GN Class 717
Discussion in 'Traction & Rolling Stock' started by choochoochoo, 1 May 2017.
  1. Railperf
    Railperf Established Member
    1,275
    30 Oct 2017
    Any 717s out today?
  2. choochoochoo
    choochoochoo Member
    589
    6 Aug 2013
    None on bank holidays.
  3. dlj83
    dlj83 Member
    120
    11 Mar 2012
    Are any planned to operate tomorrow?
  4. swt_passenger
    swt_passenger Veteran Member
    20,423
    No. As was just explained in post #2100
  5. 717001
    717001 Member
    108
    4 Aug 2018
    GN have said there won’t be any at weekends until after signalling work is done - likely to be end of May.
  6. Class315
    Class315 Member
    239
    9 Feb 2008
    The signals are due to be moved, the first/second week of May & belize for the auto changeover fitted at Drayton Park at the end of May.
    I would imagine weekend working will be introduced from the 19th as more depots get diagrams which incorporate 717 work & more drivers are passed competent.
    Don’t see what the rush is to get them into service on the weekends personally!?
  7. Robert Carroll
    Robert Carroll Member
    18
    24 Nov 2017
    By yesterday afternoon, I think only 003 and 007 were left standing. I went to Moorgate to catch the 1450 to WGC, which was cancelled, but boarded 003 an hour or so later at Finsbury Park, then saw 007 at Alexandra Palace.
    https://flic.kr/p/24Y59a8
    https://flic.kr/p/RPg9jt
    Didn't see any others.
    The ride on 003 was very good.
  8. whoosh
    whoosh Member
    564
    3 Sep 2008
    On 313s, there is a switch - crew doors are switched out of the interlock circuit in 'Guard' mode. In DOO mode they are switched in. This is so the the cab doors are securely closed with the sole member of staff safely on board.
  9. 387star
    387star Established Member
    5,498
    is the pis unit the same as a 700
    On a 700 internal screens may display 'not in service' and not clear even when a pis code has been entered unless you press a string of buttons... but with no repeater display in the cab the driver may not know
  10. Tony2
    Tony2 Member
    55
    7 Apr 2019
    At least 005 007 009 and another I managed to miss running today
  11. K.o.R
    K.o.R Member
    409
    6 Dec 2017
    The Southern 313s run with it switched in, despite having a guard - the light doesn't go off until the guard's door closes.
  12. choochoochoo
    choochoochoo Member
    589
    6 Aug 2013
    The PIS seems to run the same way on both 717/700.
    For such a modern train, they really didn't give the PIS much consideration. Or at least the driver's operation of the PIS. It's operated in the same way as it is done on a 365. That is apart from the initial setup when you can send a code from the train 700/717 DMI (driver machine interface) as opposed to typing it into the PIS unit as you would do on a 365.
    They moved a step forward on the 387 PIS I felt, and now they've made 2 steps back.
    Although apparently there is the option of it being controlled/updated remotely. Although that is possible on 387s too. But I don't see it used. At least on the TL/GN side.
    I do wonder if the option to load adverts into it exists ?
  13. choochoochoo
    choochoochoo Member
    589
    6 Aug 2013
    Oh, so that's why I check the switch position during a prep ? :)
  14. BlueHorizonUK
    BlueHorizonUK Member
    8
    21 Mar 2018
    Saw one parked up at Kings Cross this morning on platform 11. Had Moorgate on the display. Doors were locked so looked like a diverted train?
  15. iphone76
    iphone76 Member
    559
    6 Nov 2010
    South Essex
    On the Kings Cross Station twitter feed today it said a 717 visited the station on test.
  16. Class315
    Class315 Member
    239
    9 Feb 2008
    2J17 06:28 Stevenage via Hertford North - Moorgate was delayed at Finsbury Park earlier on this morning, the service was ultimately terminated at Finsbury Park and ran into King's Cross as 5J17 were it remained until it worked as 5V49 to Finsbury Park t/f 2V49 10:33 to Welwyn GC.
    To be pedantic but since early last week 2J01 04:22 Stevenage via Hertford - London King's cross is worked by a 717, it returns to Stevenage as the 05:21 2F01
  17. 700007
    700007 Established Member
    1,054
    6 May 2017
    Near a bunch of sheds that aren't 66s.
    Yes and it has been done before. Particularly last summer it was used quite a lot for a variety of things such as telling passengers to keep cool and hydrated during the heatwave, and also promoting the Rail Plan 2020 in the days running up to doomsday.
  18. choochoochoo
    choochoochoo Member
    589
    6 Aug 2013
    I always thought those were pre-loaded when the trains were in the depot.
    I'd like to see Control target a specific train and send a PIS update when they decide to alter the stopping pattern. Rather than expecting the driver to faff around with a cumbersome PIS interface.
  19. Spirit555
    Spirit555 Member
    267
    8 Oct 2017
    I have seen today at various times at Finsbury Park/Drayton Park and Moorgate 717002/003/005/007/009 in passenger service
    HTH
    Mark
  20. Tony2
    Tony2 Member
    55
    7 Apr 2019
    In addition 717018 was also in service yesterday.
  21. APUK002
    APUK002 Member
    315
    26 Dec 2016
    That is true,there supposed to be able to do that remotely on the 700’s/717’s
  22. Railperf
    1,275
    30 Oct 2017
    I used 717009 in the evening and its PIS system seemed to be working okay.
  23. BowesRanger
    BowesRanger Member
    81
    16 Jul 2018
    Same on 19.55 from Moorgate
  24. Af317
    Af317 Member
    27
    3 Sep 2018
    This evening's 717s from Moorgate:
    1705 717007
    1725 717018
    1730 717005
    1800 717009
    1845 717003
  25. Class315
    Class315 Member
    239
    9 Feb 2008
    [DELETED]
  26. Class315
    Class315 Member
    239
    9 Feb 2008
    From Today until Thursday 02.05.19
    Carriage working HE51 will revert back to 2 x 313, but returns to 717 on Friday 03.05.19
    Carriage Working HE54 will revert from 2 x 313 to 717, but returns to 2x313 on Friday 03.05.2019
    HE54
    3B27 06+42 Hornsey EMUD - Hertford North
    2J27 07:32 Hertford North - Moorgate
    2V29 08:30 Moorgate - Welwyn GC
    2K48 09:24 Welwyn GC - Moorgate
    2B50 10:25 Moorgate - Hertford North
    2J65 11:30 Hertford North - Moorgate
    2V67 12:30 Moorgate - Welwyn GC
    2K80 13:28 Welwyn GC - Moorgate
    2B82 14:25 Moorgate - Hertford North
    2J09 15:30 Hertford North - Moorgate
    2V10 16:30 Moorgate - Welwyn GC
    2K31 17:28 Welwyn GC - Moorgate
    2F32 18:20 Moorgate - Stevenage via Hertford North
    2J53 19:30 Stevenage via Hertford North - Moorgate
    2V55 20:50 Moorgate - Welwyn GC
    5I72 21+44 Welwyn GC - Welwyn GC via Reversing Sidings
    2K72 22:09 Welwyn GC - Moorgate
    2B74 23:10 Moorgate - Hertford North
    3D88 00+25 Hertford North - London Kings Cross
    2D88 01:09 London Kings Cross - Hertford North
    5E88 02+03 Hertford North - Hornsey EMUD.
  27. Fred26
    Fred26 Member
    987
    5 Mar 2010
    Is that because of the engineering work overnight?
  28. Skimpot flyer
    Skimpot flyer Member
    425
    16 Nov 2012
    I just checked the NRE journey planner for the weekend of the late-May bank holiday, and trains between WGC and Moorgate are shown as running normally on 25/26/27th May, at least they are, during daytime hours.
    So how are the signals in the Drayton Park to Moorgate section going to be repositioned? Is the work being done overnight?
  29. choochoochoo
    choochoochoo Member
    589
    6 Aug 2013
    Really doubt it will happen over that weekend. Attempting to fiddle with that old time expired infrastructure is asking for trouble. and to do it in an overnight period is a recipe for disaster.
    If I were a betting man, I'd put my money on August Bank Holiday or next Christmas !!
  30. Skimpot flyer
    425
    16 Nov 2012
    Perhaps it’ll be done on time and on budget, by the team that brought you Crossrail...
Share This Page
