Strathspey Railway Extension
fraser158
7 Feb 2011
Inverness
The Strathspey Railway are one step closer to Grantown-on-Spey.
http://www.railstograntown.org/page.php?domain_name=railstograntown.org&viewpage=news
The Strathspey Railway Charitable Trust is delighted to announce that a major step in the “Rails to Grantown” project is planned for mid-February. A steel bridge structure, donated by Network Rail in 2008, which used to cross Merry Street in Motherwell will be re-installed over the River Dulnain to carry the Strathspey Railway further towards its Grantown destination. A massive rail-borne Kirow 1200 crane, operated by Colas Rail, is coming north to lift the bridge beams into position. 39 Engineer Regiment based at Kinloss, plan to assist with later bridge work. Once in place, Strathspey Railway staff and volunteers will make plans to lay track across the bridge and over the Muckrach Estate lands towards the planned tunnel under a re-aligned A95. Grantown will then be just one mile away!
chris89
21 Dec 2009
Edinburgh
Great News & Thank you for posting.
Really got to visit the Strathspey again, been far to long.
Chris
ianhr
17 Sep 2013
Excellent news, this means the Strathspey is within sight of running between two fair sized towns and with a main line connection.
clc
31 Oct 2011
That is good news indeed. Am I reading this article correctly, are they going to have to dig a tunnel under the A95 ? if so that will be a huge project.
Transport Scotland will build a bridge for the railway to run under as part of a scheme to realign a section of the A95. It's a few years away yet.
43167
18 Jan 2010
Keighley
Been twice, last time after the last time it got extended and it was a option on a Pathfinder spinner, we had 31327.
St Rollox
2 Jun 2013
Great to see the bridge being put in place and BBC Scotland plugging it on the local news.
Fair play to all involved.
furryfeet
17 Apr 2008
What is the length of the steel bridge structure that will span the River Dulnain ?
the strathspey railway state on their web site that the "gap" is 80 feet. I seem to remember that the length of the girders when they were in use at Ravenscraig was 27 metres, although the web site does not state as to whether the girder length has been altered during the refurbishment. I know that there have been some alterations, since the skew on the Dulnain bridge differs from the Ravenscraig installation.
66C
8 Sep 2013
Was a double track bridge at Merry St If I remember correctly it was a 9ft skew. It has gone back in as a single track bridge on the opposite skew using the two outer girders. The bridge decks were held in with 1000+ 1" dia bolts.
Mtough
2 Mar 2014
80 ft gap in old money
26.2 metres clear span
6 new web plates 3 per side girder had to be added to allow changed skew to fit ie very little work but this was identified before SRC agreed to take bridge in 2007 ..whilst it was donated SRC had to pay for it's taking down & movement to Aviemore in 2008
548 bolts needed to reconnect it all new ones being used
centre girder was not used & was scrapped
sorry 26.2 overall
24.2 clear span
25.3 between centres of bearings
