Are 67s still doing Manchester to Holyhead?
Discussion in 'Allocations, Diagrams & Timetables' started by stretchdj74, 15 Apr 2019.
  1. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Wasn’t on last week due to the work at Acton Grange Junction.
  2. Y Ddraig Coch
    Y Ddraig Coch Member
    874
    1 Nov 2013
    Of course...:rolleyes:
    Thank you :D
  3. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Anyone know what happened to the 1650 Piccadilly today? Cancelled. Was it a shortage of drivers who sign the 67?
  4. _toommm_
    _toommm_ Established Member
    2,932
    8 Jul 2017
    Whiston/Leeds
    Cancellation code is TG, so it will be the driver.
  5. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Thanks.
  6. Y Ddraig Coch
    874
    1 Nov 2013
    It has just arrived in Llandudno and it is the 67s though so must have started short. Rather than cancelled and different traction used.
  7. PHILIPE
    PHILIPE Veteran Member
    11,171
    14 Nov 2011
    Caerphilly
    Just cancelled between Chester and Manchester Picc and back
  8. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Just seen the Manchester set arriving at Frodsham and sure I only saw 2 coaches instead of the usual 4. I’m assuming a couple are out for maintenance.
  9. 86247
    86247 Member
    159
    12 Feb 2017
    is it still 67010 on it or has it changed thanks
  10. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Yep still 67010.
  11. 86247
    86247 Member
    159
    12 Feb 2017
    thanks a lot hopefully get in at Oxford road later
  12. craigybagel
    craigybagel Established Member
    2,496
    25 Oct 2012
    67 + 3MKIIIs + DVT, been like that for a few days.
  13. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Thanks. Shows how observant I am! Must be doing maintenance on one of the Mark 3s.
  14. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    67010 has failed at Chester this morning so the Manchester set is a unit. This morning’s Holyhead to Cardiff is also a unit due to power issues with 67014.
  15. 158820
    158820 Member
    230
    1 Nov 2017
    67014 terminated Shrewsbury last night nearly 2 hrs late.
  16. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Anyone know what happened to 67010 today at Piccadilly? RTT said a brake issue?
  17. PHILIPE
    11,171
    14 Nov 2011
    Caerphilly
    You've answered your own question
  18. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    What I meant was - any further info? Think I heard it go through Frodsham about 7PM so was wondering whether it was a loco/coach issue and if it was indeed fixed that quickly.
    Sarcasm unnecessary.
  19. PHILIPE
    11,171
    14 Nov 2011
    Caerphilly
    If I do find out later I won't pass the info on
  20. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Looks like the 1650 was cancelled and 67010 and the Mark 3s were on 1T31 that left Piccadilly at 1806.
  21. PHILIPE
    11,171
    14 Nov 2011
    Caerphilly
    Whatever, the whole of the evening peak on the route got heavily disrupted with trains even turning back at Warrington due to TFW trying to reduce disruption to a minimum.
  22. mrcaa
    mrcaa Member
    130
    12 Mar 2019
    Was an absolute nightmare as the next train was only 2 cars and was diverted to 13b at the last few seconds so lots of us couldn’t get on. I walked to Victoria and got the Northern one after that as those platforms were dangerously crowded as usual. I wonder if the unit with the dodgy brakes is the same one that started moving at Earlestown when people were still getting off a few months ago?
  23. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Yeah still not sure if it was a loco/coach issue. I *think* the loco was 67014 at the point of that incident, thought the coaches would more than likely have been the same, unless they’d been swapped out with some of the Cardiff-Holyhead Mark 3s.
  24. mrcaa
    mrcaa Member
    130
    12 Mar 2019
    Does anyone know why these locos are still being used on these services? Is it just because they’re still desperately short of DMUs or is there some reason why they’re more suitable for the route? If they’re going to cause the kind of disruption they did tonight maybe it’s time to pack them in.
  25. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Good question and would be interested to hear from others on this. Even with TFW ‘new’ stock on the horizon the plans are to keep the 67s, but to replace the Mark 3 coaches with ex-LNER Mark 4s (from Dec/Jan 2020 I think). So probably to do with capacity as they have, for example, 4 coaches on the Manchester set.
  26. mrcaa
    mrcaa Member
    130
    12 Mar 2019
    I guess that makes sense if the DMUs are a maximum of three cars. If the brake issues are with the carriages too I guess that wouldn’t be a problem once they get replaced.
  27. Phil from Mon
    Phil from Mon Member
    329
    28 Nov 2014
    Beaumaris, Ynys Môn
    As I understand it the Mk 4s will only be working Cardiff-Holyhead. All the Manchester services will revert to DMUs.
  28. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Ah yes now you mention it I’ve heard the same. I’ll miss the loco hauled set.
  29. krus_aragon
    krus_aragon Established Member
    5,317
    10 Jun 2009
    North Wales
    Or maybe not! See this post about a recent announcement, in the TfW Mark 4 thread.
  30. Tom Maddox
    Tom Maddox Member
    592
    14 Apr 2019
    Frodsham
    Interesting! Hope that proves to be the case.
Share This Page
