hexagon789
From memory, Manchester retains a similar service to now, and Glasgow gets something like 3/4 trains per day
Thank you
Yes because all the other stations can take 11-car Pendolinos.
It has been mentioned on the 397 thread that the Glasgow services departing Manchester and Liverpool (each 5-car) could join at Preston, and only use 1 path up the WCML.
Thought it was Liverpool that was getting 3/4 trains to Glasgow per day, with Manchester Airport having 1 Scottish tph alternating between Glasgow and Edinburgh. I could well be mistaken though.From memory, Manchester retains a similar service to now, and Glasgow gets something like 3/4 trains per day
Reading that post again, you're right... just ignore me!I thought that is what Domh245 had meant.
Also, I see to recall plans to get the 397s running at up to 115 on the WCML, has anything become of this or is it simply another one of those 'pie in the sky' WCML speed increases?
The 397's will not be running in multiple. The coupler is to be used for rescue only.
I think only platforms 1 and 2 at Glasgow Central could take a 10-car 397. But it should be OK if the Liverpool service couples to the Manchester as the only other trains that length are the Pendolinos and there is only one in the hour when TPE runs to Glasgow. Can't remember if the Voyager via Edinburgh is in the same hour, but if so it might have to go into one of the shorter platforms.
But the TPE track access application allows for doubled up working Preston-Glasgow with combined Manchester and Liverpool portions.
So 10-car formations are envisaged north of Preston.
Might be a problem crossing all the other tracks to get that far over during the daytime, which is less of an issue at the time the sleeper runs. I've never been on a long-distance train at Central that hasn't used one of the lowest-numbered platforms.Forgive me if I'm wrong, but aren't 9 and 10 longer at Glasgow Central, being used by the Sleeper? So couldn't 9 or 10 be used if there was a Pendolino in the other platforms?
For car drivers in past years, the Vauxhall 'Nova' never seemed to have that particular "sparkle".....
