Looks like an early stab at a paceresque trainAnd going back a bit further to 1912, GWR Churchward Auto Trailer No. 92. View attachment 44649
Also found in 357s, and 319/2, arriva 142s & 143s, 150s and 153s.
EditedAlso found in 360s however not a comfortable material. (too rough)
(pic is large so took it out of quote)
The first class seats on the 458/5s are the first class variant of the Grammer IC3000, with the others being the standard/second class variant.They are the ones on the EMT 158, but I the 222 is a different type (I don't know the make).
Also in 458/5 first class.
I'm pretty sure the 458/5 first seat is still the standard Grammer, just with a large headrest cushion added on by SWR. There is a first version which can be seen in Europe, that is wider and designed for 2+1 spacing.The first class seats on the 458/5s are the first class variant of the Grammer IC3000, with the others being the standard/second class variant.
As for the seats fitted on the 222s, I believe they are a one-off design specially made for them, but I am unaware of who made them.
They always seemed just that bit wider than the others to me, larger headrest aside, but given I have never personally seen one of the first class one's in Europe I know it could be mistaken.I'm pretty sure the 458/5 first seat is still the standard Grammer, just with a large headrest cushion added on by SWR. There is a first version which can be seen in Europe, that is wider and designed for 2+1 spacing.
One thing to point out about the Fainsa seats, is that on some trains (700 at least), they have a cantilever construction out from the wall of the train, instead of being supported by a pillar underneath the inboard seat. Much better for legroom and cleaning.Fainsa 'ironing board':
Found in: Class 377/6, 377/7, All 387s, 700s, 707s and other classes yet to enter service
Pros: Very good posture, very supportive, comes with good legroom in Electrostars
Cons: Lack of padding can cause discomfort, seat spacing problems in the 700
MY OVERALL RATING: 7/10 (Highly subjective, many would disagree strongly on this)
I would say the "Mallard" style of seating does have the following pros and cons:-"Mallard" standard class seats
(not my photo)
Found in all standard class Mark 4 coaches, most VTEC HSTs, and all CrossCountry HSTs
Pros: Very deep cushioning, good angle with the window, decent amount of legroom.
Cons: Not an awful lot of elbow room on window seats, cushioning eventually wears down after a few years use.
View attachment 44629 View attachment 44630 The other 142 style.
Another downside from the seat leaning back too much is that (in some seating positions) if you want to look out of the window you have to physically lean forward - as often you are sat so far back you are away from the window - note image above. Also rather cramped on the face to back seats.Last one for now:
Ashbourne:
(not my photo)
Found in: Ex-BR units including classes: 150, 319, 320, 321, 322
Pros: Well sprung and padded.
Cons: Seats too low to ground and leans back too much, so bad posture, unsupportive.
MY OVERALL RATING: 3/10
Con by original design: hurts some peoples' backs because the base cushion slopes the wrong way and so doesn't give any underthigh support.
I believe the VTEC refurb fixes this by using a two piece cushion, though.
IC70:
(not my photo)
Found in: Chiltern, Greater Anglia etc. Mk3s, Mk2 Short sets, EMT (and two VTEC) HSTs
Pros: Very well padded and sprung, good width, seats low meaning good view
Cons: Seats low, therefore unsupportive, posture encourages slouching, especially if tall, fixed armrests a nuisance and limit shoulder space
MY OVERALL RATING: 5/10
Maybe it’s me, or the first class seats, but I always found them comfortable.
A pity the VTEC refurb didn’t repair the seats.
I'm not sure what the name for them is but they're only used on Networkers, Turbos and 323s, which would suggest that it is a British Rail design of some sort, probably a follow on to the Ashbourne design.3. What type of seats these are as they do not look like Ashbourne seats?
1. They are made by Compin, though I don't know the exact type. They can also be found on various trains in France.Can someone answer the following:
1. Are those are Compin seats?
2. What sort of ironing board seats these are?
Sorry for the large pictures as they are not mine and from Wikipedia.
The only 377s with sprung seats are:I think I have a good tip for those who don't know to identify the best seats on an electrostar e.g. Compin seats that are sprung:
If the poles in the vestibule bend straight down (more common with 2+2 seating than 3+2), where it is 2+2 seating, the seats are sprung.
If the poles in the vestibule curve on the way down (more common with 3+2 seating than 2+2), where it is 2+2 seating, the seats are not sprung.
377101—377119 (throughout)
377120—377139 (only at carriage ends, the rest is 3+2)
377301—377328 (throughout)
On 375s, I think the /3s, /6s and /7s have sprung seats but these might have been removed at refurbishment.
These are theChapmanRichmond seats - also found on the Class 144.
In terms of personal opinion I'd say I'll agree with class387; satisfied with the Grammer and Fainsa seating, and very much pleased to be seeing a lot less of the Ashbourne now.
