Headcodes
crispy1978
4 Feb 2013
Scarborough
I was wondering if there is a certain way in which headcodes (i.e. 1J25) work?
For example, looking at http://www.realtimetrains.co.uk/search/advanced/YRK/2015/08/20/0000-2359?stp=WVS&show=all&order=wtt there are various numbers (1, 2, 3, 4 and 5 for example) - 1 and 2 seem to be passenger services, 3, 4 and 5 empty coaching stock - not sure if 1 and 2 are different.
I can't work out the letters but the second set of numbers seem to increase per service (so an early service 1E03, a later service 1E23 for example).
Purely for my own curiosity!!
HarleyDavidson
23 Aug 2014
Class 1 is meant to be for a an express.
Class 2 is meant to be for a normal train, semi fast or stopping.
Class 3 is on our patch for priority empties or empties of 10 coaches.
Class 5 is on our patch normal empties.
Class 9 is on our patch is for suburban trains (mainline) formed of 10 coaches, so the signaller doesn't try and put them into a low numbered platform at Waterloo (1-6), as they won't fit.
ValleyLines142
25 Jul 2011
Gloucester
Take for example a Scottish headcode; these are the easiest to use as an example.
The 1000 Kings Cross to Aberdeen has the headcode 1S11. It is '1', as this is an express train (a local GN service out of KGX would be 2xxx). 'S' is the location, so Scotland. '11' is because it's relatively early in the day. In about twenty minutes the 1630 to Edinburgh will be leaving, which has the headcode 1S26 as it leaves later in the day.
There are some exceptions to this rule. Short branch lines do have headcodes going back on each other (such as the Cardiff Bay and Stourbridge Town branch).
jopsuk
13 May 2008
One key thing is that the letters appear more than once across the network. Indeed, from St Pancras a 1F might be headed for Sheffield, or it might be headed for Ramsgate- as the MML and HS1 are handled by completely separate signalling centres, this is not a problem.
And on the same line, it is possible for a headcode to repeat with the operational day.
LAX54
15 Jan 2008
Then some TOCs have theor own version ! on the GE.. (not Inter City) the Class 1's are simply fast Romford, and Class 2's call at Romford.
HarleyDavidson
23 Aug 2014
Yes. We have some oddities where you can & cannot have a class 1 headcode or TRN (Train Reporting/Running Number), also certain routes you can only have high numbers & others low numbers!
I'll see if I can find them.
Elecman
31 Dec 2013
Lancashire
On the WCML a leading 9 indicates a Scotland service VIA Birmingham rather than the Trent Valley
The codes aren't unique to a particular train either are they?
Can't you have a 2J14 in two different areas?
Most assuredly. I believe you can even have them in the same area sometimes! That being said trains do have their own unique number but those aren't the same as headcodes.
HarleyDavidson
23 Aug 2014
I believe as long as it's not in the same "Division" or "Zone", so you could have one out of Waterloo, but you couldn't have one out of say Bournemouth, but you could have one at say Eastbourne (just as tentative examples!).
greatkingrat
20 Jan 2011
For example 1A01 today could mean any of
1A01 0505 Leeds - Kings Cross
1A01 1219 Brighton - Victoria
1A01 1227 Kilmarnock - Glasgow Central
1A01 1828 Kilmarnock - Glasgow Central
1A01 1927 Brighton - Victoria
greatkingrat
20 Jan 2011
Some slip through the net though. If the driver of 2F04 contacts Southern control just before 8am there might be some confusion!
2F04 0532 Victoria - Ore arr 0800
2F04 0749 Victoria - London Bridge arr 0840
HarleyDavidson
23 Aug 2014
But they won't be in the same area or zone at the same time and one will be in the London/Sussex zone, the other will be in the Kent zone (Yes I know Ore is in East Sussex!), over 70 miles away, so the chances of a miscommunication are zero.
Michael.Y
14 Oct 2011
One thing to remember is that 1 and 2 relate to the class of the train, rather than the type of train. Sprinters can run as class 1s, and HSTs can run as class 2s.
TDK
19 Apr 2008
Crewe
The main problem with a duplicate headcode in the same area is the setting up of the GSM-R as duplicated headcodes are not permitted.
tsr
15 Nov 2011
Between the parallel lines
Headcodes in the Southern area often take their letters from the first unique point on the diverging route served:
1Exx : Uckfield service - first unique stop after divergence is Edenbridge Town
2Lxx : East Grinstead stopper - first unique stop Lingfield
2Cxx : Horsham stopper - Crawley
Etc.
Springs Branch
7 Nov 2013
Couple of comments:-
1) The assignment of headcodes seems to be more varied, flexible and specific to individual trains today than was the case in the BR era.
Class 1 inter-city trains almost always had their own individual train numbers, but for many years Class 2 trains usually had the same headcode assigned to every train on a particular route, and often the same headcode in the opposite direction too, a bit like a bus route.
For example, on Merseyrail every all-stations train between Liverpool & Southport and vice-versa used to be headcode 2F88. All Ormskirk trains were 2F90 and Kirkby line 2F55 - in either direction.
Today Southport trains are headcode 2S-something, starting in the morning with 2S01, then 2S02 etc. Ormskirk are 2Oxx, 2Kxx for Kirkby, 2Uxx Hunts Cross and 2Gxx Liverpool Central, each train having its own sequential 2-digit number. Much more useful!
2) For many years there was potential for confusion on the Warrington PSB panel in the Wigan area (and Wigan No. 1 box which preceded it), when every hourly Wigan NW/Liverpool Lime St DMU (in either direction) was headcode 2F50 and there was a completely different set of 2F50 DMUs running between Manchester and Wigan Wallgate or Southport via Bolton. The two 2F50s did not cross paths but did run alongside each other at Wigan Station Junction (since all Lime St DMUs used the bay platforms), and were supervised by the same signaller.
There are still a couple of 2F50s per day running all-stations Lime St / Wigan NW, but all the 2Fxx DMUs running into Wallgate are now assigned a different number series. Probably more potential for confusion nowadays with increasingly large control areas & electronic communication systems than when a small group of signallers were supervising the same area day-in-day-out and train crews were mostly incommunicado.
gimmea50anyday
8 Jan 2013
Back Cab
Etc.
1E is used for eastern region terminating stations. The high E's being from liverpool transpennine, while the low E's from London typically.
1P is portsmouth, also used for Pennine, odd pennines heading westbound towards manchester while eastbound towards york are even numbered.
1F usually indicates Liverpool with again the low F's from Euston, 1F61-80 from Newcastle while 1F81 onwards from Scarborough
1L is usually used for Liverpool-Norwich workings, also used for Waterloo-Exeter workings
2C is also used for Crewe workings
9x headcodes are utilised on anglo scottish services, particularly headline services that need special regulation. VTEC usually dont use code 9's but they are used on a few VWC and AXC services. They are also used by eurostar services.
Tyne and wear metro internally use a 3 number headcode starting at 101. Once the train leaves the internal system and start running on NR metals the service the 1 becomes an I converting the headcode to 2Ixx. This usually results in a headcode being repeated later in the day.
Safety365
8 Dec 2010
Not restricted to Scotland trains. 9S** = Euston - Scotland via Birmingham, 9G** = Euston - Birmingham/Wolverhampton, 9J** = Euston - Shrewsbury via Birmingham.
The common factor in the use of class 9 services on VTWC is Birmingham rather than the destination.
Elecman
31 Dec 2013
Lancashire
That's what I meant, the 9 indicating to the signaller to route the train via Brum rather than via the Trent Valley at a Rugby and Stafford.
kieron
22 Mar 2012
Connah's Quay
But what does the class of a passenger train relate to? A class 1 pacer is just as comfortable as a class 2 one, after all.
I suppose the distinction is more useful in areas where there's a frequent service and ample opportunity for one train to overtake another.
D6975
26 Nov 2009
Bristol
Indeed - and it actually seems to be quite accurate!
There is a significant error - class 5 trains can be passenger as well as ecs.
At the moment we've got quite a few down my way, due to the electrification works diversions we've got some unusual services running.
Take a look at Chippenham on RTT, at the moment almost everything is a class 5.
Peter Mugridge
8 Apr 2010
Epsom
As far as headcodes go, generally the fewer stops it makes = class 1, the more stops it makes = class 2.
That's an over-simplification, but it gives the general idea. It's more the stopping pattern and overall relative speed of the service than the type of rolling stock used.
Tomnick
10 Jun 2005
A passenger train absolutely should not be running as a class 5 - the Rule Book is quite clear on that one.
