XC Voyager Refurbishment
irish_rail
30 Oct 2013
Plymouth
Has this started to filter through to capacity increases on other diagrams yet?
There seems to be a drop in capacity on SW to NE, EXCEPT on a couple of selected trains that are now pairs of voyagers. Great if you can be flexible and purposely travel on one of the 3 or 4 trains a day that are pairs, but not so good if your previous 5 car set is now a a 4 car set (as seems to be the case with most SW to NE services now).
Killingworth
30 May 2018
Sheffield
Not so good if you select a 9 car train and carefully take up position in the rear 5 car unit - that is then removed at Derby and you have to stand in the leading 4 car like a sardine.
takno
As delightful as all of this sounds, I think I'm just going to keep flying to Bristol instead. Hopefully in a year or two they might have faintly got their act together.
Trainman40083
29 Jan 2024
Derby
Maybe they will reintroduce the pre COVID timetable in June 2025, with more double sets on NE/SW services.
18 Mar 2007
North Oxfordshire
Or upon arrival, you find the front set locked out of use due to lack of staff... but nobody bothered to tell the waiting passengers and they have to all go running down the platform!
The previously discussed track access application lists all the changes including the ‘long distance routes’ having a capacity increase in May/June 2025. “Significant uplift of seating capacity on the long-distance network.” However it will not be exactly pre 2020, as it is also known (from the ECML thread) that on the Reading to Newcastle route some trains will not run north of York, it is also known that the Newcastle - Southampton extensions are no longer in the track access. (pdf attached below.)
  • XC TAA Form P.pdf
Goldfish62
14 Feb 2010
Yes indeed. It was reported in Modern Railways a few months back that XC are intending to reinstate the Reading - NE services almost, but not quite, in full from May, giving that much needed restoration of two trains an hour on the Reading - Birmingham section.
sprinterguy
4 Mar 2010
Macclesfield
There are two fewer 4-car diagrams on the South West - North East route since the summer timetable started: One has become a 5-car and the other a double set. In fact, looking at Realtime Trains I think there's another diagram that was a single set south of Bristol that's currently a double all the way through to/from Plymouth, which would make it three fewer 4-car workings as far as the South West is concerned. It only requires a perusal of Realtime Trains to get an indication of the typical unit allocations for any given day: From Plymouth, single 4-car units on SW-NE services are very much in the minority.
Were there more double sets pre-Covid? The fact that Newcastle - Reading was hourly at the time, requiring more single sets than now, suggests that there would be fewer, even taking into account the couple of HST diagrams that existed then. Especially now that there are three extra trains to play with.
Seems so, there are definitely a couple of extra double sets kicking about and some services that I used to know as 4-car workings are regularly running as 5-car since the timetable change.
irish_rail
30 Oct 2013
Plymouth
This doesn't seem to be reality though, just because something is booked a longer train, doesn't mean it always materialises. Certainly fewer 5 car sets around down here since June. Yes there are more double sets, but there are in reality more 4 car sets than before. If you are not flexible with when you can travel , a 4 car train is really quite unpleasant. Looking at a random day last week on RTT, it seems there was roughly a 50 50 split between 4 car voyagers and longer 5 or 8 car sets. Great if you can steer your journey toward the longer train, but if you can't, the 4 cars are just no good down this way anymore.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
I can only remember one double set pre-Covid, 1S49 1127 Plymouth to Edinburgh, with the addition of one summer timetable period when 1V54 0633 Dundee to Plymouth/Newquay ran as a pair of Voyagers instead of an HST.
-Colly405-
25 May 2018
Stoke Gifford
Wasn't 1S35/1V66 a double set pre-Covid? Of course, it still is booked to be - even had a 10-car on it on July 4th, with the rear car locked out northbound due to platform lengths (1st class). The front unit was ex-Avanti (114), and the catering announcement was "shop in the front unit, at-seat trolley in the rear"... One 1st class carriage and 8 standard seemed a good balance, in retrospect!
sprinterguy
4 Mar 2010
Macclesfield
Yeah, that 1S49 rings a bell for the sort of time of day I'd be travelling. I couldn't recall witnessing many double sets on NE-SW, but then I did tend to aim for the HST services when looking for a longer train where possible.
virgintrain1
29 Jul 2011
Both singles pre COVID.
1S33 was a double and 1V64 then used to split at Derby.
XC did have some Friday only double sets. That were made possible by Friday only HST diagrams.
occone
8 Apr 2023
Manchester
If XC could just tighten up the panels that would be a splendid start, the panels on this voyager seem to be competing as to what can rattle and shake the hardest; I think the window blind by the emergency exit is currently winning.
Gagravarr
3 Mar 2016
Got one of these just now, realtime trains says 221116. One big snag - no wifi. Is that normal for these transferred units?
Otherwise it's very nice, feels brighter, seats and carpet in much better condition etc. Just a pain that there's no wifi and mobile reception remains terrible due to the window coating
TheGuy77
21 Apr 2024
Earth (obviously)
Did you take pictures of it? It could just be an ex-avanti unit which they refurbished in 2020.
fgwrich
15 Apr 2009
Hampshire
116 is one of the ex Avanti units, though I’m not sure if they’ve switched the WiFi over to XC yet. It was trying to use Avanti’s WiFi in Hampshire when I last used it.
Then again, I was in native 221120 yesterday and the WiFi wasn’t working in that either.
Killingworth
30 May 2018
Sheffield
Not unusual, very poor at the best of times. Something to do with the glass in the windows creating an effective Faraday cage.
voyagerdude220
13 Oct 2005
Please could someone confirm which Avanti 221s have recently transferred to Cross Country? Are any additional sets being transferred this year?
Lewisham2221
23 Jun 2005
Staffordshire
Can't see confirmation elsewhere in this thread; Alstom will refurbish the Voyagers at Litchurch Lane, starting 2025.
Derby train maker Alstom has signed a new £60 million contract to refurbish CrossCountry’s Voyager trains over the next two years. The work will see the trains receive an interior refresh – including new seats and tables – while their exteriors will be repainted in CrossCountry’s new livery.
Work on the the latest contract for the Voyager trains, which will take place at the company's Litchurch Lane factory, will be offered to existing staff but it is likely that additional recruitment will take place – particularly for specific skillsets.
Design work will commence immediately, with physical work in Derby set to commence from next year.
Blindtraveler
28 Feb 2011
I hope that they propose strip out and replacement of least one of the unnecessary accessible toilets, two on the five-car units and addition of more seats or luggage racks in their place, obviously, the accessible toilet in first class and in standard near the wheelchair space will need to remain
Wolfie
17 Aug 2010
Genuine question as l don't get to use XC that often. To what extent is the current toilet provision driven by the length of journey and current depot set-ups? How often are toilets out of use due to full tanks on XC? Would such a removal pose future issues?
It would be bloody unfunny having a train run from the South of England to Scotland with no functional toilets for a large part of the way.
In any event l seriously doubt that a total £60M refurbishment budget anywhere near covers removing toilets.
jojoseph72
8 Jul 2020
Not sure if anyone has seen this (if it has sorry for the duplication), but a tweet by Tim Dunn lays out the details of what we can expect from the refurbishment and a little video of the mock up interiors.
takno
The aim isn't to get rid of toilets, it's to replace at one of the 3 accessible toilets with a non-accessible toilet which could take less than half the room in the cabin. Nobody has figured out a way to store luggage below the sole-bar yet, so presumably the space for 3 toilet tanks will still be there, and the tanking setups at depots would be unchanged.
Lewisham2221
23 Jun 2005
Staffordshire
I agree, it's pretty much certain that £60m won't include any significant toilet work.
Completely removing a toilet probably wouldn't be a great idea either. Reconfiguration of 1 or 2 into smaller, non-PRM toilets might be possible, but I would imagine also costly and would probably only practically free up space for another luggage rack (not the worst idea for XC, but still...)
Disappointed to see nothing being done about the overhead luggage racks which are way too small. The design on the 222 is much better.
They also don't appear to be replacing the reservation displays which don't work most of the time.
