WCML Future Routes
WatcherZero
25 Feb 2010
Today -10% total of services but with quite specific minimum daily service requirements.
Zoe
22 Aug 2008
The train service reuquirement allows a ten percent reduction in the daily number of stops (or one stop if there are less then ten) but no overall weekly reduction.
calc7
8 Aug 2011
Pathing-dependent, I'd like to see a RUG stop every 2hrs on a non-BHM train (maybe one of the Manchesters?) This would also alleviate the NMP issue.
VTPreston_Tez
26 Jan 2012
Preston
Euston to Glasgow has 1 per day afaik, I've rode it. It probably gets more though.
MidnightFlyer
16 May 2010
VTPreston_Tez
26 Jan 2012
Preston
calc7
8 Aug 2011
Rugby will get faster trains if the 110mph LMs come off.
But where will they go to northwards? If it's Birmingham then there's already the xx03 VT from Euston. If it's Crewe via all shacks then it isn't useful. A more regular stop at Rugby would make Coventry and Northampton from the north, as well as Rugby itself, more attractive propositions.
NSE
3 Mar 2010
I'd like to see the Southern service extended north, maybe Northampton. I've used them and they seem well used.
calc7
8 Aug 2011
Northbound at xx03 ish would fill the gap between xx54 and xx25. Southbound its path is to leave MKC at xx13 so would need to leave NMP around xx56 - there is a LM xx50 and xx05 so perhaps not the best timings in that direction.
NSE
3 Mar 2010
Ahhh maybe not then, it's surprising how well used they are though. Maybe a joint service between SN and LM could combine between Brighton and Birmingham. That might be more feasible.
VTPreston_Tez
26 Jan 2012
Preston
Has anyone ever thought of a full-on dual TOC operation? For example a ScotRail/LM joint service from Euston (I know) with FSR going to Fort William and LM going to Liverpool Lime Street. They would operate together up to like Crewe, where FSR would go limited stop to Fort William so something like Warrington-Wigan-that dreaded place-Lancaster-Oxenholme-Carlisle-Edinburgh-all stops to Fort) and LM all stops to Lime Street.
I'm sure it's not the best idea ever, but would be interesting to see some domestic services to Scotland from London all the way up north that don't run in the dark hours. The stock would need to be compatible and I'd guess the FSR as a DMU being hauled by a LM EMU up to the split may work, what stocks can be coupled together that would work the route?
VTPreston_Tez
26 Jan 2012
Preston
What would be the advantage over the existing Birmingham - Glasgow / Glasgow - Mallaig services?
  • It's all in one so there's no need to change
  • The first leg doesn't operate as Voyager
  • Well really it's a Pendo as it's running from London, but Brum may work
  • The service would skip Glasgow and go straight to Edinburgh Waverley and that would cut journey times
  • New connections in general
  • It would showcase the teamwork between ToCs
  • The WCML could do with some shinier and better-looking stock (all the stock is too dark and dismal for me ATM
They're what I had planned. Bet I could think up of more.
telstarbox
23 Jul 2010
Wennington Crossovers
MidnightFlyer
16 May 2010
- True, but at a massive time penalty as shown here it may be worth changing to save yourself hours!
- Indeed, quite a few Birmingham-Scotland trains are now Pendolinos.
- How to hell would it join to a Liverpool service at Crewe then? What do you propose to do to get this train from Edinburgh-Fort William too? 57 haulage?
- Via Edinburgh would add the best part of 45-90mins onto a journey to the West Highlands in lieu of via Glasgow :|
- True, but enough I suspect to detract from a 10 min walk across Glasgow or a change at Queen St ex-EDB.
- As is demonstrated at quite a few points already (ticket acceptance and joint TPE / NT, SR / NT and SE / FCC working to name but a few)
Seriously? What a pathetic reason :roll:
sprinterguy
4 Mar 2010
Macclesfield
[*]The service would skip Glasgow and go straight to Edinburgh Waverley and that would cut journey times
By running all the way over to Edinburgh, and then back all the way to the west to join the West Highland Line journey times would probably be longer than they are with a change (and cross-city interchange) in Glasgow at present.
Time-keeping in general for this service would probably be abysmal due to the sheer length of the service and the long single track run from Helensburgh to Fort William where any delays would also probably impact on the other WHL services.
The through market is minimal - trains on the West Highland are generally 156 or 158 units compared to Voyagers south of Glasgow
Trains on the West Highland are solely 156s; 158s aren't gauge cleared for the route.
Ivo
8 Jan 2010
Bath (or Southend)
As NSE shows here:
Everyone and their mother has already realised that a link between LM and SN would be feasible on this route. But should one or the other fall under the control of someone other than Govia, unless an arrangement such as that of NT and SR on Newcastle to Glasgow applies (which proves that such arrangements do already exist) then it would be far harder to implement. Any other option would fall foul of the same problem.
Seriously though, any such suggestion would have to be on a viable route. Newcastle to Glasgow is feasible. Birmingham to Brighton is feasible. London to stations on the West Highland Line is not.
Isn't it past your bedtime Tez?
Now that is harsh ;)
Ivo
8 Jan 2010
Bath (or Southend)
I'm all for enthusiastic "fantasy" ideas, but there has to be a time and a place for these things
Of course you are. Not so long ago you were one of the main protagonists ;)
For the record, the time was Spring 2011, and the place was General Discussion. In other words, fantasy threads have had their day :(
NSE
3 Mar 2010
I'm intrigued to see this Pendo hauling a 350 to Crewe before turning into a FSR 158, or is this attached at Birmingham?
