Remaining GWR HST Diagrams
spark001uk
20 Aug 2010
I've traced a known sighting of the short 'GTi' set back through RTT, and I think this is what it appears to be working - until this Friday. Any errors let me know.
5E12 0530 XPZ PNZ 0535
2E12 0600 PNZ PLY 0803
2C43 0921 PLY PNZ 1120
2A86 1141 PNZ PLY 1339
2C47 1409 PLY PNZ 1609
2E88 1644 PNZ PLY 1842
5E88 1855 PLY XLZ 1930 FO
2C88 1936 PLY PNZ 2129 FX (FO=cl.15x)
5C88 2215 PNZ XPZ 2225 FX (FO=cl.15x)
PLY = Plymouth
PNZ = Penzance
XLZ = Laira T&RSMD
XPZ = Penzance T&RSMD (I know, I made it up for reference, but it suits!)
Mark Webster
29 Aug 2018
PLY = Plymouth
PNZ = Penzance
XLZ = Laira T&RSMD
Correct
father_jack
26 Jan 2010
2Y03 0603 BRI WSM
1A07 0648 WSM PAD
1C09 1000 PAD BRI
1A17 1230 BRI PAD
1B46 1445 PAD SWA
1L92 1829 SWA PAD
All formed 43002/43025 today.
43055
8 Mar 2018
How many Diagrams will be working on weekdays from the 25th March.
Cheers Nat
Post 702 on page 24 by Jimm says that 3 diagrams go over to IET operation from Monday (IW8, 9, 10) so possibly only 7 diagrams remain.
jimm
6 Apr 2012
Those three diagrams have already gone over to IETs - I was referring to the long-term planning HST diagrams back up the thread.
Short-term changes as a result of rolling stock reallocations due to the current closure of Whiteball tunnel for engineering work meant the end of Cotswold Line HSTs in mid-February.
VT 390
7 Dec 2018
Will there be any HST services on Paddington to Plymouth services on the 16/17/18th of April?
If so which services will they be on?
Melancholia
21 May 2016
Argleton
Someone's reported on Facebook that this Sunday (10/03/19), 1W39 1337 PAD - WOF & its return working 1P69 1627 WOF - PAD is going to be an HST. Can anyone confirm (or deny)?
Mag_seven
1 Sep 2014
here to eternity
According to RTT It appears to be formed off the stock off 1A14 10.53 Bristol - Padd
http://www.realtimetrains.co.uk/train/C55531/2019/03/10/advanced
the ECS for which comes from St Phillips Marsh HST depot:
http://www.realtimetrains.co.uk/train/C50728/2019/03/10/advanced
So it would appear to be an HST - usual disclaimers apply!
FGW_DID
23 Jun 2011
81E
I just saw that and have checked the STP for this Sunday and yes both those workings are on an HST diagram.
50Fan91
7 Mar 2011
Expect the unexpected with the weekend diagrams. We're still several weeks away from "lasts" over all routes. Due to the nature of engineering works going on and the ongoing IET / HST balancing requirements the diagrams are unlikely to look anything like the LTP for the next couple of months.
Bear in mind that for Cheltenham week, there are no additional HSTs out on Cheltenham additionals, but to free up a 9 car IET IW8 (SX) is booked to work the following. This is for one week only:
1A06:
WSM (06:18) > PAD (08:44)
1C08:
PAD (09:30) > BRI (11:09)
1A16:
BRI (12:00) > PAD (13:40)
1B42:
PAD (14:15) > CDF (16:22)
1L82:
CDF (16:56) > PAD (19:07)
1C28:
PAD (19:30) > WSM (21:53)
Melancholia
21 May 2016
Argleton
1A13 0946 WSM - PAD is out as HST, 43189 + 43098.
It then goes on to work:
- 1B35 1235 PAD - PTA
- 1L82 1611 PTA - PAD
- 1C29 2005 PAD - WSM
- 2M76 2248 WSM - BRI
And also can confirm, 1A14 1053 BRI - PAD is HST too (43156 + 43018), then onto:
- 1W39 1337 PAD - WOF
- 1P69 1627 WOF - PAD
- 1C28 1927 PAD - BRI
Peter C
13 Oct 2018
GWR land
I don't want to be annoying, but does anyone know if the HSTs have ended on the Cotswold Line (Oxford - Hereford)?
Thanks.
QuestRail
10 Mar 2019
Bristol
There has been a set swap at Paddington - 022 and 088 are now the power cars on the above.
Glad I managed to pick up the original set between Swindon and Didcot in that case. Had a slight double take when it pulled into Oxford and it wasn't either 156 or 018 leading.
Harbornite
7 May 2016
Thanks for the heads up, was a bit cheesed off as I missed the 13.37 by two minutes but all isn't lost, gonna try and get the return from Evesham.
Mag_seven
1 Sep 2014
here to eternity
Went out to see it today and yes - a HST! Probably the last one up the Cotswold Line.*
*If it isn't, please tell me ASAP!
-Peter
There was talk on the train of the same service being an HST in two Sundays time - how true this is I don't know.
Peter C
13 Oct 2018
GWR land
Oh OK. Thank you very much for this information - I'll do as much research as I can to see if it will be a HST. However, I'll probably only be able to get this sort of information from the TOPS Requests subforum on the day.
-Peter
mikeastons
15 Jul 2018
-Peter
At Shrub Hill I was told by a GWR chap (poss a driver who had just brought it from Paddington) that they are hoping Sunday 31st March will be a HST for the service as far as Foregate Street and they are retaining 6 sets to cover events like Glastonbury etc
Obviously this might change.
Here’s a pic of the rear power car 43088 on IP69 on 10th March heading to Paddington.
d
Peter C
13 Oct 2018
GWR land
d
Thanks. I'll do some research into this.
If they're keeping sets for Glastonbury, surely this means that we'll be seeing HSTs on the Cotswold Line for a while yet?...
-Peter
