Class 707 - SWT: Introduction into service
Now that you mention it, the only reason that this is done on third-rail only Electrostar units is so that their suspension setup is roughly equivalent to a dual-voltage unit.
So I understand, but Siemens must historically (at least) have adopted a different approach to suspension compensation. Which wouldn't be surprising, I'm sure there must be different solutions available.
Peter Sarf
Croydon
Correct. The DV 350/1 ran as a 12 cars from WCML to Basingstoke to prove the concept.
And then, some time later, some 350s (/1s ?) were loaned to Southern to operate the Milton Keynes (or thereabouts) to Brighton (or Croydon ?) service. This was while the dual voltage units (377/2s or was it 319s) that were meant for the service covered for other services (on Thameslink iirc). Sorry some real holes in my memory on this but someone will fill-in/correct the blanks.
Nym
2 Mar 2007
Somewhere, not in London
In other words, BT couldn't be bothered doing two structural assessments?
D365
29 Jun 2012
Eh? If the suspension was configured differently on a third-rail only Class 377, for example, wouldn't that mean more work would be required in order to convert it to a dual-voltage unit?
Class377/5
19 Jun 2010
5x 350/1 were loaned to Southern while the newly arrived 350/2 arrived.
This allowed a bunch (I can't remember numbers) of 377/2 to be loaned to FCC to run the KO0 timetable (where some FCC and SE services were linked and ran jointly).
In return for this cascade 3x 375 transferred to Southern from SE to run a singe peak diagram.
No 319s were loaned, all transferred to FCC for the March 2009 timetable change.
Class377/5
19 Jun 2010
No Bombardier made sure that two different set up had the same performance so drivers didn't have to adjust for different sub types when braking which is never clever.
Fincra5
6 Jun 2009
Which is actually quite sensible to be fair.
D365
29 Jun 2012
Obviously in the case of SWT it doesn't matter in as their third-rail only Class 450 fleet is completely separate from the Class 350s.
leomartin125
15 Nov 2015
North West
Kite159
27 Jan 2014
West of Andover
They certainly sound great when they depart, very much the Desiro motor noise.
Like others have mentioned, I wouldn't be surprised if one of the bidders for the new franchise hasn't put an idea to order 60+ additional 707s to replace the 455/456s
Suraggu
23 Oct 2013
The Far North
As part of their franchise bid tenders went out for brand new rolling stock including stock for Suburban workings.
Mind you they also put out a tender for self powered units with the ability for 3rd rail...
Class377/5
19 Jun 2010
Who says they haven't had a word with Siemens. Next year the five line production for Desiro Cities is not going to have any work with the ability to make 10 coaches a week.
More likely to be Stagecoach that have done so isn't it?
Yet First has actually signed an order for far more Desiro coaches (1140) than Stagecoach (883 coaches).
Monty
12 Jun 2012
You would need to nearly double that number to replace the 455/456 fleet completely.
Peter Mugridge
8 Apr 2010
Epsom
Not sure... SWT has 59 of the 455s doesn't it? So 60 more 707s would exactly replace them on a like for like basis with no need to account for the 456s since the 707s are 5 car?
jayiscupid
19 Aug 2015
Singapore
Do we know when the winner will be announced? I've seen Feb 2017 but I'm not sure if that was before the short extension.
AlexNL
19 Dec 2014
To be honest, what would be the benefit of removing it at all, aside from consistency?
What's not there doesn't have to be maintained, and can't cause any faults either.
aleggatta
28 Sep 2015
Also, assuming that all Desiro City trains have the same traction packages, it can simply be put in with the number of service spare parts for other desiro city trains that do have the AC kit
Class 170101
1 Mar 2014
A pair of 707s on test have just passed Bracknell en route to Reading
If 10 car EMUs are running on test does this mean the power supply upgrade has been completed?
A reason for running 10 cars is that should there be a failure it is unlikely that both units will fail and the ok unit will assist the demic back to the depot.
