DarloRich
I hope they do run this trip - Would love to be a passenger. Should be a decent trip if they put on a decent long distance run, perhaops with some long non stop portions at full bore!
That is both good and bad news, good as I'd like to be on it, bad because I have a lot of work to do and can't really afford to take a day off.
Balls to that! It's the last Valenta FFS! For your generation this is like the last Deltic, so forget the work and get out there!
Perhaps the aircons are putting him off!
The best air con you can get is sticking your head out of the window!
He's referring to an ongoing row between me and another poster about the suitability of aircons for railtours. I don't like 'em in that context, but obviously on an HST tour it's hard too see how it could be avoided!
It is my understanding that on Sat 18/12/2010 a special valenta powered train,43084 and 43123 will work sunderland-kx,kx-bradford,bradford-kx,kx-sunderland. Then on the Monday 20/12/2010 work Sunderland to Kilmarnock special to take last set up for refurb,the powercars then go to Brush for MTU's.
43465 and 43467 should return with refurbed set from Kilmarnock on Fri 17/12/2010.
this is still to be confimed but is in the planning stages.
The downside is 43084 is currently in traffic with engine isolated after throwing its engine oil out of the breather,further investigation required to see if its got piston/turbo damage.
cheers Ian
cheers Ian
Ihow can they do Kings Cross to Bradford & return if they're not cleared between Bradford and Doncaster via Wakefield Kirkgate unless they're getting special permission from Network Rail?
Sorry if this has already been repeated but does anyone know any dates and locations yet?
They're cleared now AFAIAA
Well the special between Kilmarnock and Sunderland interests me, however by using the first service from Kings Cross and changing at Newcastle for the Nunthorpe service means you get into Sunderland at 1049 and if you use GC's service direct via Hartlepool, you get into Sunderland at 1150.
I do hope there are some good times provided for the Monday outing if it goes ahead.
i bloody well hope they don't put the HST's on the west riding route..
If the HST used on the Sunderland to Kilmarnock working is stabled overnight at Heaton, surely it would be better to start the working from Newcastle rather then having to work ECS to Sunderland then in service from there?
cheers Ian
No, and someone did ask that already - three posts above yours! Once some solid gen is available I'll make sure it is re-posted here.
