Remaining LM 150s
Discussion in 'Traction & Rolling Stock' started by metromuppet, 13 Nov 2011.
Thread Status:
  1. metromuppet
    metromuppet Member
    63
    2 Jul 2010
    Sussex
    Morning all,
    As the LM farewell tour has happened, how many 150s remain in service now?
    I am hoping to nip up to the midlands at the end of the month, any garantees of 150s anywhere with LM?
    Rail Forums
  3. newtownmgr
    newtownmgr Member
    92
    2 Jan 2011
    Only guarrented 150 by end of month will be Marston Vale line. I imagine 150's will see use as required on Snow Hill lines up until timetable change but diagrams will change on a daily or weekly basis to suit requirements. From Dec the only 2 150 diagrams will be Mon-fri on New St - Hfds & Marston Vale.
    Forgot to add, I believe 150's 012,015,018 & 019 have been split ready to go to new owners. 150001 is off to Eastleigh very soon. 106 is also off in next few days, that leaves 124 & 125 due to move in Dec. 105/7/9 are staying. Departure dates may have altered as i believe LM are suffering a few teething troubles with the 172's
  4. TEW
    TEW Established Member
    4,993
    16 May 2008
    150001 is out in service today, worked the 1002 Great Malvern to Stratford-upon-Avon.
  5. trainspotter
    trainspotter Member
    397
    11 Jan 2011
    Oldbury, West Mids
    Also 2 x 2 cars work to B'ham New Street with a 3 car 170 in tow!!!!!! around 12:39 past Rowley Regis.
    Yesterday at Worcester 150 105 & 109 were stabled in the station middle road!
    None at all at Tyseley when the railtour past throught the middle road in the yard!!!!
    106 it to go north on tues/Wed as we were told by the train crew on Saturday!
    Click on the link below to all the days photos from start to finish for us!!!
  6. IanPooleTrains
    IanPooleTrains Established Member
    1,216
    21 Nov 2010
    Brereton, Rugeley, Staffordshire
    Well that went agaiinst everything I heard yesterday because I had that 001 was going Southampton way today but I guess that that is wrong information
    The remaining 150s, 105, 107 and 109 IIRC, two of them will start their new life as the Marston Vale trains and the remaining one will be working a service from BHM to Hereford
  7. newtownmgr
    newtownmgr Member
    92
    2 Jan 2011
    Just to correct previous post.
    1 x Marston Vale,
    1 x New St - Hfd,
    1 x Spare at Tyseley.
    Marston Vale unit swapped Friday Nights.
    Worcester set swapped Friday/Saturday (To Tys Fri, back Sat).
  8. 150001
    150001 Member
    492
    24 Jul 2011
    Can I just say the photos you have taken are brilliant. Thank you! I was at Dorridge when you raced through on the way to Leamington and I even got a little toot. Trainspotter
  9. TEW
    4,993
    16 May 2008
    150105 and 150109 both worked in service yesterday.
    106 will be going west not north on Tuesday morning.
  10. Offertonhatter
    Offertonhatter Member
    8
    6 Nov 2011
    Do we know what is going to happen to the ex-LM 150's?
    Much as i dislike the 150's (seating config mainly) they are still FAR better than the pacers for suburban running. I know that Northern seem to be a dumping ground (sorry, cascading....) for older units. But at least if these 150's would be a short term solution for replacing a great number of the hateful Pacers that are currently running in Manchester, until we get something new to complement the lovely 323's.
  11. GazzaB24
    GazzaB24 Member
    81
    30 Apr 2011
    The farewell is premature for 150001 it seems as it out this morning on the 06.45 Worcester - Dorridge etc with 153354 and should finish with the 17.28 from Dorridge tonight all being well.
  12. swt_passenger
    swt_passenger Veteran Member
    18,714
    Yes we do. But the information is split over about half a dozen threads started before you joined the forum, so I'll attempt a short summary.
    Having been rearranged into their original two car formations, the LM fleet of 150/1 and 150/2 has nearly all been split between FGW and Northern. LM will retain only the 3 x 2 car units as noted above in post #5.
    Of the rest, FGW get 11 units, and Northern get 18 units.
    The pair of original 3 car units, 150001/2 are currently going off lease, indeed 150002 has been at Eastleigh since the end of October. Lastly there are two orphaned carriages following accidents over the years, these have been joined as 150209, and this unit is also in store at Eastleigh.
    None of the Manchester area Pacers will be withdrawn, indeed rather more will be in service following the transfer of 7 x 142s back from FGW.
    Also leaving Northern are the 3 x 180s, and 4 x 156s which go to EMT.
  13. GazzaB24
    GazzaB24 Member
    81
    30 Apr 2011
    Seems LM still need 106 as it's out with 105 again today on the 07.09 Dorridge - Kidderminster. Also, 150001 out with 153354 on same diagram as yesterday , the 06.45 Worcester - Dorridge etc.
  14. DarloRich
    DarloRich Veteran Member
    20,031
    Work - Fenny Stratford(MK) Home - Darlington
    150125 on the Marston Vale line
  15. tom1649
    tom1649 Member
    877
    5 Jul 2010
    The LM 150s are going to supplement the Pacers to increase capacity rather than replace them, which I think is the most sensible option.
  16. TEW
    4,993
    16 May 2008
    A 150 should have arrived with FGW early this morning, could have been 124 though.
  17. james37672
    james37672 Member
    16
    29 Jul 2011
    Correct 150124 did 5z50 Tyseley- St Phillips Marsh.
  18. duffman82
    duffman82 Member
    208
    2 Jan 2010
    Wolverhampton/Liverpool
    Any chance LM will relivery these unit to match up to the rest of there fleet ?
  19. IanXC
    IanXC Emeritus Moderator
    5,645
    18 Dec 2009
    It would seem bizarre not to given the small size of the fleet and the use of one unit on Hereford diagrams where its in danger of looking very outdated and out of place.
  20. 150001
    150001 Member
    492
    24 Jul 2011
    London Midland are considering a repaint, which isn't promising! But the 150s need more a interior TLC as they look worn inside!
  21. sprinterguy
    sprinterguy Established Member
    9,745
    4 Mar 2010
    Macclesfield
    I was wondering, and hoping, if there might be a repaint into LM house colours for the three 150s that are being retained. Looks like it could be the case then.
  22. Class172
    Class172 Established Member Quizmaster
    3,094
    20 Mar 2011
    Worcs
    150 in LM livery...? That's an idea for a trainz reskin. :)
  23. GazzaB24
    GazzaB24 Member
    81
    30 Apr 2011
    150124 stabled with 150109 on Tyseley this morning (16th) so it hasn't left yet!
    150001 out again today with 153354 on same diagram as the previous 2 days.
  24. swt_passenger
    18,714
    A poster in wnxx is reporting that FGW are going to insert the two orphaned cars (currently formed up as 150209) into 150121 and 150127...
  25. Dreadnought
    Dreadnought Member
    586
    1 Oct 2007
    150109 went south through Rugby tonight, presumably a set swap is taking place with 150125 to enable that to depart to pastures new!
  26. GazzaB24
    GazzaB24 Member
    81
    30 Apr 2011
    150001 out again today with 153354 on usual diagram.
    150105/106 and 150124 all stabled at Tyseley when I passed at 08.15.
  27. metromuppet
    metromuppet Member
    63
    2 Jul 2010
    Sussex
    What is the usual diagram?
  28. Old Hill Bank
    Old Hill Bank Member
    927
    6 Mar 2010
    Kidderminster
    0647 wos-ddg
    0820 ddg-bsw
    0857 bsw-ddg
    0928 ddg-sbj
    1025 sbj-ddg
    1128 ddg-sbj
    1225 sbj-ddg
    1328 ddg-sbj
    1425 sbj-ddg
    1528 ddg-sbj
    1625 sbj-ddg
    1727 ddg-wos
    2053 wos-ddg
    2233 ddg-wos
  29. Merseyrail
    Merseyrail Member
    50
    3 Jul 2009
    Was on 150132 for the first time last night on the 19:01 Liverpool to Wigan. Looked proper shaby inside.
    Was still in Midlands livery but with Northern information posters on the walls inside. Are these going to.be a permanent fixture on my line, and if so how many of them?
  30. newtownmgr
    newtownmgr Member
    92
    2 Jan 2011
    RE 150+153 Diagram: The diagram finishes at Worcs SH at 18.58 the units then go to depot. 20.52 Wos - Dor & 22.33 Rtn. is the set that runs empty from Stourbridge Jct arriving at Worcs about 20.38 (previous working 18.50 Strat UA - Sbj Jct).
  31. tom1649
    tom1649 Member
    877
    5 Jul 2010
    They are in a common pool with the other 150s, so they could turn up on any Newton Heath diagram I would have thought.
Thread Status:
Share This Page
