How far has a 08/09 travelled under their own power ?
sprinterguy
4 Mar 2010
Macclesfield
Heaton depot to Tees Yard via the Durham Coast route for a start. That's got to be a good 40 - 50 miles.
43167
18 Jan 2010
Keighley
Skipton-Holbeck or Neville Hill 25-30miles. when Skipton used to have a pilot until late 80's.
theblackwatch
15 Feb 2006
When Scarborough had a pilot, the loco travelled from York under its own power. In latter years, an 03 was used due to its higher speed, meaning it could get to/from York quicker. The pilot there would often stay for a long period.
142094
7 Nov 2009
Newcastle
Wasn't there a branch line where the only thing that could fit under a bridge was a 08?
atillathehunn
6 Jan 2010
NL
Do you mean the Burry Port and Gwendraeth Valley Railway (spelling??)?
They had to cut down some of the Class 08 shunters in order to get through some of the bridges, I believe.
12CSVT
18 Aug 2010
An 03 has rescued a passenger train at Malton and hauled it to Scarborough (21 miles)
In 1994 a railtour ran from Plymouth up the Gunnislake branch top & tailed by 08645 and 08663.
08s may have possibly run from Carlisle to Workington (or vice versa) their own power - 33 miles.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Not as long as some of the listed journeys - Eastleigh to Clapham!? :o But there are several occasional shunter moves / swaps between Didcot & Hinksey DB yards - in fact, one did a shunt swap reccently.
Im sure there must have been various shunter swaps down in Cornwall too, although looking at some of the state of the 08s down in Cornwall they obviously havent been swapped for a while!
They ran a normal height 08 once too:
http://www.combsmr.co.uk/g01.html
Bet the Form 1 made interesting reading.;)
Oh. :lol:
6Gman
1 May 2012
Crewe 08s used to go regularly to/from Shrewsbury under their own power (often in pairs).
Crikey they made a racket!
Rich_D3167
14 Jun 2010
Hull
Up until about 5 years ago, Class 08's were regularly swapped between Immingham & Scunthorpe, & the loco's powered themselves between each location, a distance of 23 miles. With a lot of this being on one of the busiest freight networks in the country, it usually happened in the night. These days, 08's get moved by road, sadly, so it's no longer seen.
I've been told it used to happen as well between Boston & Lincoln with Class 03's & possibly Class 08's too, back when Boston & Lincoln had station pilots, of course. That must have been a stagger for the driver!
matchmaker
8 Mar 2009
Central Scotland
The 08 based at Inverness for shunting the sleeper stock must have got there under its own steam..............sorry, diesel :oops:
That's a long trip!
12CSVT
18 Aug 2010
That's a long trip!
Er, not quite. They can be towed at up to 45 mph with the coupling rods removed.
Liam
29 Dec 2010
And they are often these days moved by road. :(
There are 2 08's at Inverness. 08788 is black and 08308 is the purple/grey one.
Kneedown
29 Dec 2007
Nottinghamshire
Not sure of the mileage but we often used to work an 08 under it's own power from Burton on Trent sidings to Toton, and vice versea. Would often take a whole shift as it was hard to get a path from Clay Mills to Stenson.
ChiefPlanner
6 Sep 2011
Herts
Ipswich to Stratford E London a few times - took all night !
Ipswich to Harwich / Colchester was fairly common
curly42
23 May 2008
Used to quite often take one on its own from Gloucester to Bescot.
Now that made for quite a lengthy turn.
6S83
6 Sep 2010
When swapping the Carnforth pilot they used to do Carnforth to Carlisle, 63 miles. Crews used to swap footplates at Shap Summit.
route:oxford
1 Nov 2008
During the 60s, when much of the network was being lifted...
Wouldn't much of the infrastructure lifted with 08&09 stock hauling the equipment vans?
paulclass43
10 Jul 2012
Stevenage to London Kings Cross, hauling failed 07.05 Hull to Kings Cross HST back in GNER days. (class 08):) I was on it, took the slows to Alexandra Palace and waited for a path stood in the reception loop at Bounds Green.:)
455driver
10 May 2010
The traction motors also have to be de-meshed, otherwise they'll be spinning 300% faster then they normally do!
Which is the important bit, the coupling rods are removed so they dont suffer from centrifugal force as they are not balanced enough at the higher speed.
