Group Bourdon Tool
Beveridges
8 Sep 2010
BLACKPOOL
It really is better to be on the safe side with Group Boredon as OPC/CCL are failing more & more results that you would expect to pass (see above).
You should nowadays be aiming for a speed of above 1400 and less than 5 omissions or mistakes. Obviously this is impossible without a lot of practice.
Waikikibaby
22 Jul 2013
I've heard that if there are too many applicants then the tests get harder.
Suppose you're on an assessment day with 40 candidates, 30 get through by lunchtime and normally there'd only be about half the original amount, after another test or two there are still 25 people hanging in there.......that's when they might pull out the harder tests. Get those 25 people down to the expected 5 or 6.
Just something that I've heard from one person who may or may not be a reliable source.
ultra4
20 Sep 2013
I disagree.
Me thinks: There must be a set pass mark in order for the test to be accurate and fair.
i.e. you may have 40 candidates, perfect for the job, doing exceptionally well at GBT.
They are all potential drivers. Why to loose 20 of them?
i.e.2 you have 40 useless candidates, all doing poorly at GBT.
Would 20 of them been put through?
nah...
Group-Bourdon Result Statistics
Saved on 10/16/2013 at 9:14:24 PM
Overall Statistics:
Perception & Attention:
Targets Omitted ------------ 4
Marked Incorrect ----------- 2
Speed:
Total Cells ---------------- 1951
Mean Cell Time ------------- 0.191
Median Cell Time ----------- 0.150
Completed Rows ------------- 76
Mean Row Time -------------- 4.760
Median Row Time ------------ 4.740
Vigilance:
Row Fluctuation ------------ 2.07
My assessment is 2morrow.
Still practicing, although GBT is a drop in the ocean with this new assessment regime.
TEA, scares me a bit, and TRP 1
TDK
19 Apr 2008
Crewe
And your source on these figures Bev.
The tests remain the same, the pass rate remains the same except companies will not take borderline passes and more will fail at interview
I disagree.
nah...
Overall Statistics:
Speed:
Vigilance:
Those figures will not be as good as 1200 with no errors or omissions but all you new prospective train drivers keep trying to hit the 2000 mark as this will enable all those with 1200 a better chance of success.
ultra4
20 Sep 2013
Which one of you guys found paper GBT to be easier than computerized version?
Is it possible to attach a survey to the post in this forum?
If not we can simply post answers.
Me first:
PAPER VERSION
mickeyjenson!
3 Oct 2013
Anyone know if you get penalised for not completing lines on the real test, say for instance they say change and your half through the line will that cost you ?
youngboy
28 Jan 2013
I did the paper version earlier this year and got a pass, which is now considered a borderline pass. I completed 10,8.5,10,10,10, pretty sure I got through all correct but only got a borderline pass. This was however the one and only time I've ever completed the test and never practised it beforehand. Pretty convinced that page 2 let me down for a good pass, I got lost on the page for a split second and that error lost me 1.5 lines. So IMO take your time aim for ten lines all correct and I think that would get you through. Don't go for speed and 15 lines a page it isn't necessary !!!
TDK
19 Apr 2008
Crewe
If you had 6 or 7 lines all correct it would have been a good pass
ash39
8 Feb 2012
Just started practicing group bordon again. I first tried it a couple of years ago and can't remember my stats now, but I'm pretty happy with these. My assessment is next Tuesday so I still have time to practice, but I think I'll prioritise the other tests as this would probably be a pass from what I've read here.
Targets Omitted ------------ 1
Marked Incorrect ----------- None
Speed:
Total Cells ---------------- 1271
Mean Cell Time ------------- 0.306
Median Cell Time ----------- 0.270
Completed Rows ------------- 48
Mean Row Time -------------- 7.655
Median Row Time ------------ 7.650
Vigilance:
Row Fluctuation ------------ 3.94
Just to show practice definitely makes for improvement. If you've got onto an assessment day you'd be daft not to use the tool...
Overall Statistics:
Targets Omitted ------------ None
Speed:
Total Cells ---------------- 1395
Mean Cell Time ------------- 0.279
Median Cell Time ----------- 0.250
Completed Rows ------------- 54
Mean Row Time -------------- 6.962
Median Row Time ------------ 6.850
Vigilance:
Row Fluctuation ------------ 3.12
DunfordBridge
13 Apr 2013
Scarborough
I had a spare ten minutes this morning so I thought I would try doing a Group Bourdon test for the first time in weeks. I completed 58 rows with 2 omissions. I was not actually performing much better when I practised regularly maybe completing 61 or 62 rows on occasion, disregarding the motivation aspect as I do not have any applications on the go at the moment.
It might be just me but it makes me wonder if there is any point in practising to excess, not that I ever went to town on this test even though I have wasted endless hours on this test because my pass from the conductor assessment was quite adequate apparently.
I would recommend losing your virginity with this test, so to speak, just to get used to the pseudo-random dottiness of the boredom test.
Theukslayer
28 Nov 2013
Hi ash39, have you heard anything back from northern with regards to your assessment on Tuesday ?
gazcat
15 Dec 2013
hello, just wondering if anyone could clarify something in relation to the paper based group bourdon test in an assessment centre?
do you need to count the amount of strikes or boxes you mark, and remember that so as to fill in a total completed box anywhere?
or is it a case of striking through as many as you can as accurately as you can, leaving the assessor to count them?
Waikikibaby
22 Jul 2013
You just need to strike through the shapes from left to right and line to line. Do as many as you can in the time, they'll do all the counting up afterwards.
TDK
19 Apr 2008
Crewe
I see many people on here boasting about how good they are at GB and what speed they are getting to but none of them hardly ever come back saying they have passed the tests, strange that!
DunfordBridge
13 Apr 2013
Scarborough
Passed the GB test over a year ago and passed all other driver tests a few months ago apart from the CBI. I always preferred the DTG test. Funny how there is no equivalent test in the new driver assessments for foot co-ordination.
Beveridges
8 Sep 2010
BLACKPOOL
GBT is a little 10 minute test out of a full day assessment.
TDK
19 Apr 2008
Crewe
This thread is for the GBT and it is this thread I am referring to and this thread where members of the forum look for help with the GBT.
NI 271
10 Sep 2012
The Doghouse
Maybe that's because...
beavercreek
18 Nov 2011
I did exactly 10 lines per page which works out at 1250 cells.I got a good pass and got the job as trainee driver.
Beveridges
8 Sep 2010
BLACKPOOL
I did 13 lines per page which is around 1600 cells. I got an outstanding pass back in 2008. My only regret was wasting so much time over practising the Group Boredom tool. Once I had hit 10 lines per page I should have stopped practising as everything after that was just wasting my time.
TDK
19 Apr 2008
Crewe
I cannot remember how many lines I did and had no practice back in 1999 however I looked at the sheet and deducted all the groups of four were either square, diamond or a "Y" shape and looked for the shapes, I completed constantly over half a page on each sheet with out any omissions or mistakes as I did not get bogged down counting the dots but looking for shapes instead. I do not know whether the format of the dots has changed and the shapes are now different but that is what I would say using your initiative.
hidden
10 Dec 2013
I have my assessment later this week with Northern for a trainee conductor role.
I have been practicing the SCAAT test and obtained the following result
(3 pages @ 1 min each)
SCAAT Result Statistics
Saved on 31/12/2013 at 15:20:18
Overall Statistics:
Targets Omitted ------------ 11
Marked Incorrect ----------- 1
Speed:
Total Cells ---------------- 512
Mean Cell Time ------------- 0.225
Median Cell Time ----------- 0.140
Completed Rows ------------- 19
Mean Row Time -------------- 5.544
Median Row Time ------------ 5.100
Vigilance:
Row Fluctuation ------------ 4.88
What do we reckon? I'm going to keep practising, this was the first time I did it on the computer ^.
ewsdbs
24 Nov 2012
Hello again guys. I gave the test another go, after passing 20+ years ago. Here's how I got on. Don't know if it's good or bad:
Overall Statistics:
Speed:
Total Cells ---------------- 1020
Mean Cell Time ------------- 0.380
Median Cell Time ----------- 0.320
Completed Rows ------------- 38
Mean Row Time -------------- 9.462
Median Row Time ------------ 9.515
Vigilance:
Row Fluctuation ------------ 4.73
Individual Sheet Statistics:
Sheet: 1
Speed:
Total Cells ---------------- 182
Mean Cell Time ------------- 0.426
Mean Row Time -------------- 10.670
Fastest Row ---------------- 9.32
Slowest Row ---------------- 12.43
Vigilance:
Row Fluctuation ------------ 3.11
Sheet: 2
Speed:
Total Cells ---------------- 210
Mean Cell Time ------------- 0.369
Completed Rows ------------- 8
Mean Row Time -------------- 9.253
Fastest Row ---------------- 7.82
Slowest Row ---------------- 11.32
Vigilance:
Row Fluctuation ------------ 3.50
Sheet: 3
Speed:
Total Cells ---------------- 219
Mean Cell Time ------------- 0.354
Mean Row Time -------------- 8.814
Fastest Row ---------------- 7.83
Slowest Row ---------------- 11.59
Vigilance:
Row Fluctuation ------------ 3.76
Sheet: 4
Speed:
Total Cells ---------------- 213
Mean Cell Time ------------- 0.363
Mean Row Time -------------- 9.120
Fastest Row ---------------- 7.70
Slowest Row ---------------- 9.73
Vigilance:
Row Fluctuation ------------ 2.03
Sheet: 5
Speed:
Total Cells ---------------- 196
Mean Cell Time ------------- 0.395
Mean Row Time -------------- 9.623
Fastest Row ---------------- 8.70
Slowest Row ---------------- 10.23
Vigilance:
Row Fluctuation ------------ 1.53
Septus
20 Jul 2013
Well I must have passed my GB test, seen as I passed my stage 1 with FGW.
Although I have no idea how I did. I only know that on sheet no2 I marked one wrong and ended up been a line or too short on that sheet compared to others as it threw my concentration slightly.
Oh and it seemed a hell of a lot easier to do on paper than on the computer!
DunfordBridge
13 Apr 2013
Scarborough
I was not even old enough to apply for a conductor's job in 1988, let alone a driver's job.
Today I thought it would be an idea to practise the test again as I have failed to do so since the last time I posted on this thread. Got two times 57 rows with three and two omissions respectively. It was a bit frustrating as I was that close to getting 13 rows on two of the sheets if I could have bothered pushing myself a bit more on this boring test.
Bearing in mind that the new Vigilance test from Schuhfried is half a hour long, supposing if anyone had devised a practising tool, it would be a good test of time-management skills to find the opportunity to practise for this test.
In addition to the advice from TDK, I would like to add that it is good when you can a long run of threes but not so good when you get a long run of fives as you need to be careful about what is seemingly interspersed amongst the fives, for example a four.
youngboy
28 Jan 2013
Did this test a few weeks ago and passed, I did nine lines on each page !!
The assessor from the OPC stated at least half a dozen times, go as quickly as you can but remember ....accuracy is the key !!
