London to Glasgow Non-Stop
Ianno87
3 May 2015
The (calendar) timing of this train is very clever. The huge demand for Glasgow to Euston services ahead of the England v Scotland football match at Wembley on Friday means all available spare 390s are being sent to Glasgow to work additional services to London. So the record attempt would have run anyway as an ECS, and the additional costs involved are marginal.
Ah, clever!
hexagon789
2 Sep 2016
Anyone know if this run is authorised the maximum 128 (before TASS intervention) in some places as I understand was the case with 2006 run? Or is this run officially 125 max throughout?
jp4712
1 May 2009
I'm following the train, and I see that the first train in front of it is 1H18 Euston to Piccadilly. I see that this is running 2 minutes early so I suspect its driver has been briefed to get a move on until Norton Bridge! It even departed its booked stop at Milton Keynes a minute early.
Bertie the bus
15 Aug 2014
Are you sure about that? 1Z72 and 1Z77 (11:52 and 14:00 additionals) are showing as Express Passenger on RTT and are shown as departures on National Rail. 1Z25 (the return of the record attempt) shows as Unadvertised Express on RTT and doesn’t show on National Rail. It looks like it will just be bringing back the people it took up.
Scotrail314209
1 Feb 2017
Edinburgh
1 minute late at Rugby.
I'd imagine the signallers, passengers and Avanti Management are watching this with bated breath.
EDIT: RTT just updated, currently RT.
1H18 turns right at Colwich, so less chance of conflict.
1D85 to Chester did its loop on the slow line Bletchley-Hanslope without any bother, for 1Z57 to overtake.
notlob.divad
19 Jan 2016
so, its already failed or is there still spots to make up for lost time?
Looking on RTT it set off one minute early, fell back to its alotted time slot between Wolverton and Rugby, but is back to 30s up at Lichfield. But then again I don't know what precision each of the timing points on RTT is reported at. Some seem to report 1/2 minutes, others just whole minutes. You would think it would gain on the APT-P through Norton Bridge, given the improvements there.
Almost exactly 1 hour to Lichfield - that's an average speed of 116mph. Not bad!
Mike99
4 Mar 2011
G E M L
Filmed it going through Nuneaton, but the announcement saying 11:35 Nuneaton to London Euston is cancelled overhead wires down at Stafford
jp4712
1 May 2009
My eyes are drawn to LNW 1U29 which is approaching Norton Bridge 2 mins down, and due to switch to the Down Slow at Madeley. Gerroutoftheway!
Dren Ahmeti
17 Oct 2017
Reading
The pantograph of 1U26 has decided that it wants to have a go at knitting with 25kV at Stafford P1, however 1Z57 has got an exception to run through the DFL before both lines are blocked, in order to pry the old nanny away from her tools.
Mike99
4 Mar 2011
G E M L
Flew through Nuneaton, RTT had it spot on time, so 51 and half minutes for I think 97.1 miles
dk1
2 Oct 2009
East Anglia
That’s the spirit :)
Tom
19 Jan 2008
35,000ft
The precision is poor today, because RTT is only picking up TRUST reports (roll over the timings in the Realtime column and you'll see the source on any train). The train via the open data TD feed is running obfuscated (180Q I think) so RTT can't match them together.
jfollows
26 Feb 2011
Wilmslow
That will be good given there is no Down Fast to Down Slow crossover at Madeley
Yes, I think 1U29 was booked to use the slow lines from Stafford, but presumably because it's far enough ahead of the special train it was sent fast line.
notlob.divad
19 Jan 2016
1F14 running 4 1/2 minutes late appproaching Winsford. Hold or release onto the two track section to Weaver Junction? :|
Edit: It was released now 7 1/2 down. Hope it can clear Weaver in time.
Edit 2: i assume 1S52 is scheduled to be held
Potential trouble at Crewe.
1F14 (to Liverpool) and 1S52 (to Glasgow) both delayed into Crewe, and are now on the slow towards Winsford.
1F40 (LNR to Liverpool) on the slow adding to the complexity, currently at Crewe.
PS
Looks like 1Z57 had a clear run, behind the Liverpool (turning left at Weaver Jn) and overtaking the service Glasgow before Winsford.
1F40 following from Crewe.
Dren Ahmeti
17 Oct 2017
Reading
It’ll be out of its way by Crewe even if it was to run FL.
Approach control isn’t very restrictive iirc.
1S52 will be held - it’s in its path to do so.
5 minutes pathing allowance at Winslow.
