How can there be more to the story if the person didn't cross the railway line but got an on the spot fine? If he'd attacked or abused the BTP officer, it would have been a different charge and probably arrest. Maybe the OP did do more, but it doesn't actually matter for the sake of the argument.
And if you're trying to be the voice of reason, saying that the law is different in the railway world, then your 'ludicrous' comment to what I wrote is even more weird, as you must have seen the point I was making. Are you saying that the warning sign only applies beyond its position? The point is, if it says 'must not cross the line' then the wording means you can't cross the yellow line to board a train.
If it only applies beyond the sign, then that means I can jump off the platform and cross the railway line as long as I climb up the other side and never pass this invisible line that is horizontal in line with the sign. No, obviously it doesn't mean that. THAT is ludicrous.
Come on, you're clutching at straws here. I don't need to be qualified lawyer to understand what 'crossing the line' means.
If people in the railway think otherwise then that's a serious issue and may explain why they've been so slow to put up the proper 'must not cross this point' signs that would do away with ANY chance of confusion.
