12CSVT
- Joined
- 18 Aug 2010
- Messages
- 2,611
According to 'Rapid Transit Miles & Chains' by S.Clarke Kings X to Tottenham Hale is 5 m 26 ch
What I think they should have done, which would have perhaps solved the issue of people breaking the doors so easily by boarding when the doors are closing, is had the footwell lighting change form bright white to red - and then flash - as the doors are closing. At the moment, the white lights stay on until the doors lock. A missed opportunity there.
It might help, but I'm not sure how much a difference it will make though. There are many people these days who rush as they hear the warning sound just so that they could get half their body on the train which means the doors opening again to let them on. To be honest, I feel that guard making an announcement in the train before closing the door rather than giving those outside a cue to start hurrying up as a better alternative. Unfortunately there will not be a perfect solution to this problem.
Perhaps the lights should not flash or change colour, but merely go off as soon as the doors are about to close? I mean, why keep the lights on until the doors are locked?
But the footwell lights don't flash, the tiny little icon that is only on one side of each door does - which is rather easy to miss.
I am sure that making the footwell lights flash, or change colour, would aid the visually impaired AND the hard of hearing.
I am sure Bombardier and TfL did whatever was required for compliance, but I am sure they could have done more - but it would have been more expensive.
Also, if they had wanted to make it clearer to the visually impaired and hard of hearing, why didn't they have TWO lights by each door - which could (like in Barcelona) show the side the doors will open and then switch to warning that the doors are closing? And why not make them a little bigger too?
I believe it's a visibility issueI think flashing works best, as it draws attention to the fact the doors are closing. (if they just went off, people - especially the hard of hearing - could think that the lights have failed, rather than the doors are about to close)
I wonder what proportion of Metropolitan Line trains are now S class. I hope plenty of them run through to Aldgate by now
I may be able to travel for example from Finchley Road to Victoria, changing at King's Cross, and thus ride an S class and an 09-stock train consecutively!
Yes, they have been for a few months now. Still not many in service yet though.Are they running though now? I'm still to use one, and only saw one a year or so ago at Wembley Park (but didn't go on it).
It is, and has been for a while now.I don't think the S stock is running Baker Street - Aldgate just yet.
Back on the Victoria Line, I have been told that yesterday 17th saw the withdrawal of the last rake of 1967 stock. Presumably that was 40 + 41 as it was reported running the day before?
Mon-Fri now usually 4 in service.Are there enough to warrant going along to try and wait for one? Are there any days they definitely are (or aren't) running?
are there enough to warrant going along to try and wait for one? Are there any days they definitely are (or aren't) running?
SSR Update said:From SOT on Monday 13th June, an additional S stock will run in service as T443. This will be in addition to all S stock services previously operated, i.e. T441, T451/T431/T474, T462/465, resulting in a maximum of four S stock trains operating on the line at any one time. For information, T443 reverses at Aldgate once in the morning peak and then again from the evening peak until its last northbound trip (departing ALD at 00.141/2).
Last already? Did they withdraw more than one at the same time then? I thought that there were still a fair few left and available for service [albeit limited to just 2 diagrams]
I will definitely take some time out to try and ride one if they are being operated in any reasonable numbers.
If you want to do both, make sure you wrap up warm for one and then strip off for the other! I think you will be able to work out the correct order!!
I can confirm that some services are still running with 67 stocks; I had 60+61 home from work this evening.Back on the Victoria Line, I have been told that yesterday 17th saw the withdrawal of the last rake of 1967 stock. Presumably that was 40 + 41 as it was reported running the day before?
Even with the delivery rate stepping up to 1 per week from August, they couldn't deliver all 58 trains by the end of this year.I have seen on Wikipedia that the last S class trains for the Met are due around the end of the year.
to this.06: 16th October
07: 29th July
10: 16th July
11: 29th July
20: 29th July
21: 20th August
22: 29th July
26: 29th July
28: 29th July
32: 16th July
35: 20th August
42: 29th July
43: 29th July
44: 16th July
45: 29th July
47: 29th July
49: 16th July
50: 29th July
54: 29th July
55: 2nd July
56: 29th July
58: 2nd July
65: 16th July
66: 16th July
67: 29th July
72: 16th July
78: 28th July
80: 16th July
82: 2nd July
84: 16th JUly
86: 16th July
