Major Disruption At Nottingham Due To Fire (12/01)
Discussion in 'UK Railway Discussion' started by MG11, 12 Jan 2018.
  1. Mugby
    Mugby Established Member
    1,231
    25 Nov 2012
    Derby
    Ah, I didn't know that. Given that the Southern Concourse is fairly new, presumably it should be well equipped with CCTV?
  2. fowler9
    fowler9 Established Member
    7,226
    29 Oct 2013
    It is a very bold claim even without the fire being taken in to account. :)
  3. thenorthern
    thenorthern Established Member
    3,171
    27 May 2013
    Using Google Maps I have tried to create a plan of how the layout is, from I understand the fire started in the toilets which are circled in red.
  4. WatcherZero
    WatcherZero Established Member
    8,860
    25 Feb 2010
    There was a witness this morning who said they were in the multi-storey and saw smoke coming from the toilets around 6:45, so I'm surprised they are that far apart.
  5. thenorthern
    3,171
    27 May 2013
    I have checked and had it confirmed that platform 6 and 7 are the ones that are out of use, I am not surprised given that there was a raging fire directly above them.
  6. TUC
    TUC Established Member
    1,818
    11 Nov 2010
    Northern are showing the 0711 Nottingham-Leeds operating normally, although a Station Update for Nottingham says 'lifts out of order', which is technically correct but a bit of an understatement of Nottingam's problems!
  7. High Dyke
    High Dyke Established Member
    1,835
    1 Jan 2013
    Yellabelly Country
    Damn! I've got to do some work this morning...
    Joking aside. Fair credit to all involved in getting a modicum of service running at the station. I hadn't realised there were a set of toilets in that part of the station, but as they are for ladies then they're no use to me.
    Yes it is a shame to see the pictures of the damage, but thankfully it didn't spread to other parts of the station or any rolling stock. More importantly there were no reported injuries as a result of this incident.
  8. kevjs
    kevjs Member
    278
    4 Sep 2013
    IIRC "PLAT 4" is actually (bay) Platform 5. Platform 4 is further to the right on a build out.
    Actually that's not really a surprise - right of the word TOILETS is basically all open (stairs and ramps, no floor) and the car park links into that same area on the same level with a bridge - entirely possible to see from outside the loos to the car park and vice verse. All glass walls too.
    There are Gents there too. Usually quieter and cleaner than the platform ones.
  9. kevjs
    kevjs Member
    278
    4 Sep 2013
    Is it "lifts" out of order, or is the platform 1/2/3 one working? Guessing it's easier to say no lift access rather than let a wheelchair/reduced mobility user get trapped on Platform 4/5/6 after a late platform change or indeed be unable to access a service they earlier expected to be able to access after the same.
  10. kevjs
    kevjs Member
    278
    4 Sep 2013
    Does anyone know the status of the Co-op?
    If anyone is planning on picking up snacks for there journey and was thinking of using the Tesco Express outside the entrance as a plan B (should the co-op be closed) - be aware that is currently closed for a refurb. Nearest convenience store would be the Sainsbury's local at the junction of Carrington and Canal Streets.
  11. High Dyke
    1,835
    1 Jan 2013
    Yellabelly Country
    It could be that they are using the Station Street access to the station and not through the main concourse, which would mean no step free access to platforms, but as you say probably easier to advise people no lifts available.
  12. Harpers Tate
    Harpers Tate Member
    938
    10 May 2013
  13. High Dyke
    1,835
    1 Jan 2013
    Yellabelly Country
    1Y12 (08:17) Nottingham - Leeds currently in P4 at Nottingham.
  14. kevjs
    kevjs Member
    278
    4 Sep 2013
    That makes sense - The Nottingham Post have reported the Station Street entrance is opened but not the main entrance and is showing that it's still cordoned off http://www.nottinghampost.com/news/local-news/nottingham-train-station-fire-open-1047660
    Caught the end of an interview on Radio Nottingham where it sounds like the IT Infrastructure has been damaged preventing the ticket machines from being used - she also said they are accepting booking references printed or on mobile in place of tickets for those who were supposed to collect at the station.
    NET also say they are serving the station but "Passengers will be advised to use the old exit via Station Street. And no acces to the main station via the tram platform.
    " http://www.thetram.net/disruptions.aspx
  15. TUC
    1,818
    11 Nov 2010
    I wonder if it is the station electrics that have bern damaged rather than the IT itself? Anyone know whether the main station lighting is working or do they have other lighting in place?
  16. Andyh82
    Andyh82 Member
    906
    19 May 2014
    Northern are running a normal service to/from Nottingham as per National Rail Enquiries.
  17. Stampy
    Stampy Member
    211
    21 Sep 2014
    Peterborough
    Excellent.
    I'll set off soon (leave a bit earlier, just in case it all changes!!!)
  18. kevjs
    kevjs Member
    278
    4 Sep 2013
  19. InOban
    InOban Established Member
    1,075
    12 Mar 2017
  20. MG11
    MG11 On Moderation
    642
    4 Nov 2017
    According to Low Level, Rail Gourmet Standard Class trolley services are held away from the affected area, so an at-seat refreshment service should still be available. I'm not sure about First Class or CrossCountry (First Onboard) services though.
  21. MG11
    MG11 On Moderation
    642
    4 Nov 2017
  22. MG11
    MG11 On Moderation
    642
    4 Nov 2017
    Well done East Midlands Trains. I am shocked at how quickly the service has resumed and how much of the station they have been able to re-open.
  23. 221129
    221129 Established Member
    3,099
    21 Mar 2011
    That's not what was asked...
  24. 221129
    3,099
    21 Mar 2011
    Not forgetting the Fire service that put it out and Netwrok rail who did all the inspections etc... And all tge other TOCs that operate through Nottingham.
  25. Bletchleyite
    Bletchleyite Veteran Member
    26,956
    Up and down the south WCML (mostly)
    The problem (in this context) is that toilets tend not to have CCTV for fairly obvious reasons. So if you were going to deliberately get up to no good, it's not a bad place to do so, as I guess the perpetrator him/herself thought.
  26. MG11
    MG11 On Moderation
    642
    4 Nov 2017
    Of course, well done to those too!
  27. howittpie
    howittpie Member
    315
    11 May 2012
    At the station now the tvms are working but are only accepting cash. There are no toilet facilities as they do not have running water which also means no hot drinks available. There is also no tannoy or PiS screens working but seemed plenty of staff helping people.
  28. Timrud
    Timrud Member
    91
    6 Dec 2016
    Top work from EMT - IMO the best TOC
  29. MG11
    MG11 On Moderation
    642
    4 Nov 2017
    I can't imagine it was that busy in the 6th hour of the morning. There would only be a select few people entering the toilets at that time, and I imagine the concourse CCTV will cover the entrance to the toilets.
  30. 221129
    3,099
    21 Mar 2011
    And all the other TOCs that operate from Nottingham and Network Rail that actually did the work also ya know the Fire service for putting the thing out...
Share This Page
