Is that the number for all depots or just New Street?
I have heard that is how many they will take for New Street but how reliable that is I can't be sure.
This is my first ever assessment so I need to start doing some research ASAP!!
Well done for getting through. However other than the info the TOC send you, there shouldn't be any need for further "research". Its an aptitude/experience test rather than a knowledge based one. Those that are suited to the role should pass with ease. Just ensure you attend having had plenty of rest and get there with time to spare dressed in smart and comfortable clothing.
Good luck.
Good luck.
They haven't given me any information.. just a confirmation email for the slot I've booked. Well it can't hurt to get some practise at these aptitudes tests.
Do you know what tests you will be doing though?
Congratulations!
Youngbuck. You mind sharing how far from Bletchley you are? Here's me hoping its just that I'm quite a long way outside of the 30 mile radius for Bletchley.
I live in Wales haha
In that case I really need to get you to look at my application lol!
455driver, sorry for my ignorance, I am new to TOC abbreviations.
What would the WPB stand for?
I was wondering if I would be at a disadvantage by not applying for more than one depot? I am a strong believer in not following application descriptions (Only apply for one depot as an example), could have a negative effect on my application.
Regards
I've always thought that a commitment to relocate should be seen as a positive on an application, shows the extent to which one will go for the role.
That accent works wonders!
On a serious note, I honestly thought mine was a strong application. I'm 25, my first job was working with heavy plant excavators, I was then an apprentice in electronic engineering for BAE Systems, I've spent 6 years as an Electromagnetic Compatiblity engineer, and was in the TA Royal Engineers for a couple years (EOD search and disposal). Went grammar school and got mostly As and Bs too...
Maybe I wrote too much, or not enough of the right stuff. I don't know! If its an automated sift I guess it doesn't really understand what it is and is just looking for key words.
If anybody out there could take a look at my application and give some positive feedback please let me know! I will but you a virtual pint (after your shift )
Why would a TOC take an applicant with an equal rating that needs to relocate over someone living close by? In reality there is a policy in this order for suitability considering location, the list below is in order of preference:-
1. Able to walk to work
2. Able to cycle to work
3. Able to motor bike to work
4. Able to drive to work
5. Relocate
6. Taxi or public transport only
What level of detail can TOC's see regarding the results of the train driver tests a candidate has taken? For instance if you have already passed and are applying to another TOC, when they check your results on the OPC database do they just see either a pass or enhanced pass or do they see actual test scores?
Also, you mention about the order of preference for location, which makes sense. However, at the application stage, if you have someone who has previously taken the tests and achieved high scores and could relocate straight away, would they have a higher chance to progress than someone who lived locally and looks good on paper, but hasn't taken the tests yet?
I was also unsuccessful! Congratulations YoungBuck!
I wasn't holding my breath for the Bletchley position, I am 5 miles outside of their catchment area and also do not hold a mechanical/engineering qualification. Fingers crossed for Leamington Spa (which only asked that you were mechanically competent rather than holding actual qualifications...).
Could I just ask why they would require a mechanical/engineering qualification for a driver position? Surely the last thing they want in the event of a breakdown is the driver jumping out of the cab and 'giving it a bash'? Is it more to do with ensuring someone has the ability to carry out safety checks to the highest standard before taking the train out?
Going back to the application, I really felt once you've filled out the majority of the usual info, that those last 5 questions were the deal breaker. I ended up spending 2+ hours just on that section to ensure that I'd answered exactly what they were asking. I chopped, changed, deleted, rewrote so many times, it was driving me mad by the end as they seem so simple on the surface!!
TOC's can ask for any detail they need from previous results.
When there is a recruitment drive by a TOC they will take into account candidates who have passed the tests but will always have new candidates take the tests and if they pass they will have preference over people who need to relocate. Only if you have excellent results much better than others then the candidate who needs to relocate will get the job. If there are candidates with similar results then the location is a huge factor.
Hi,
I have been successful at the application stage. Have booked my interview at Bletchley. Could anyone give me any advice on the interview. I'm not sure whether it's the structured interview or the driver manager interview? Any help appreciated
Thanks, is it possible for candidates to obtain detailed results from the OPC for their own tests? I would be curious to know my detailed results as it may give me an idea of how I may compare to other candidates. All I know is that I have an enhanced pass in each test, but I don't know what that means. Is an enhanced pass over 70%, 80%, 90%?
You need to change your forum name
--- old post above --- --- new post below ---[/
And I think you need to learn to read a question properly to understand what it truly meant.
You've been getting a lot of stick from people not reading that properly.. maybe you should rewrite it and take out what's written in brackets.
When you log on to the website it asks you to book an appointment with the assessments centre, so I think the first stage is completing the aptitude tests then if you're successful an interview will follow.
