Class 345 progress
samuelmorris
18 Jul 2013
Brentwood, Essex
345008 seems to have had a PIS reset and is now using the original script which included having an interchange at Forest Gate, saying 'Liverpool Street via Stratford' and the screens seem to be fuzzy.
I thought Liverpool Street via Stratford was still in the current script, and that the Forest Gate interchange was mentioned, but only off-peak? I can't comment on the fuzzy screens, I don't ever recall that being an issue - it was the audio they had trouble with for the first year or so.
6 May 2017
Near a bunch of sheds that aren't 66s.
Current script uses just plain 'Liverpool Street'. The interchange at Forest Gate is mentioned as only an exit on the current script. It says 'Exit for Wanstead Park Station' whereas the original says 'Change for London Overground lines'. Audio mostly seems to be fine with a few glitches. Nowhere near as bad as when they were first introduced.
iphone76
6 Nov 2010
South Essex
The Wi-Fi system has been enabled on a few of the 345s in the East and West. Its called "tfl wifi". Posters have been added to the trains.
700007
6 May 2017
We have been told all of them on the West apparently including the 360s have been done but it is still 50:50 on the East side. Indeed I did notice a few had TfL WiFi yesterday when I was out and about.
Railperf
30 Oct 2017
No WiFi on the 360s yet but some on the 345s
These are very fast accelerating trains - 0-80mph in 60 seconds. On the other hand any performance advantage with the faster acceleration seems to be lost by the very cautious braking approach to most stations - even on a dry rail - compared to the turbos!
matt_world2004
5 Nov 2014
Theres a late night 345 service that is Hayes Ealing Broadway and Paddington only and it does the trip in about 10 minutes.
samuelmorris
18 Jul 2013
Brentwood, Essex
No progress to report I expect. With Heathrow still inaccessible to 345s, the crossrail core opening now a very distant dream, unless there's to be a U-turn on the decision not to run too many sets in 7-car formation, the status quo will carry on for quite a while yet. The only thing that might change this year is operation of more GW services from Paddington with 345s.
samuelmorris
18 Jul 2013
Brentwood, Essex
How much longer have we to wait for this? Why is it taking so long to sort?
I assume, given how late everything else is, they've given up on getting 345s to work with GWATP still active, so are waiting for 387s to replace 332s on HEx services before they serve Heathrow. Once GWATP is decommissioned on the branch they'll be ready to go. Whether anything will be done about stopping at Hayes requiring 7-car units I'm not sure.
19 May 2010
West Drayton
387s are supposed to have in cab signalling also though as there is no TPWS fitted to the Heathrow branch.
9 cars can serve Hayes platforms 1 to 4, just not platform 5 (dead-end bay platform).
ijmad
7 Jan 2016
The suggestion I'd seen was the current signals would be decommissioned and ETCS could be commissioned with a blockade, and the class 322's replaced by 387's and the 360's replaced by 345's at the same time when the line reopened.
19 May 2010
West Drayton
How is that going to be commissioned when testing keeps failing?
ijmad
7 Jan 2016
I thought the reason the testing is supposedly failing is interference from the old signalling. If they switch them off entirely and it's just ETCS in the tunnels, the tests might start passing, and they could do it all in a blockade perhaps?
rebmcr
15 Nov 2011
St Neots
They've already successfully tested ERTMS signalling overnight with GW-ATP fully shut down. It was quite a while back now, well into last year.
ijmad
7 Jan 2016
Fair enough. Things a bit further on than I last remember reading!
27 Aug 2017
There is also in fair honesty not much point running a 9-car Hayes shuttle service as it would simply cart air around. The 7 cars off peak are already very lightly loaded as it is.
True but it would get the 7cars back to the east where they belong.
Peter Mugridge
8 Apr 2010
Epsom
This morning for the first time ever I saw two side by side on the Crossrail metals at Westbourne Park; 345 031 and 345 032.
I grabbed a picture of this - if it is good enough once I have extracted it from the camera this evening I'll post it up.
Mag_seven
1 Sep 2014
here to eternity
Funnily enough I came out of Paddington a little earlier and noticed two class 345s side by side there as well!
Peter Mugridge
8 Apr 2010
Epsom
Probably the same pair; there's still very limited time slots in which they can carry out running tests in the tunnels isn't there?
