junglejames
- Joined
- 8 Dec 2010
- Messages
- 2,069
It doesn't have to be a compromise between faster journey times or a nicer interior - I would love to see UK loading gauge Siemens Taurus locos and the equivalent of OBB "Railjet" push-pull rakes on the WCML instead of Pendos - but in comparison of the WCML at present and in the past then the Pendolinos present more benefits to the general travelling public than they do pitfalls.
Again you are comparing and seem to be accepting a rubbish interior, just because its faster.
They provide pitfalls. Pitfalls that neednt be there. We could have a pendy with a much nicer interior. Or, if thought about fully at an earlier stage, we could have built a train that had the advantages of a pendy, but not the pitfalls. Its not hindsight either. A lot of this stuff would have been obvious from the beginning.
The only advantage I can see of the voyagers, and the interiors of the the pendys, is it softens people up, to such an extent we forget what train interiors used to be like, and just blindly accept the next rubbish interior. Which it just so happens, is possibly right around the corner, in the shape of the IEP, or, partly stealing somebody elses term, off another forum, the Japanese vibrating poo tube. Sounds so much better.
It is if you want it to run at over 110mph on the WCML, yes.
1- I wasnt complaing about it. I was just saying you then need to compensate with the interior design.
2- You could actually run at 125 without tilt if it wasnt for the silly setup and speed restrictions. Plenty of areas where pendys run 125 without tilting. Unless of course they tilt on the straight just to look impressive
3- Pendys arent like they are because they tilt. Its because they are made of aluminium. Aluminium being so much weaker, means extra stiffeners and supports are needed. The main 2 in question being directly above and below the windows, running horizontal along the coach. These supports and stiffeners will also have a large part to play in the large frames between the windows, and the very narrow interior. Also some of the extra supports you can see inside the coach.
Yes it makes the coaches lighter, but at a very big expense.
However, this is one thing i dont complain about, as it was a given the moment aluminium was chosen. I just complain about the fact they havent tried to make the best of a bad situation. Instead they have ended up making the worst of a bad situation.
