End of Yellow Front Ends?
Karl
16 Aug 2011
Bamber Bridge
I noticed this from JaJaWa in another thread and being totally unaware of the change wondered if anyone else could add additional information as to how this came to be?
It's going to be strange to see units and locomotives without their traditional yellow fronts. I'm undecided what to think.
With no more yellow front ends from January, I presume it will look something like this (excuse the awful Photoshop!)
AM9
13 May 2014
St Albans
Not really. Many here remember trains without yellow fronts when they actually looked better. The speckled squashed fly and salt/oil smeared front wasn't so obvious and any styling/livery schemes looked much better.
I would expect the current craze for white base-coloured stock to fade away and schemes to make better use of the new freedom.
driver9000
13 Jan 2008
It only applies if a certain level of front lighting is met which I understand existing stock doesn't meet so they will require yellow ends. The only loco that meets the new regs is the 68 as far as I'm aware.
DarloRich
Fenny Stratford
they might look better but the Yellow end is easier to see at track level. Personally i don't care about the aesthetics as long as i see the front of the train coming!
sprinterguy
4 Mar 2010
Macclesfield
This was previously discussed within the thread announcing the livery of the Crossrail stock. Here is the relevant part of the standard:
http://www.railforums.co.uk/showpost.php?p=2368312&postcount=11
I understand that this is shall no longer be required due to improvements in headlights. I will try to find a link to this information.
Edit: I believe this is it, from this document
Originally Posted by RSSB GM/RT2131
Historically, RGS GM/RT2483 required the front of trains to include a yellow warning
panel, in order to increase their visibility to members of the public and trackside staff.
The LOC & PAS TSI does not have a requirement for the colour of the front of trains,
thereby giving the transport operator a choice. The presence of a head lamp meeting
the requirements of the TSI is considered to give a sufficient visual warning that a train
is approaching; whilst the combination of that head lamp along with the marker lamp
layout is considered to make an approaching train identifiable as a train.
BestWestern
6 Feb 2011
It does seem a tad disingenuous having some trains with yellow front and others without...
Domh245
6 Apr 2013
nowhere
Which is why until there is an entire fleet of trains with compliant headlights (class 345), you probably won't see liveries without it
dave87016
9 Dec 2008
Lancashire
I got told off my friend who works for TPE that the yellow at the front on class 185's is also used as a indicator of where the first class carriage is. as they can be at either end of the train
221129
21 Mar 2011
Sunny Scotland
How does that work if both ends are yellow? :roll:
sprinterguy
4 Mar 2010
Macclesfield
That would be the yellow strip on the bottom of the coupler at one end, not the yellow warning panel (which features at both ends out of necessity).
dave87016
9 Dec 2008
Lancashire
on the TPE 185's I believe they are only yellow at the front of the train of one carriage ( where the first class compartment is)
Thanks Sprinterguy I failed to clarify the correct part as per my post thanks pal ;)
21 Mar 2011
Sunny Scotland
As SprinterMan says, you mean the little stripe on the coupler not the warning panel on both ends of the train.
ComUtoR
13 Dec 2013
So much for staff safety being the number one priority.
Why ?
Staff are still protected and it comes with a caveat that headlights meet a higher standard.
TOWS
Lookouts
Possessions
Blue fencing
restricted speeds
Late notice case
Not not forgetting the high vis clothing or the Driver's requirement to blow up when sighting people within the boundary fence.
I'd have expected many recent classes such as 387s and 379s also have compliant headlights. They are surely only what has been generally fitted for the last few years, having followed this subject since it was first mentioned.
Presumably representatives of people directly involved have already had an opportunity to respond to the official consultation, or are we to believe RSSB ignored the responses?
185
29 Aug 2010
I see an issue here. Headlights & reds do fail, it happens even with newer types of lamp.
If a headlight on a non-yellow end set fails and a temporary battery operated bardic/equiv is slung on the front, how, even with a threshold-reduced speed limit, is that 'as' safe?
Trog
30 Oct 2009
In Retirement.
Why ?
TOWS
Lookouts
Possessions
Blue fencing
restricted speeds
Late notice case
The yellow ends are easier to see than headlights in some conditions, particularly heat shimmer. Also as painting the front of the train yellow costs nothing as it would need painting anyway. Even if the benefit is only small it must be worth doing.
ExRes
16 Dec 2012
Back in Sussex
Seems to me that it's all down to one choice, are we interested in safety or aesthetics ?, for me there's no choice whatsoever, safety comes first every time
ComUtoR
13 Dec 2013
They fail all the time.
I know the rules and do not see an issue when running without headlights. (its quite restrictive) Is it "as" safe. No, but the increased risk is minimal and if it was a non yellow end I would hope that additional restrictions are required without headlights. I don't support the change but I am highly aware that staff on the line are well trained professionals and the procedures that are in place are safe.
The protections for those on the line are quite high. The lookout does a very good job and is often in a position of safety.
Crossover
4 Jun 2009
To be more precise, the electric box cover :)
As an informed outsider, it does seem a little retrograde...
Ploughman
15 Jan 2010
Near where the 3 ridings meet
Why ?
TOWS
Lookouts
Possessions
Blue fencing
restricted speeds
Late notice case
Do IWA's still exist?
Because I frequently used to out and about on my own.
Responsible for my own safety.
Yellow ends are better for visibility especially on an undulating line when the lights may be down in the dip.
455driver
10 May 2010
Why ?
TOWS
Lookouts
Possessions
Blue fencing
restricted speeds
Late notice case
What about the weekly track inspection carried out under red zone working and by necessity the staff could be anywhere on the route!
NSEFAN
17 Jun 2007
Southampton
Isn't one of the requirements for new stock to have lights at the top of the vehicle for this very purpose? If anything that aught to be more visible than the yellow warning panel closer to the floor of the vehicle.
Blamethrower
13 Oct 2014
Bedfordshire
Yellow fronts are an outdated requirement for a train in my opinion. With new lamps and increased safety requirements, clearly they're not needed.
Trains for me aren't about just the engineering, aesthetics matter too. 395s look great as yellow goes with blue, and 373s and 374s for the same reason. Most other liveries look terrible with a yellow patch on the front. Virgin got creative with the 390 and made a hideous yellow smile, but I guess it matches the childlike interior.
Let's take the opportunity to design some truly beautiful trains without being hamstrung by ancient, outdated safety requirements
455driver
10 May 2010
I take it from your post that you work trackside on a regular basis and have first hand experience of having trains bearing down on you at 100mph*!
*other speeds are available. ;)
Marklund
18 Nov 2010
Precisely. Staff can be rapid responded anywhere.
As I've said in the previous thread, angle of view can make a huge difference, and also as Trog has pointed out heat shimmer too.
ComUtoR, track staff are under bombardment with rule changes eating away at safety. SWL being the latest farce.
COSS + 1 needs no Site Warden when working Green Zone, but all it takes is a slight lapse in concentration to step back from a location case closer to the line than what you perhaps should be.
Every tool in the box should be deployed to help keep staff safe.
Removing yellow warning panels is simply a case of aesthetics over safety.
Kentish Paul
25 Apr 2012
Ashford Kent
Not sure. I used to be one. I always looked in the up and down direction every 10 /15 seconds or so. Always saw the train before the yellow bit on the front. Even working in possesions or with lookouts I always kept looking myself. I remember one Sunday morning having a possesion of the down line east of Ashford station (pre HS1) and looked up to see a Eurostar coming towards us on the down. Told the COSS only to see the Eurostar cross to the up track and pass us wrong line with a friendly wave from the driver despite having to drop from 90 to 40mph.
Goldfish62
14 Feb 2010
In Belgium generally SNCB domestic trains have yellow panels, but ICEs, Thalys and TGVs don't. Some SNCB locos/MUs which haven't been painted for about 600 years have mere yellow whiskers.
