T
Tom
Guest
If you're tight fisted, yes
That particular example? No, unless you wanted a break of journey at Swindon on the outward leg and wanted to return within a month.Bloody things.
Tried this splitting thing..
Burnham-Cardiff SVR: £35
Burnham-Swindon: £16.50
Swindon-Cardiff: £16.50
Total £33
Is it really worth it to save just £2?
Cheaper than £1.95?An off-peak return trip to Heathrow Airport from STP on LU on Oyster is cheaper than a travelcard, even with a railcard. In fact, this is the case for any return journey between any two zones. Also, a zone 1 & 2 Oyster travelcard is cheaper than a paper travelcard - it would be interesting to see the zones actually travelled by those who have entered London from further afield on NR.
I wouldn't know as I would by walk-up tickets for that price.For instance, a Grantham - London ODT (on YP) is £21.20, a CDR with the same restrictions into London Terminals is £17.80, a zone 1-6 travelcard is £6.90 (paper), or £6.40 (cap) (Oyster, no NR*). Therefore, if you buy your travelcard or use Oyster in London, you pay £24.20 (or £24.70) in total. You only pay £3.40 for your travelcard if you buy it combined with your ticket.
The Oyster cap is £4.40. Also, a CDR is a return, not 3 different journies.If you are only doing a zone 1-2 journey, generally you will do 3 journies in London (this is an average based on statistics). Therefore, this is a minimum of £4.50 on Oyster. So even then, you are paying more than you need to if you buy a CDR. The only way you do get a cheaper journey (by only 40p) if you only do 1 return journey across zone 1 by Tube.
A cash single is £4.Your Heathrow airport theory is incorrect, as most people would be going to Heathrow Airport and would book their tickets ahead, and therefore take advantage of GNER Advance tickets, hence getting a discount anyway. A cash single to Heathrow Airport from KXSP is £4. So... think again!
You what??!?!! Where are you getting your info from?GNER Travelcards should only be valid for zones 1 & 2.
Sorry if this is considered off topic as it's not a trick, but on the subject of fares, why , like Peter B said earlier, are GNER Value fares so expensive?!
An example is Leeds to London-
Cheapest MML single, when available is:
£7 Standard Class.
£14 First Class.
This is compared with GNER's option of:
£10.65 SC (ok not a great difference, but...)
£32.50 First Class- over double MML!
I was personally planning on doing York-Kings Cross- St Pancras-Derby-Bristol over Easter, but because GNER isn't the cheapest TOC out there, i'm going to save the £18.50 difference and use it elsewhere.
Never thought about doing York - London direct with MML?
ok, so when you go to London you only do a couple of zone 1/2 singles? Well, maybe you're one of the few people who doesn't benefit from an inclusive-travelcard, but for most of us it's a no-brainer really.Now I don't go to London regularly. However, I still recognised that investing £3 in a card would be a good idea as I would only be using it in zones 1 & 2, it would still be cheaper than a Y-P T/C.
Evil_hippo lives in Appleby and always tells us how much better value the Appleby-Penrith bus is than just about any other bus in the country! So it may be worth trying the bus? Also I think Mr Hippo knows a few good fare combos to Penrith so may be worth sending him a PMI wish I could find the absolute cheapest way to get from Southampton Central to say Penrith North Lakes as against say Appleby, where my HQ is based. It's a taxi ride, say 13 miles, from PNL to Appleby. Is there any advantage in splitting or going by listed route? ?
OK, you've gone off-topic now by talking about advance purchase fares.Sorry if this is considered off topic as it's not a trick, but on the subject of fares, why , like Peter B said earlier, are GNER Value fares so expensive?!
£7 Standard Class.
£14 First Class.
Day trip yes, just had a check again on the train line and it shows swindon-cardiff for £9.65, why it didnt show it first i dont know.That particular example? No, unless you wanted a break of journey at Swindon on the outward leg and wanted to return within a month.
If it was a day trip you'd get a CDR combo which is approx £22 which would save approx £13 (or, in other words, effectively child rate compared to a through saver).
It isn't expensive but partly because of demand, partly because, unlike some of their rivals they actually seem to open at T-10 weeks - availability seems to be generally less.Anyone who thinks £10.65 York-London (or £9.50 if you book online through GNER) is expensive needs to have a reality check. That fare is cheaper than any ordinary ticket you could buy for that journey around 20 years ago - it is incredibly good value. If £10.65 for 189 miles is expensive, what is a local bus journey at around £1.30 for 2 miles?
It doesn't matter. An Oyster Z12 travelcard cap is still cheaper than a Z1256 travelcard.ok, so when you go to London you only do a couple of zone 1/2 singles? Well, maybe you're one of the few people who doesn't benefit from an inclusive-travelcard, but for most of us it's a no-brainer really.
No probsDay trip yes, just had a check again on the train line and it shows swindon-cardiff for £9.65, why it didnt show it first i dont know.
Cheers tho, I'll amend this saturdays plan to include a break at swindon to grab the additional ticket.
Burnham-Swindon: £16.15 (just checked again)
Swindon-Cardiff: £9.65
Total: £25.80
Much better.. I'll remember that
Actually, you can discount the cheaper fares on that basis. Why? Because the only advance fares that exist to York on MML are "MLL Only" tickets. "MML + Connections" do not exist for that flow.I was aware that MM only ran 2 trains/week but you shouldn't really be discounting the cheaper fares on that basis. It might still be cheaper to change at Leeds or Sheffield.
Opening earlier for bookings surely gives more people the chance to book. If someone leaves it 2 weeks before to book, then all the cheap tickets may have gone, but that doesn't mean availability was low. Many people request to be emailed when the cheap tickets go on sale and snap them up quick. I've had no problems getting £9.50 tickets for large groups when I book on the day they go on sale. The fact is loads of these tickets are available, and they are extremely popular - and for good reason as they are excellent value for an excellent service!It isn't expensive but partly because of demand, partly because, unlike some of their rivals they actually seem to open at T-10 weeks - availability seems to be generally less.
Wrong. £4.60 versus £1.95 (Y-P) / £3 (Adult) taking the Peterborough example.It doesn't matter. An Oyster Z12 travelcard cap is still cheaper than a Z1256 travelcard.
Cheers I'll grab em tomorrow from Slough T.O. I can buy CDRs for next day can't I? If not I'll work out a plan to include the breaks to grab tickets..No probs
As a general rule of thumb, on FGW Didcot is a very useful point to split tickets, although you restrict yourself to trains that call there:
Burnham-Didcot £7.60 CDR
Didcot-Swindon £4.95 CDR
Swindon-Cardiff £9.65 CDR
Total: £22.20
I am now considering banging my head against a brick wall :P
For York or elsewhere I was thinking more along the lines of CDS/R to Leeds/Doncaster or Sheffield and then AP to London.Actually, you can discount the cheaper fares on that basis. Why? Because the only advance fares that exist to York on MML are "MLL Only" tickets. "MML + Connections" do not exist for that flow.
Leeds/Doncaster do get "MLL + Connections" tickets (specify 'via Rotherham' when booking on thetrainline to ensure maximum availability/flexibility, then collect from FastTicket, your ticket is then "open" between Sheffield and Leeds or Doncaster )
What I was trying to get at probably is that GNER tickets seem to sell out earlier, because of the factors already mentioned.Opening earlier for bookings surely gives more people the chance to book. If someone leaves it 2 weeks before to book, then all the cheap tickets may have gone, but that doesn't mean availability was low. Many people request to be emailed when the cheap tickets go on sale and snap them up quick. I've had no problems getting £9.50 tickets for large groups when I book on the day they go on sale. The fact is loads of these tickets are available, and they are extremely popular - and for good reason as they are excellent value for an excellent service!
Tom convieniently picked an example (Grantham) where a CDR/Travelcard ticket was available and it wasn't terribly far from London. We need to remember that CDs or Travelcard-inclusive tickets aren't always available from all origins, on all operators and not all tickets can come with LU travel included - Tom's example fortunately did. We have to look at passengers from further afield having to purchase LU travel seperately, whether it be at the origin station, or when they arrive in London, but not inclusive of their NR ticket to London Termini.Wrong. £4.60 versus £1.95 (Y-P) / £3 (Adult) taking the Peterborough example.
According to this the Zone 1/2 cap for an adult is £4.60. This is 50p less than the cash Z1-2 travelcard (£5.10) and only 20p less than Z1-6 from within the zones with a railcard.
But, as I said earlier, it costs more for Oyster than an inclusive travelcard (£1.95 in the example from Peterborough), which is what we are talking about.
In summary:
If travelling to London from outsize the Zones, and you require travel around London (even in just zones 1 and 2), then it is cheaper to get an inclusive travelcard. It is not cheaper to split it into a CDR + Oyster.
