1F05 0801 Bristol Parkway - Portsmouth due 0816 formed of 158950 (F) + 153361 (R)
On arrival to split
153361 to shunt and attach to rear of 2O70 0841 dep to Weymouth
158950 to form continuation of 1F05 0823 dep to Portsmouth
2K07 0751 Severn Beach - Bristol TM due 0832 formed of 166220
Set to form 2K10 0836 Bristol TM - Avonmouth
2K27 1434 Avonmouth - Bristol TM due 1506 formed of 166220
Set to form 2K30 1515 Bristol TM - Severn Beach
RFA @ Reverse formation due to NON MULTI restriction & 153 not suitable for Avonmouth branch / 2O70 shortformed
_______________________________________________________________________
1F02 0630 Cardiff Central - Bristol TM due 0820 formed of 150263
Set to form 2E17 0723 Warminster - Great Malvern starting Bristol TM (0841 dep)
5F02 08+30 Bristol TM - St. Phillips Marsh ECS not required
RFA :- Earlier failure of 158959 on St. Phillips Marsh
Started at Bristol Temple Meads [BRI] due to a "fault on the train".Service absolutely diabolical this morning! 07.44 Trowbridge to Great Malvern cancelled due to a broken down train. Following train at 08.00 (06.00 ex-Pompey) formed of 2 coaches instead of 5 due to ‘more trains than usual requiring maintenance at the same time’. Passengers left behind at every station from Trowbridge onwards. Made it on board. All windows locked shut and failed air con! GWR currently getting mobbed on twitter from commuters - What’s more concerning is it’s the second time it’s happened this week, though last time the 08.00 had 3 coaches. Things are really poor for commuters in Bristol - Warminster corridor at the moment.
EDIT: And to top it off, one side of the staircase closed on platform 1 at Bath so took about 10 minutes to even get out of the station - only one side of the staircase open for those travelling between the subway and platform!
Lots and lots of issues with shortforms and failures today: (Pulled directly from Tyrell, sorry if formatting is bad)
On arrival to split
Even without being caught up in it all, I could tell there were rolling stock issues this morning. The 08.41 Temple Meads to Weymouth was formed of 3x153, which was interesting to say the last. Pretty sure that isn't normally the case. Didn't help will dwell times (which is why I suspect it was delayed a fair bit as it went along).
You can say that again!
I commute from either Oldfield Park to Keynsham or Montpellier to Keynsham, and there has been some kind of delay pretty much everyday for the last few weeks.
One thing I have noticed that is happening is more is services being delayed at Temple Meads. Either adding a delay onto an otherwise right time departure, or existing delays being made worse. And this seems to be even more the case now than what it was before the resignalling. I suspect the slow temporary (or maybe not so temporary) speed limit that has been applied at Temple Meads isn't helping matters at all. I'm also noticing more services being shown on live boards and apps as simply "delayed" rather than having a number of minutes - but that could be a policy change (showing "delayed" rather than showing delayed by 1 minute, then delayed by 2 minutes etc etc).
Booked for a Turbo, so I assume 3 coachesI notice that the next one is the Weymouth (0824) and that did turn up. I wonder how many coaches on that one - two possibly?
Apologies. Pretty sure I read on JC that it was cancelled throughout at one point but maybe I imagined it.Started at Bristol Temple Meads [BRI] due to a "fault on the train".
What’s interesting is this time of year, the Weymouth services just cannot seem to run to time, and it’s been like it every year since I’ve started commuting about 5 years ago. Obviously not all GWR’s fault but the route becomes very unreliable when we have good weather. Probably down to a mixture of infrastructure issues; trains that break down when it gets to above 25 degrees centigrade; increased passenger numbers; additional trains using the single track on weekends; long distance services (more to go wrong elsewhere) and large passenger numbers.
Makes me wonder if redoubling parts of the single line would make any difference, allowing a more frequent service to run without being delayed at passing points. The current set up is fine for winter but the line struggles to cope in summer.
Primary cause is IET engines overheating due to clogged air filters - one 10 car got stranded in Sapperton Tunnel last night for several hours. Issue then is it’s not just a case of replacing/clearing the filters, the engines have to be thoroughly examined and any secondary damage from overheating repaired. Why the filters aren’t up to the job is the question being asked; but a caveat is they’re doing a lot more high speed diesel running than designed for.
5 sets stopped at Maliphant (Swansea), a brace each at Stoke Gifford and North Pole. Hitachi are working on getting units available for later today to re-strengthen back to 10 car, but they’re up against it.
For once “more train than usual...” is actually the truth!
Anything to do with the weather too, or just the filters?
In a way, yes. But it’s not exactly a new phenomenon in the UK for seeds/pollen/leaves to get stuck on radiators under trains. So really it’s poor design and maintenance.Perhaps the new trains are suffering from hay fever?
You are, as it’s not blocked air filters causing over heating.......I think it’s all kinda intrinsically linked; but I’ll be honest I’m heading into speculation territory here.
The cause was known by the early hours of this morning, or should I say confirmed, by investigation carried out last night.That’s what I was told on my handover before my early turn dealing with all this this morning. If further investigation has changed the cause I wasn’t privy to any update before finishing my shift. Doubtless if anything has changed I’ll find out tomorrow; and as always I’ll share what I’m allowed to.
Is it something easy to solve?The cause was known by the early hours of this morning, or should I say confirmed, by investigation carried out last night.
Yesterday, both the 1730 and 1800 services from PAD - BRI were short-formed of five-car IETs. Both full & standing within 5 minutes of boarding.
To rub salt in the wound, we then had to trundle pass North Pole IET depot and look at all the ten and nine car sets sitting idle (presumably without any staff to run them).
It's embarrasing how badly managed the introduction of the new trains has been. In terms of passenger comfort, punctuality and capacity of trains, we're easily in a worse position than a year ago.
Coming in 2019. It was meant to be 2018. But it’s late, like GWR’s services.New Trains. More seats. Faster journeys.
All coming in 2019 folks. Hold onto your hats!
(You thought they would've taken that insulting message off the CIS now)
