thats what is needed.
Connecting Northampton to Bedford from the north of Bedford makes the EWR's life a bit easier since they can piggy back off each other if necessary. It keeps Bedford Midland in the loop.
I will agree that none of those justifies rebuilding the line on its own, but altogether, I think there is a case for it. Especially as doing it now will be the cheapest it will ever be. In 10 years time there may be new cases to justify its re-opening only to find that cost has doubled, houses are built all over the line etc. I've seen whats happened on the cycle path at Bedford. Its going to happen on the Northampton-Bedford line eventually. So its now or never really.
Very short sighted as most of the roads into Northampton from all points of the compass are overcrowded alot of the time. There needs to a strategic rethink at govt level over towns such as Northampton that are choked with traffic. The problem is not going to get any better and, as any sane person knows, building more roads that only make the problem worse is not a viable or desirable solution any more.
And just about everything you have said puts railways in a disadvantaged position. All your arguments could be used against every single proposed railway in the world. You could argue "Just build more roads, Job done".
Hmm, lets see... How many streets are currently jam packed with parked cars on the grass verges, how many streets are now one way because there is a line of parked cars down either side of the road?
Railways are supposed to be the solution to taking cars off the road, or one of them.
Not many people see the bigger picture. But I for one see a country where we do not have the capacity for cars in many areas. Building more roads only helps in one aspect of the problem.
