Major Disruption At Nottingham Due To Fire (12/01)
LowLevel
26 Oct 2013
Catering trolleys and EPOS equipment might have been damaged as well.
You can live without the Dragon's Wagon but in any case Rail Gourmet live down the East end of platform 3 (that's a matter of public record as they have a sign outside their door!). EMT and Interserve Cleaning facilities of various types (not going to go into detail) are under the main station bridge. I'm being deliberately somewhat vague while trying to stay informative as I'm sure what is being posted online about this issue will come under some scrutiny!
gavin
25 Dec 2006
Hopefully its not too bad but given the main station building is over the tracks I think the potential for damage is much greater than at most stations.
Substantial damage caused from a mix of water smoke and the actual fire
Presumably the short-term fix will be a temporary footbridge of some kind (not sure how disabled access will be resolved short-term, possibly free taxis to nearby stations on demand?) to some Portakabins in a suitable area e.g. car park?
gavin
25 Dec 2006
Does Nottingham have any underpasses under the platforms like York has?
LowLevel
26 Oct 2013
No. It does have a barrow crossing which was closed last year but is apparently under repair to be reinstated all being well. That links the two islands and the medical centre car park on Station Street for emergency access. Platform 7 can be accessed via Queens Road.
kevjs
4 Sep 2013
No - but it does have a second bridge which seems to have been unaffected. Only stairs though IIRC. Bit of a trek from the main concourse to that though - but is linked to the tram at both ends - one of which sounds like it will be out of action for some time, but the Loxley House end should be okay
9 Nov 2017
"A trolley service of drinks and alight refreshments will be available on this train."
You win.
In all seriousness, let's hope it's not as severe as some sources suggest. Anyone know if larger stations such as this typically have sprinklers installed to any extent?
thenorthern
27 May 2013
There are indeed two footbridges one by the booking hall and a smaller one the opposite side of the tram viaduct.
kevjs
4 Sep 2013
You win.
Obviously hard to tell from outside too much, but the old taxi area looked fine (if anything cleaner than normal!) as did the waiting area. What you could see of the dispersal bridge was a bit darker than normal (although it appeared all the lighting was off) but otherwise intact. From what Notts fire service have described it's sounding like the area between the loos and tram/car park has been damaged, as has the roof of the dispersal bridge between platforms 2 and 4 (although the photos they've tweet suggest it's between 4 and 7).
The rest of the building is smoke damage - all the doors were wide open at lunch time as I walked pass. How much effort will smoke damage to take to sort - disposal of food/cloth and a clean or is it more involved than that?
Radio Nottingham are reporting most fire fighters/engines have now left, but they are still fighting the fire in the roof.
John Webb
5 Jun 2010
St Albans
You win.
I am not aware of any surface level UK railway station that has been fitted with sprinklers. There are several problems - firstly the height of overall station roofs takes sprinklers to the limit of their operation, the open nature of most stations allows breezes through which could deflect the heat away from the nearest sprinklers delaying operation or causing sprinklers away from the fire to activate, a 'dry' sprinkler system (ie one filled with air when not in use) would have to be used to protect against frost damage, and finally (but probably not the least reason) they cost money to install and maintain for what is a relatively rare event.
There might be better arguments for buildings with more normal height ceilings, including toilet blocks, to be fitted with sprinklers to prevent a fire spreading through such a building and to the rest of the station.
Smoke damaged buildings need deep and careful cleaning to remove the deposits, which can include some unpleasant and carcinogenic compounds, particularly if burning plastics were involved.
waynemorrell
25 Aug 2017
Inverness
Just heard on BBC Radio Nottingham, 4pm, fire still burning but some appliances have been released according to the Fire Brigade.
EMT hopes to open to some degree at some point tomorrow.
kevjs
4 Sep 2013
Radio Nottingham are reporting that East Midlands Trains are expecting to resume services at some point tomorrow to some degree
The wooden bridge that runs across platforms 2 and 4 is still on fire
I don't think you mean 2 and 4, both of these are at the far east end and a long way from either bridge. There has certainly been fire on the bridge linking the main stairs and lifts particularly around platforms 6 and 7. This has timber walls and probably roof but a tiled floor and rests on steel girders above the track. If the supporting structure is affected then trains probably can't run, but hopefully it isn't as it's a non-flammable structure and the heat tends to go up rather than down.
<pedant>
Not much from Nottingham calls at Emerson Park.
You perhaps mean EMD
</pedant>
Not sure what the builder of the class 66s has to do with it either.
They might reinstate the temporary ticket offices rather inconveniently placed to the north-east of the station site during the rebuilding, with access over the existing "middle" footbridge (actually somewhat west of the middle). But this would not be step-free. During the re-building they kept a narrow passage open through the main concourse to reach the lifts, officially only for those who couldn't manage the stairs, but at least two of the three platform lifts are in the fire-damaged area so will be inaccessible during any prolonged closure.
kevjs
4 Sep 2013
2 and 4 are what have been said on the radio and Notts Fire reports all day. Wonder if they are using wrong terminology with each physical platform are being counted as 1 rather than the number of faces (2 or 3) - e.g. platform 2 is actually 2/3 and 4 is 7?
NET now running over the top of the station, but not stopping. Reporter on Radio Nottingham describing how the bulk of the damage is to the bridge between Platform 2 and 4 next to the main building and the new build stuff linking the station to the tram / car parks. Walking past the station (Station Street / Carrington Street) there was no visible damage to the central bridge or main concourse, what you could see of the main bridge was darker than usual (possibly because the lights were off) but otherwise intact
Well, that's certainly sounding more positive !
howittpie
11 May 2012
The temporary ticket office is now home to the National Express ticket office so they may not be able to.
thenorthern
27 May 2013
Given that the station was recently rebuilt I think questions will be asked of how the fire managed to take hold so quickly and why there weren't things in place so that it could be contained much quicker.
BestWestern
6 Feb 2011
Being reported as arson.
:( Very odd time to do that, would tend to link that sort of nonsense more with late night. And the ladies toilet wouldn't be top of the list of expected locations for it either. I do hope there's CCTV available, the circumstances are rather intriguing.
Stagecoach have advised they are running double deckers in place of the usual branded single deckers on their Mansfield route this evening to assist in getting commuters home. Presumably though a good number of them never got to work in the first place.
Hophead
5 Apr 2013
According to the National Rail disruptions page, there is no ticket acceptance on local buses, which seems somewhat unhelpful. Is there a reason for this? Are Trent Barton unwilling to take displaced passengers?
Allowing people to make their own way over to Derby or other nearby stations must surely be helpful, and I'd have thought users of the Mansfield line have few other options.
OLJR
20 Apr 2011
Pimlico
I must travel from Newcastle to Nottingham tomorrow. It is extremely important so I will make the journey no matter what.
But I also have plenty of time. I am currently scheduled to travel via Newark on a 1ST Advance. If a replacement bus service from Newark is not available would my ticket be valid for Newcastle - King's Cross - St Pancras - East Midlands Parkway?
Many thanks in advance.
thenorthern
27 May 2013
Someone from British Transport Police is on BBC Radio Nottingham at the moment, they are not giving anything away but they are implying they have significant information.
DarloRich
Fenny Stratford
no idea. Keep an eye on the EMT website. I am fairly certain a chat with the guard will sort out any issues mind!
