ScotRail HST Introduction - Updates & Discussion
ScottDarg
27 Apr 2017
South Lanarkshire
Any idea of the formation please?
Taken from the scot-rail forum:
On its way at the 6th attempt
43142 40615 42030 42579 42010 43143
This brings the total delivered to 22 (21 available if you exclude the Carmont set). Based on the list I've compiled on the Freightmaster forum the sets still to be delivered are;
  • HA06
  • HA14
  • HA19
  • HA20
Happy to be corrected if I'm wrong though.
3 Mar 2020
Middleport
If the aim is to have all long-distance services worked by HST’s, wouldn’t a 170 cause issues with some crew no longer being competent? Especially Perth-Inverness where there are no DMU commuter services like on the Aberdeen route. It would also counter-productive to the goal of removing suburban trains from long-distance services.
Perth and Aberdeen crews will still work other units away from the IC services, as will Inverness. Although with the latter depot it would be just 158s North of Inverness. On top of that I'm not aware yet if there is an odd token dmu diagram that may feature something running along the Highland Mainline or via Elgin which would also serve the purpose of keeping crew cleared to work 170s. 158s certainly look like they would still be OK as replacements on the day regardless of whether any are booked to work the mostly hst operated routes. As all 3 depots that work north of the Central belt would still have some turns presumably.
hexagon789
2 Sep 2016
I don't think any of us can have the slightest idea at the moment - it'll be down to a discussion between Scotrail, the leasing company and the insurers.
One thing which is worth noting though is that if they don't do it now, they may not have the option in the future as Mk3s may not be available, and the work would be more expensive for a one-off job than by adding another set to the current production line.
I accept that, I was purely speculating and I agree - if they want a 26th set they'll need to move sharpish.
I was thinking of revoking a HST diagram on Inverness-Aberdeen which were always planned to be a mix of HST/DMU and you might not need to do that except where there isn't sufficient maintenance cover. I can't remember how many sets were supposed to be diagrammed out of the 26, even with one set out of action there may still be enough maintenance cover to cope.
43096
23 Nov 2015
From memory, I think it was 23 diagrams for them. 23 from 25 looks incredibly tight, especially if the power cars aren't replaced.
St. Paddy
11 Sep 2019
Hitchin
  • HA06
  • HA14
  • HA19
  • HA20
Thanks
hexagon789
2 Sep 2016
That was the figure I had as well, but I wasn't 100% sure. On the subject of power cars, aren't there more pairs than sets anyway, though might still be tight even then.
I can see the argument both ways with this one really, my gut feeling is they won't replace the set from Carmont but I would prefer to be proven wrong on that.
DB
Guest
18 Nov 2009
It's normal to have more power cars than sets as they need more maintenance than trailers and are more likely to be out of service due to failures.
Not really sure what 'gut feeling' has to contribute to the matter - it'll be a financial versus requirements judgement by the parties involved.
43096
23 Nov 2015
There’s 54 power cars (pre Carmont) for 46 planned diagrams. At over 85% availability, I’d say that was ambitious based on historic power car diagramming (normally 80-82%).
hexagon789
2 Sep 2016
The odds seem more inclined towards not replacing the Carmont set given the time it takes to churn out a set and reduced passenger numbers.
So already arguably too ambitious.
I don't know then, present circs. along with what I'd heard on the matter suggested the set would not be replaced.
They still have the option to rework the diagrams and replace certain workings with a 170 given they have more left than they were originally going to have.
43096
23 Nov 2015
There’s an argument to not replace the set, drop the diagrams to 22, but replace the power car(s) so there’s still 54 power cars but 44 required daily. That would sort out the challenging availability target and reduce costs with one less set of trailers.
hexagon789
2 Sep 2016
I can see that be the adopted course of action, given the sets have still to be made up to 5-car and some have still to be delivered as well
But then, the diagrams are a lot less demanding than historical - shorter distances and most of the running would be at c. 75mph vs the large amount of >100mph running on the ECML/GWML.
43096
23 Nov 2015
On the flip side, they are now 40+ years old with the inevitable impact that has on maintenance to keep them going.
John R
1 Jul 2013
The most important bit of them is around 15 years old, and of a newer design, not just a like for like replacement. So maybe mid life.
InOban
12 Mar 2017
I assume that this will be the next pair of power cars going south?
Now rescheduled to tomorrow, Friday
And this time it's running. I'm sure someone will report the power car numbers for those who follow such things.
Speed43125
20 Jul 2019
Dunblane
Is the slower average speed, more stopping and starting service now operated actually less demanding? Would it not be less demanding to be sitting along at a relatively constant speed for longer?
IIRC, the energy required (and therefore stress on the engines) increases with the square of the velocity.
Speed43125
20 Jul 2019
Dunblane
Ek = 1/2 mv^2, yes. However, that assumes that instead of doing hundreds of miles cruising at 125, it's instead doing the same at 75, which simply isn't the case. The trains are stopping and then accelerating back up to line speed much more frequently, which would strike me as putting more stress on the trains. ISTR this may show in the traction motors failing for Scotrail more, even if the MTU units fare alright with this sort of work.
For example if we look at the 1H51 today, it's travelling 180 miles from Queen Street to Inverness, but it's stopping on average once every 18 miles even if we assume the single track sections don't cause it to need to stop anywhere outside of scheduled station stops.
I think it's fair to say that is much more frequent than anything they'd have been diagrammed to do on the ECML/GWML.
43096
23 Nov 2015
Paddington-Bristol "Great Western metro" services are close: 6 stops in 118 miles.
hexagon789
2 Sep 2016
There's a fair amount of 90-100mph running on Glasgow-Aberdeen. Also drivers usually run in Notch 4 with the short sets a driver said some time ago as the schedules are easy to maintain so there's no need for full power unless running late.
20 Mar 2012
Set 23 has just left Doncaster at 1335 according to RTT. Wouldn't be too surprised if the remaining 3 sets were delivered before Xmas
The_Train
2 Jun 2018
Set HA14 formed 43150 40614 (ex-41010) 42012 42245 42013 43163.
Thank you :)
Do we also know why 43124 and 43143 have ventured to Wabtec at Donny?
